Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,885 guests, and 584 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,357 mail-order LSR
Topics65,693
Posts634,978
Members10,028
oif t140 oil level help #441728
06/24/12 1:00 pm
06/24/12 1:00 pm
united kingdom
brian begg Offline OP
united kingdom
hi looking for advice on the oil level on my oif t140 .prob a stupid question but want to make sure .i take it the oil level must be up to the mark on the dipstick which is fixed to inside the frame when cold .then when engine is running you should see the oil returning back into frame.i no stupid question but want to make sure cheers ..
Re: oif t140 oil level help [Re: brian begg] #441735
06/24/12 1:45 pm
06/24/12 1:45 pm
Sunny South Carolina, (US)
T140V-Rich Offline
T140V-Rich  Offline
Brian, technically that's correct. Short answer to your question - I fill mine to the bottom of the filler opening. The reason being is when the frames were first produced, there was no concern - legitimate, IMO - about keeping the engine cooled with less oil capacity. I believe the original destination, correct me if I'm incorrect, for the oil filler cap was behind the steering head on the frame. Placing it in front of the seat but off a certain amount of oil capacity. At any rate, the added oil won't blow out seals, etc due to the overflow pipe at the upper portion of the frame. With the summers around here averaging 100F, I like a bit more cooling capacity.
HTH.
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: oif t140 oil level help [Re: T140V-Rich] #441737
06/24/12 2:55 pm
06/24/12 2:55 pm
united kingdom
united kingdom
cheers for that mate .my filler is in front of my seat but be the same idea
Re: oif t140 oil level help [Re: brian begg] #441739
06/24/12 4:01 pm
06/24/12 4:01 pm
T140V-Rich Offline
T140V-Rich  Offline
After reading my reply, I made an error. Nothing catastrophic. But it should have read, "there was SOME concern...." rather than the incorrect "there was no concern...." about cooling, etc.
I'm tinkering with mine now and the level is about a finger's length below the filler plug/oil access in front of the seat. I know I've got extra oil that was put in the primary to drain over, so no worries on it being lower than what I normally ride at. I'll simply check it after a few minutes of running the engine.
Richard
PS. Yes, you should see the oil returning to the tank via a small hole in the "rod" protruding down from the upper portion of the tank. At even low rpms, the flow of that oil should seem like a steady stream. Just turning the engine over, switch off, one kick, the oil should squirt out fairly coinciding with the compression. ie "phomp, phomp" - two squirts, etc (silly exhaust/compression illustration, I know. smile )
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: oif t140 oil level help [Re: T140V-Rich] #441744
06/24/12 4:46 pm
06/24/12 4:46 pm
united kingdom
united kingdom
no worries thanks again
Re: oif t140 oil level help [Re: brian begg] #441748
06/24/12 5:08 pm
06/24/12 5:08 pm
T140V-Rich Offline
T140V-Rich  Offline
Cheers mate. Hope that alleviates any concerns.
Richard
1977 T-140V
1973 T-140V
2011 Bonneville SE
Re: oif t140 oil level help [Re: brian begg] #441957
06/26/12 3:06 am
06/26/12 3:06 am
New England
Snap50 Offline
Snap50  Offline
New England
Think you might regret filling to the bottom of the opening.
When it heats up or pumps a bit of oil out of the sump, and you happen to open the cap, you'll end up with the biggest mess imaginable.
You don't need to ask me how I know; just imagine it.
There are high and low marks on the dipstick for a reason.
