breeze1954
breeze1954
S.W. Pa.
37 registered members (Blown Income), 248 guests, and 412 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 98
Stuart 83
reverb 80
NickL 73
koan58 56
549,657 mail-order LSR
Topics66,547
Posts645,104
Members10,170
Crank pinion removal -- 1939 Triumph Speed win #445522
07/20/12 11:56 pm
07/20/12 11:56 pm
Texas
tomgunn Offline OP
tomgunn  Offline OP
Texas
Hey guys:
Anyone know how to pull the crank pinion gear on a 500cc Speed twin? Only about .020 to .030" clearance between gear and crankcase. No room for a puller and no puller thread. Afraid to press crank through -- may break crankcase?
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445540
07/21/12 4:55 am
07/21/12 4:55 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
Is there a thread on the outside of the crank pinion?If there is,use the cam wheel puller.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: Pete R - R.I.P.] #445543
07/21/12 5:36 am
07/21/12 5:36 am
Magnetoman Online content
Magnetoman  Online Content
According to Instruction manual No. 4, "The tool part number Z.89 shown in Fig. 11 is necessary for the removal of these [camshaft and crankshaft] pinions." Fig. 12 shows the puller in use on one of the camshaft pinions, but the nut on the crankshaft pinion obscures the view of it. It's been many years since I had my Triumph 500's engine apart so I don't remember this detail but, as Pete R. wrote, the manual clearly says the same puller works on both.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445550
07/21/12 7:10 am
07/21/12 7:10 am
There's a puller made for Triumph crank pinions, isn't there? Google say there is. It has thin round jaws to get behind the pinion.
Anyway, can't you heat the crankcase to let the bearing and pinion slide through when you lift the crankcase off the crankshaft? Then you might have room to attack the bearing and pinion. In fact, I think the manual says all this.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445554
07/21/12 9:24 am
07/21/12 9:24 am
dave jones Offline
dave jones  Offline
I had a similar problem on my 67 because the previous owner had left the clamping washer out. This meant that there was no room for a puller. As Triton describes and because I was stripping the engine anyway I heated the case and just took the whole assembly out and then removed the pinion and old bearing.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: Pete R - R.I.P.] #445565
07/21/12 1:02 pm
07/21/12 1:02 pm
Texas
tomgunn Offline OP
tomgunn  Offline OP
Texas
As I said in my post, there is no thread for a puller on the crank pinion gear, and no room to get a puller behind it. The gear outside diameter is larger than the hole diameter in the crankcase. Thus the challenge....
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445567
07/21/12 1:32 pm
07/21/12 1:32 pm
I'd like to see a photo.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445586
07/21/12 3:01 pm
07/21/12 3:01 pm
Ellisville, Ms.
Allan Offline
Allan  Offline
Ellisville, Ms.
If you can remove cam gears, then you may be able to clamp a u-bolt around the crank gear to gain enough grip to pull gear with a regular jaw type puller. Be sure to wrap some soft aluminum or copper around gear to protect teeth. Allan
member GABMA(Greater Atlanta British Motorcycle Association)
Pre-unit triumphs
Unit Triumphs
Tiger cubs
(1) Trident
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445601
07/21/12 6:21 pm
07/21/12 6:21 pm
dave jones Offline
dave jones  Offline
Sorry, I thought the gear fitted through the hole on the pre units too.
The crank pinion isn't nearly as tight as the cam gears on a unit so maybe the trick with the clamp would work if pre units are the same!
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445604
07/21/12 6:57 pm
07/21/12 6:57 pm
Sorry, my fault for not noticing it was a '39 Speed Twin rather than a later one.
Instruction manual No. 11 that covers 1945-55 Speed Twins shows a rather special Crankshaft Pinion Removal Tool Z60. "Crankshaft Pinion: Again a special tool must be employed to withdraw this gear from the crankshaft." At some point I'll give up and set things up to let me upload images, but for now you'll have to settle for a description.
The figure of the puller, and the instructions for its use, show it has two flat jaws, i.e. it sort of looks like a two-jaw puller, but without the hooks at the ends of the jaws. A collar slides down over the jaws to clamp them against the OD of the gear. This clamping action is much the same as on some two- and three-jaw pullers where a separate tapered piece screws into place to keep the jaws from separating. Anyway, since there are no hooks on the jaws of the special puller, only sideways pressure from the collar causes them to grip the gear.
