Bob Mitch
Bob Mitch
Biggin Hill Kent England
51 registered members (57nortonmodel77), 273 guests, and 396 spiders.
Gtommy, Stew Dempsey, JoeBrown, Bart223, Duckster
10175 Registered Users
Lannis 102
reverb 89
Stuart 69
koan58 68
L.A.B. 54
554,204 mail-order LSR
Topics66,605
Posts645,495
Members10,175
!970 A65 Primary Drive Side #438931
06/07/12 3:08 am
06/07/12 3:08 am
Oahu Hawaii USA
Roger Gulledge Offline OP
Oahu Hawaii USA
I have been working on my gear box for a broken third gear layshaft dog, at the same time I have been replacing the drive sprocket, rear sprocket and chain with a 530Xring. All completed thanks to Ola.
Today I started on installing the primary drive side, new chain, tensioner, tensioner bolt, cap, oil seal washer. Well I striped it down 8 weeks ago, took pictures and left in place as much as I could. Took pictures that are not doing me much good now.
The parts book shows shim engine sprocket #4 and distance piece engine sprocket #5 going behind the sprocket. The shim fits over the splins and slides up to the bearing, the distance piece is smaller and will only go on the shaft up to the splines. Did they make a mistake, and the shim goes behind the sprocket and the spacer in the front?
Will also be installing an SRM-Pressure Plate Kit. Any tips that might make it go smoothly?
Much Aloha for all the help that I have gotten here
Roger
Roger G
70 Thunderbolt
Re: !970 A65 Primary Drive Side [Re: Roger Gulledge] #438933
06/07/12 3:27 am
06/07/12 3:27 am
Looking at your photo I think the distance piece is already on the shaft. That is not the bearing inside the seal.
The other distance piece that will not slide on could be for under the mainshaft nut in the clutch.
Re: !970 A65 Primary Drive Side [Re: Gordo in Comox] #439130
06/08/12 4:37 am
06/08/12 4:37 am
Oahu Hawaii USA
Oahu Hawaii USA
Thanks Gordo
You were 100% correct...don't know how the distance piece for the mainshaft nut for the clutch got over to the other side.
Roger G
70 Thunderbolt
Page Time: 1.554s Queries: 15 (0.010s) Memory: 0.9951 MB (Peak: 1.1285 MB) Zlib disabled. Server Time: 2018-04-26 13:11:26 UTC
