DodgyRog
DodgyRog
Essex
43 registered members (998John), 282 guests, and 470 spiders.
10257 Registered Users
Lannis 54
TBolt72 47
610,583 mail-order LSR
Topics67,143
Posts651,578
Members10,257
Amal Monobloc - Setting the float height #444928
07/16/12 2:34 pm
07/16/12 2:34 pm
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
I gather that the original float cover had a pip cast into it which is used to measure the amount of fuel in the float chamber against a piece of clear pipe attached to the pilot jet.
Unfortunately, my float cover is not original and doesn't have this feature.
Does anyone have an actual measurement for the correct position of this feature or a measurement for the correct amount of fuel?
The carb is a 1" 376 Monobloc.
I ran my Tribsa for the first time in 15 years this weekend
It was running extremely rich. Seems the fibre washer included in AMAL's repair kit is not required for the fuel inlet. It raises the level of fuel considerably before the viton tipped valve stops the supply of fuel.I removed this washer and it runs better but still too rich.
What's the next thing to check after the float height?
Is it common practice to drop the needle a notch to lean the mixture or should it ideally run in the middle notch?
All the jets and needles are new AMAL components but the float is reused. It's a plastic rather than brass float. It doesn't seem to be punctured.
1952 Triumph T100 in a BSA A7 Frame
Re: Amal Monobloc - Setting the float height [Re: Mattsta] #444942
07/16/12 3:41 pm
07/16/12 3:41 pm
John Healy Offline
John Healy  Offline
The fuel level "pip" was at the geometric center of the cover.
A long shot is the gasket under the jet block is leaking - again a long shot!
Another long shot is the pilot jet itself. If it isn't fully seated it will leak fuel by-passing the action of the pilot jet. This makes the bike run rich. - again a long shot.
Saying it runs rich is not the way we should be going about this. If it is running extremely rich at all throttle openings you might have the choke on - a long shot, but a common occurrence.
This carburetor has several fuel circuits that could be causing this problem. Each circuit is referenced to by the position of the slide (and the handle bar throttle). So when you say the bike is running rich under 1/4 throttle we can give you the fuel circuits (jets, slides, etc.) to check. In fact the Monobloc (and Concenntric (MKII has three)) is two carburetors in one. The idle carburetor and main carburetor which share a common fuel source but act independently of each other.
So after ypu check the fuel level, check the position of your choke and if both of those don't improve things mark your throttle: 0, 1/4, 1/2. 3/4 and Full and ride the bike and note where the bike is running rich... Then we can sort this carb out.
Re: Amal Monobloc - Setting the float height [Re: John Healy] #444943
07/16/12 3:53 pm
07/16/12 3:53 pm
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
Hi John
Thanks for your post
Am I correct to assume that the correct fuel level is roughly the centre of the cylindrical float chamber then?
I will check the pilot jet is tightened and that the jet body is not loose in the carb body. The washer is new and I'm pretty sure I checked that the jet block was tightened fully into the carb body
As far as the choke goes, there is no choke fitted and never has been. The bike starts fine without it. It doesn't get used at all during winter. Maybe this is a problem in itself????
Re: Amal Monobloc - Setting the float height [Re: Mattsta] #445652
07/22/12 7:47 am
07/22/12 7:47 am
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
Seems the rich running problem was caused by a dodgy pilot jet. I removed it and inspected and there didn't seem to be anything untoward about it but I replaced the pilot jet with my old one and the rich running problem was cured immediately.
A very strange turn of events yesterday getting the bike running properly
After curing the rich running problem, the bike started to run on one cylinder. I removed the LHS pick up holder from the magneto to discover that the carbon brush had separated from its spring.
My first thought was SHIT! because I now have a carbon brush sitting in the bottom of the magneto body which would mean I would have to remove the magneto, strip it, re-time the engine and such forth. By an incredibly stroke of good fortune, I removed the rear pick up holder and the carbon brush was sitting intact on top of the rear pick up moulding! LOL! Phew!
Fortunately, I have a couple of spare pick up brushes. Fitted a new one and the bike still didn't fire on the LHS cylinder.
My mate suggested I fit another spark plug so I replaced the (new) one with and old one I had in the shed and bingo! She fired and ran properly for the first time in 15 years.
How odd to have a magneto brush AND a new spark plug fail simultaneouly!
Just a couple of things to sort out now before I get her MOT'ed.
The dynamo isn't working so I will test that today and see if I can diagnose the problem and I need to do some work on the rear brake pedal which isn't fitting properly.
