Triless
Triless
OZ
28 registered members (AML), 198 guests, and 65 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 75
DavidP 72
Triless 71
Rohan 69
btour 66
689,531 mail-order LSR
Topics68,028
Posts661,829
Members10,383
Best way to clean engine cases #304263
03/21/10 9:53 pm
03/21/10 9:53 pm
Arnold1896 Offline OP
Hi All,
Any advice about best way to clean engine case (inside and out).
I do not want to bead blast, as an apprentice early 1970 the work shop had a basis vapor degreaser using a inhibisol fluid(tric).
My velocette case cleaned up immaculately using this method.
What do you use?
Arnold
Re: Best way to clean engine cases [Re: Arnold1896] #304274
03/21/10 10:54 pm
03/21/10 10:54 pm
I've used gasoline, diesel, solvent, brake cleaner, WD-40, semi-caustic [?] store-bought carb cleaner, amongst whatever else over the years....
Now, I just go to a friend's machine shop. He puts the parts into a hot-tank, but it uses a soap and water solution, not the typical hot tank stuff!
Clean and beautiful stuff comes back to me, and it isn't bad for the environment...
Nor is it harmful to good paint.
Recently sent a filthy, oily, gunged up OLD oil tank, that had sticky gunge in the bottom of the tank that I couldn't get out. It's all gone. But the paint on the outside of the tank still shines!
Re: Best way to clean engine cases [Re: Arnold1896] #304275
03/21/10 11:10 pm
03/21/10 11:10 pm
St. Augustine, Florida
tri650cc Offline
tri650cc  Offline
I just did a set for a 650 Bonneville , borrowed a outdoor turkey deep frier . Mixed water with about a quart of simple green boiled each case about an hour pulled them out wire brushed put them back in for another hour rinsed off . Results were excellent.
Re: Best way to clean engine cases [Re: tri650cc] #304282
03/21/10 11:50 pm
03/21/10 11:50 pm
I've been taking them to the local transmission rebuild guy. He puts them in the ultrasonic machine- they get real clean.
Re: Best way to clean engine cases [Re: leon bee] #304288
03/22/10 12:35 am
03/22/10 12:35 am
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
tri650cc
i wondered why the next turkey tasted funny.
i won't lend that item out again.
Re: Best way to clean engine cases [Re: nert] #304297
03/22/10 1:19 am
03/22/10 1:19 am
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
I have been using a really big stock pot on the garage stove similar to what TRI650 mentions , with good results . I have a wire shelf from an old toaster one held a few inches from the bottom so any debris/crud that comes out of the pores will hopefully be trapped and not reenter those tiny spots . Havben't used simple green, gonna try that next time .
FWIW-BONZO
Re: Best way to clean engine cases [Re: leon bee] #304360
03/22/10 2:51 pm
03/22/10 2:51 pm
Why Thank You Leon Bee!
THAT is a solution I never thought of....
I'll have to ask the local tranny shops if any of them have ultrasonic bath cleaners...
Re: Best way to clean engine cases [Re: Rickman] #304373
03/22/10 3:27 pm
03/22/10 3:27 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
Put them in the dishwasher, does an excellent job.
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: Best way to clean engine cases [Re: andrewinpopayan] #304442
03/23/10 1:52 am
03/23/10 1:52 am
Pat Offline
Pat  Offline
Andrew has it right but your wife will kill you! Get some DISHWASHER soap , add it to hot water and soak over night. If you have a barby with a side burner, use a big pot and boil. The aluminum will sparkle, dirty bits will clean with a small wire brush, and it doesn't stink like solvent!
Re: Best way to clean engine cases [Re: Pat] #304505
03/23/10 4:01 pm
03/23/10 4:01 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Has anybody cleaned a case with a bad case of barnacleitis? I'm talking completely white with corrosion. Does dishwasher detergent clean this up with a good boil?
Re: Best way to clean engine cases [Re: hh] #304524
03/23/10 5:48 pm
03/23/10 5:48 pm
On board of ships we used to clean corroded aluminium things on deck (salt corrosion) with a washing powder called Biotex, obtainable at the chinese laundyman, who kept it in stalboald lockel next to steeling geal loom.
I do not know the US or or Canadian equivalent, but Biotex is a biological powder used also for baby diapers.
OMG how far have I sunk? I'm advertising soap... sick
Re: Best way to clean engine cases [Re: hh] #304530
03/23/10 7:05 pm
03/23/10 7:05 pm
dave jones Offline
dave jones  Offline
For that white corrosion maybe some of that acidic alloy wheel cleaner would do it. Hermetite used to do something called Ali- Clean which was for corroded alloy engine cases. Not sure if you can still get it.
