Thomas4
Thomas4
Thun, Berne, Switzerland
192 registered members (68 royalstar tony), 1,669 guests, and 518 spiders.
analyse, Drifter, john harrison, David Stothard, iansouthoz
10039 Registered Users
Lannis 149
kommando 113
478,877 mail-order LSR
Topics65,746
Posts635,570
Members10,039
Page 4 of 4 1 2 3 4
Re: Oil pump failed, wet sumped. What to do? [Re: Matthew in TO] #448691
08/11/12 8:08 pm
08/11/12 8:08 pm
North Georgia, USA
RF Whatley Online content
RF Whatley  Online Content
North Georgia, USA
Originally Posted By: Matthew in TO
Had the primary cover today. Oil seal is completely out, dangling behind the magnet.
The reason I asked if your primary was a breather type way, way, WAY back at the beginning of this thread is because when oil is allowed to transfer from the primary case into the engine, the incidence of oil wet sumping goes WAY up. The reason: clutch debris, which the c/s seal typically keeps out.
So while the engine may have oil wet sumped first, and then blown the seal out. It's also just as likely that the oil seal blew out, then allowed clutch debris into the engine, THEN the engine oil wet sumped.
No way to tell at this point. smirk
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Oil pump failed, wet sumped. What to do? [Re: RF Whatley] #450450
08/22/12 7:17 pm
08/22/12 7:17 pm
Toronto, Ontario, Canada
Matthew in TO Offline OP
I'm thinking of buying a rotary oil pump http://www.morgo.co.uk/rotary.html#triumph_rot to put this issue to bed forever on my machine.
1970 Triumph T100S (1969 T100S motor)
Re: Oil pump failed, wet sumped. What to do? [Re: Matthew in TO] #450458
08/22/12 8:10 pm
08/22/12 8:10 pm
The rotary brings its own set of problems such as losing prime and where to send the surplus oil, its for racing not for roadwork.
Re: Oil pump failed, wet sumped. What to do? [Re: triton thrasher] #450581
08/23/12 3:40 pm
08/23/12 3:40 pm
Chesapeake Virginia
aprophet Offline
aprophet  Offline
Chesapeake Virginia
Originally Posted By: triton thrasher
Did you inadvertently use a filter element with a non-return flap and try to pass oil through it the wrong way?
How would one be able to tell this ? Are the Map / Triple filters like this what is "the right way " for flow on these ?
1964 A65C Rocket (Jeanie)
1971 T25SS
1971 A65T BSA (Lucile)
1965 A65D Lightning Rocket
Re: Oil pump failed, wet sumped. What to do? [Re: aprophet] #450595
08/23/12 4:44 pm
08/23/12 4:44 pm
Stuart Online content
Stuart  Online Content
If, by "this issue", you mean oil seals blowing out, you should read John Healy's past posts on the subject before you part with your money. If I understand John's posts correctly, the Morgo rotary pump will exacerbate the "issue", as well as bringing a few others of its own. frown Fwiw, as a long-time triple owner, I too thought a rotary pump on my 500 would be A Good Idea; thankfully, I read John's experience before I parted with my money. whistle
The filter cartridges made to fit the compartment in the Triumph and BSA triples' crankcases do not have "a non-return flap" as such. However, certainly on the triples, the oil enters the hole in the centre of one end and flows through the filter itself from the inside out; this way, any filtered matter is held in the centre of the filter - instead of dropping off the outside - when it's removed for replacement.
Page 4 of 4 1 2 3 4