Because the puller relies on only friction to clamp it, it means the gear shouldn't be held too tightly by the crankshaft (it is a straight shaft with a key, not a tapered shaft, so only solidified grunge should be holding it). I suggest trying something as simple as a hose clamp to hold two small pieces of metal (or bolts) against the gear. This would provide the surface you need to grip with the jaws of a standard puller.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: dave jones] #445614
07/21/12 9:12 pm
07/21/12 9:12 pm
It does.
I don't know about pre-war. That's why a picture would be interesting.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: Magnetoman] #445628
07/22/12 12:35 am
07/22/12 12:35 am
Jon W. Whitley Offline
I have available to me the 1958-1962 Triumph workshop manual in .pdf and that manual uses tool Z121. Good luck finding one for sale from a vendor! Anyhow, thought I would post a pic.
BTW, I ran into this same problem with a 1961 TR6R I dismantled a few years ago and that timing pinion gear didn't have threads on it either. As far as I know none of the Pre-Unit crankshaft timing pinion gears do. The same timing pinion E1472 was used in the 1939 through 1962.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: Magnetoman] #445629
07/22/12 1:08 am
07/22/12 1:08 am
JubeePrince Offline
JubeePrince  Offline
Instruction Manual No. 11 that covers 1945-55 Speed Twins shows a rather special Crankshaft Pinion Removal Tool Z60.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445654
07/22/12 9:42 am
07/22/12 9:42 am
Tasmania - Gateway to Antarcti...
Tasman Offline
Tasman  Offline
When I stripped the motor on my pre-unit I tried to find the correct tool, but they were beyond my price range even if they were available. I made my own puller out of bits I had on hand.
The large washer is 60mm (2 3/8") across with a nut welded to one side and a 16mm (5/8") washer on the other - This locates on the nose of the crankshaft as the hole in the large washer was only 1/2". Two 6.2mm (1/4") holes are drilled opposite each other at 45mm (1 3/4") centres
The unit has to be dismantled and the legs (6mm bolts with the heads ground down) hooked under the crankshaft pinion. The large washer slides over them and it's all held together with the wing nuts. The centre bolt is tightened and the pinion is pulled off the shaft.
Sorry if this is a little long winded or hard to understand but it is a viable solution to the problem.
"Live the life you love, find a god you trust and don't take it all too seriously"
Pre-units rule!
Mid fifties Triumph T100
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: tomgunn] #445659
07/22/12 10:07 am
07/22/12 10:07 am
A large self-grip (Mole wrench) holding the pinion, with strips of mild steel protecting the teeth, might give you something to get the legs of a puller onto. I mean hook the legs onto the outside of the self-grip.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: triton thrasher] #446006
07/24/12 10:22 pm
07/24/12 10:22 pm
Austin, Texas, USA
Brid Caveney Offline
Austin, Texas, USA
Tom -- BCS show tool Z60 as 222-158/A, crank pinion puller Tri early.
If it's not A65's causing trouble it's those darned Trumpets!!
See you later,
Brid.
Re: Crank pinion removal -- 1939 Triumph Speed win [Re: Brid Caveney] #446492
07/28/12 12:14 pm
07/28/12 12:14 pm
Texas
tomgunn Offline OP
tomgunn  Offline OP
Texas
Just to update everyone who was nice enough to try to help me with this problem....Could not get a Z60 puller. I doubt if it would have done the job as it only clamped on the side of the gear teeth, not behind them. To reiterate, the crank pinion was larger than the case diameter, had no puller thread, and less than 0.010" clearance behind it.
I got it off by having a special puller made and spot welded to the crank pinion. Even then it was a tough pull.
The other 1939 speed twin engine I am working on had puller threads on its crank pinion. Even with that, it was a tough pull with heat.
Many thanks to all who replied to my plea for help.
Page Time: 0.077s Queries: 15 (0.005s) Memory: 1.1248 MB (Peak: 1.3864 MB) Zlib disabled. Server Time: 2018-04-20 18:24:51 UTC
