mike treloar
mike treloar
new zealand
43 registered members (Adam M.), 201 guests, and 55 spiders.
Championhomer, TROUBLE, Nazer, locobeta, Walt
10390 Registered Users
NickL 95
Mori55 89
Triless 88
Rohan 84
reverb 79
btour 69
DavidP 68
692,012 mail-order LSR
Topics68,056
Posts662,235
Members10,390
forks "topping out" #445058
07/17/12 1:00 pm
07/17/12 1:00 pm
Brooklyn, NY
Jamie Boud Offline OP
Brooklyn, NY
Just changed the fork seals in my 'stock '68 T100C. Prior to changing them, my forks were occasionally "bottoming out" when I hit a rough patch of road so while I had my forks apart, I decided to fit a new set of fork springs, too.
I ordered a set of "heavy duty" springs (as specified for the T100C in the parts catalogue) and it seems to have fixed my the problem of bottoming out, but NOW I have a different problem. Instead of bottoming out, the forks now occasionally "top out." That is, they "clunk" on the rebound.
The topping out isn't happening on every little bump, but the roads can be pretty rough around here -- open pot holes, lumps of asphalt, cobblestones, etc. -- and it's happening more than I expect it should. (it's topping out more often that it was previously bottoming out.)
I've been using ATF for fork oil. Is this too light? Will simply using a heavier weight oil solve the problem or is something else going on? I have some 20w fork oil on order (can't seem to find anything heavier than 15w at the local shops) so I guess I'll find out soon enough if this is a simple fix. In the mean time, any other ideas?
-Jamie
1968 T100C
Re: forks "topping out" [Re: Jamie Boud] #445064
07/17/12 1:28 pm
07/17/12 1:28 pm
Waldorf, Maryland
Tiger Dale Online content
Tiger Dale  Online Content
Waldorf, Maryland
The switch to a modern fork oil should help alot.
I run 20wgt. in my bike and it's about right for me. I weigh about 167. I may try switching back to 15wgt. for more compliance.
Either way it is cheap enough to experiment with different weights.
Dale
Re: forks "topping out" [Re: Jamie Boud] #445098
07/17/12 5:31 pm
07/17/12 5:31 pm
Brooklyn, NY
Brooklyn, NY
Thanks Dale.
I'll give the 20w a try once when I get a hold of some. Hopefully that'll do the trick.
-Jamie
1968 T100C
Re: forks "topping out" [Re: Jamie Boud] #445104
07/17/12 5:56 pm
07/17/12 5:56 pm
dave jones Offline
dave jones  Offline
On my 67 650 which has similar forks but witthout shuttle valves the normal weight oil is 30. I put some 20 in and they clang more when they become fully extended after a bump. 30 is best.
dave
Re: forks "topping out" [Re: Jamie Boud] #445186
07/18/12 10:09 am
07/18/12 10:09 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
You could effectively soften the spring rate and lower the ride height slightly.
Loosen the cap nuts a few threads,or take them off.
Fully compress the forks.Use ropes or other implements of destruction to winch the forks to fully compressed.If you only loosened the cap nuts,allow 30 minutes for the air pressure to bleed out around the threads.If you removed them,just screw them up tight while the forks are compressed.
I religiously bleed the air out of forks and run on spring-rate,not compressed air.
Re: forks "topping out" [Re: Jamie Boud] #445215
07/18/12 12:52 pm
07/18/12 12:52 pm
Brooklyn, NY
Brooklyn, NY
Sounds like it'll take a bit of experimenting. 20w is "by the book" although I see 20w or 30w is recommended for the earlier forks. I've got the 20w on order so I'll try that first and see. I've never been able to find anything heavier than 15w fork oil in the local shops and since I have the ATF for my primary, that's what I've always used. Might've been part of the problem with the forks bottoming out in the first place. (Although, aside from them topping out, the forks feel a lot better with the new springs.) If the 20w doesn't fix it, I'll try going heavier.
Pete - I've never heard of bleeding the air out of the forks, but do you have to do that regularly? I can't imagine the forks are so air-tight that air wouldn't bleed back into the forks during and/or between rides -- Am I wrong?
1968 T100C
Re: forks "topping out" [Re: Jamie Boud] #445231
07/18/12 1:30 pm
07/18/12 1:30 pm
Vic. Australia
Vic. Australia
There's too much air in the forks if they're assembled "normally",without bleeding them.You want no internal air pressure when they are fully compressed.I've used 50 grade engine oil in these early forks,but not on a "C" model with competition damping.
Some really smart forks are self-evacuating with one-way valves.Rickman frame is like this.
Re: forks "topping out" [Re: Jamie Boud] #445237
07/18/12 1:57 pm
07/18/12 1:57 pm
Brooklyn, NY
Brooklyn, NY
What you're saying makes sense. I suppose the air pressure could add enough force to make the forks clunk on the rebound. Maybe, while I'm waiting for the fork oil, I'll try to devise a suitable "implement of destruction" to try it out.
1968 T100C
Re: forks "topping out" [Re: Jamie Boud] #445291
07/18/12 7:32 pm
07/18/12 7:32 pm
Steve H Offline
Steve H  Offline
Hi Jamie,
I think you put the damper sleeves in upside down. These are what look like spacers that fit between the fork bushes. The manual is not clear on which way up they go but as far as I can remenber the smaller diameter hole goes down. These sleeves stop the topping out by restricting oil flow when the bushes get closer together, ie when the forks are fully extended, but the sleeves only work if they are the correct way up. chances are you did not spot the difference in the hole size and put them in upside down. I am speaking from experience here smile
hope this help
Steve.
Re: forks "topping out" [Re: Jamie Boud] #445302
07/18/12 8:48 pm
07/18/12 8:48 pm
Brooklyn, NY
Brooklyn, NY
Anything is possible, but I never removed the stanchions from the lower fork legs so if the sleeves are upside down, they've been that way for a long time. It was dumb of me not to do a complete teardown and inspect the entire fork while I had them all apart. (Though, I'm always amazed at how much easier these tasks get with each successive try.)
1968 T100C
Re: forks "topping out" [Re: Jamie Boud] #445387
07/19/12 6:06 pm
07/19/12 6:06 pm
Nor Cal
Roadwarrior Offline
Roadwarrior  Offline
Nor Cal
Steve is correct. If they are topping out, the black plastic spacers on the fork stantions are in upside down. If they have not been pulled, your forks are just working better now.
Who are the brain police?