On that Discovery DVD where the chap restores a 1970 Bonneville he used some plastic scotchbrite pads on an angle grinder to clean the alloy front brake plate but I don't know if it would give the finish you want.
Re: Best way to clean engine cases [Re: dave jones] #305633
03/30/10 6:31 pm
03/30/10 6:31 pm
Winona, MN
Swan Offline
Swan  Offline
Winona, MN
I use Simple Green, 3M brand synthetic red scrub pad for metal and elbow grease. Summit Pale Ale makes the job enjoyable. The results are very good, no beads to worry about or clean up.
I have considered vapor blasting but cannot justifying paying more to clean something than I paid for the item itself.
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Best way to clean engine cases [Re: Arnold1896] #305675
03/31/10 12:48 am
03/31/10 12:48 am
Stuart Offline
Stuart  Offline
Hi Arnold,
Imho: best is ultrasonic cleaning; second-best is something I found about recently - soda blasting.
Ordinarily, I wouldn't consider any sort of blasting, because particularly sand-cast alloy is relatively soft and you risk embedding blast media which, internally, can then be loosened by the engine oil acting the same way as an ultrasonic cleaner. However, by defintion, the soda dissolves in the water you wash the iem with after blasting.
Re: Best way to clean engine cases [Re: hh] #306324
04/03/10 3:28 pm
04/03/10 3:28 pm
St. Petersburg, Florida
cmessenk Offline
cmessenk  Offline
This is a little bit off the thread topic, but I've found an amazing product that helps your engine cases maintain a mirror-like shine after you get them cleaned up and buffed out. The product is called "Flawless Wax" and is made by Sherwin-Williams.
During my bike's restoration, GP (Born Again Bikes) sent my cases to a professional buffing shop and transformed them into nice shiny bits. I've been keeping that shine with tons of elbow grease mixed with Mothers Aluminum Polish...but after a week or so the tarnish would reappear. With this product, polish the cases with the Mothers polish and then apply a coating of the "Flawless Wax" as a finishing touch. It lays down a final layer a canuba wax and keeps the Mothers shine going for weeks without tarnishing. Here's some photos:
Chip
'72 Combat
Re: Best way to clean engine cases [Re: cmessenk] #308907
04/19/10 9:14 am
04/19/10 9:14 am
Brisbane, Australia
51Trump Offline
51Trump  Offline
Brisbane, Australia
Mate you got me on the wax, think i'll give it a go too.
51 Speed Twin
47 Douglas T35
Re: Best way to clean engine cases [Re: 51Trump] #309033
04/20/10 1:36 am
04/20/10 1:36 am
JubeePrince Offline
JubeePrince  Offline
I just used soda blasting (baking soda) on my cylinder head and rocker boxes....Cleans without destroying the patina and cast surface on the aluminum, no beads, grit, etc to worry about cleaning out afterwards AND it's environmentally friendly! (except for the gas/coal/oil that gets used to run the blaster! laugh )
There's a thread on the Triumph Forum called "Cost to spot face inner head bolt surfaces?", you can see the results there....
Re: Best way to clean engine cases [Re: JubeePrince] #309691
04/24/10 3:03 pm
04/24/10 3:03 pm
Carmel, CA
Doc_dup1 Offline
Doc_dup1  Offline
Carmel, CA
Can you use the soda medium in standard blast cabinet? If so, is there a good source for the stuff?
Doc
Doc
Mostly Triumphs with a few BSA's a Norton, and two BMW's
Re: Best way to clean engine cases [Re: Doc_dup1] #310649
04/30/10 12:20 am
04/30/10 12:20 am
JubeePrince Offline
JubeePrince  Offline
Doc -
I'm not sure about the blast cabinet part...my guy did my stuff outside with a portable rig....his shop is near the Cheasapeake Bay and he does ALOT of boats with the stuff....
Google "Soda Blasting". You'll be reading for hours! bigt
Re: Best way to clean engine cases [Re: Arnold1896] #433538
05/06/12 3:28 am
05/06/12 3:28 am
Los Angeles, CA
Mike Cornwall Offline
Los Angeles, CA
Question: Does boiling the cases mess up the bushes?
Keith Moore used to tell me to boil my Triumph cases, but I'm doing this A65 now after a few years off the habit and I just dont want to ruin the bronze bits. Sure wish I could call Keith, I just about cried when I heard.
1972 Tiger 650
1978 Bonneville 750
1968 Victor 441
Re: Best way to clean engine cases [Re: ] #437609
05/31/12 7:56 pm
05/31/12 7:56 pm
Trenton, New Jersey
royaloilfield Offline
Trenton, New Jersey
So, is the dishwasher bad or good? Cascade? regular dish soap? My wife is away so I'd like to try this.
Brian
