BRIT-FE
BRIT-FE
Lorton, VA
188 registered members (79T140E), 2,142 guests, and 564 spiders.
koan58 90
Lannis 83
505,477 mail-order LSR
Topics66,060
Posts639,381
79 T140D Tach/Rev counter drive Threaded plug #434176
05/09/12 10:10 pm
05/09/12 10:10 pm
Houston Texas USA
thackero Offline OP
thackero  Offline OP
Houston Texas USA
I am assembling the tach rev counter drive on my t 140D 1979 and I am curious why there are no threads in the bottom of the drive to accomodate a threaded plug as illustrated in the parts manual. Does anyone know why my unit has no threads ? Were the original drives fitted with a pressed in plug ? If so does anyone have a picture and part number of the plug. without the plug the drive to the cable just falls out
1961 BSA A10 Spitfire
1964 Triumph TR6R Trophy
1975 Norton Commando Mark III E/S
2007 Triumph Speed Triple
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: thackero] #434180
05/09/12 10:19 pm
05/09/12 10:19 pm
Scotland, UK
jimmymckenna Online content
jimmymckenna  Online Content
Scotland, UK
It should have a thread, well at least the 2 T140Ds I have owned had threads. Heres a few pics of mine, including running a tap through the c/casing to freshen up the l/h thread
The plug in pic 3 has a thread in it
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: jimmymckenna] #434183
05/09/12 10:46 pm
05/09/12 10:46 pm
Stuart Online content
Stuart  Online Content
Hi Jimmy,
You still looking for information on the T160?
Apologies for the quick hijack. blush
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: thackero] #434189
05/09/12 10:59 pm
05/09/12 10:59 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
The T140 71-7011 tacho drive had a 71-2481 "Welch washer" and 71-7012 "thrust cap" ('77-'78) or 71-2481 "spacer" (71-2475 drive '73-'76) .
http://www.classicbike.biz/Triumph/Parts/Parts.htm
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: L.A.B.] #434228
05/10/12 2:57 am
05/10/12 2:57 am
Houston Texas USA
thackero Offline OP
thackero  Offline OP
Houston Texas USA
It would appear that the parts that I am missing from my assembly are the Thrust cap 71-7012 and the sealing washer 70-7351. These some how retain the drive for the cable. The drive from the crankcase to the tach housing is complete and operational. I am intersted to know how this thrust cap is held in the tach body. Any ideas ?
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: Stuart] #434241
05/10/12 6:59 am
05/10/12 6:59 am
Scotland, UK
Scotland, UK
Originally Posted By: Stuart
Hi Jimmy,
Stuart
Yes, I should be in a position to get serious round about June/July
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: jimmymckenna] #434244
05/10/12 7:14 am
05/10/12 7:14 am
Scotland, UK
Scotland, UK
71-7143 Driving gear end plug
60-3355 O Ring.......
These are the part numbers listed for the 1979 T140, and the end plug should screw in. It may be you have an earlier tacho gearbox fitted showing just a plug and welch washer.
Heres my question...What is a welch washer. Is it just a form of circlip or what..
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: jimmymckenna] #434251
05/10/12 8:43 am
05/10/12 8:43 am
Norfolk, UK
Norfolk, UK
http://www.hubbardspring.com/install_reco.php?cid=45
Re: 79 T140D Tach/Rev counter drive Threaded plug [Re: thackero] #435370
05/16/12 11:00 pm
05/16/12 11:00 pm
Columbus, Ohio, 1978 T140E
tomterrific Offline
tomterrific  Offline
The thrust washer can be substituted by two pennys. The Welsh plug can be substituted by using a nickle.
On teh way to Mid-Ohio my T140 tach drive fell apart. I noticed the tach stopped working and then I noticed oil was drooling out of my Triumph. Oh woe is me! I figured rather than turn around I would ride to Mid-O and find expert help. I did. Fixed it on teh side of the camp road and until now I forgot about the fix.
I went looking for the proper parts, when I found them I told the vendor how I fixed my bike. He said they use two pennys and a nickle at the shop because it works better. The real parts went back in his bin.
The nut holding teh drive is reverse thresd.
TomG
Page Time: 0.174s Queries: 15 (0.006s) Memory: 1.0524 MB (Peak: 1.2414 MB) Zlib disabled. Server Time: 2018-02-25 02:03:43 UTC
