The Bonneville Shop
MotorEddy
MotorEddy
Lancashire, UK
46 registered members (Al Eckstadt), 311 guests, and 394 spiders.
JD8, John Rowley, Zoot, sal pisciotta, Shawn G
10529 Registered Users
franko 89
Lannis 82
NickL 72
785,984 mail-order LSR
Topics69,227
Posts674,397
Members10,529
Gas not coming out of tickler? #433916
05/08/12 3:44 pm
05/08/12 3:44 pm
Vermont, USA
Cort C. Offline OP
Cort C.  Offline OP
Vermont, USA
recently serviced my single AMAL 930 from '73 TR7RV, flattened the bowl and added new upgraded float and needle. Bike runs perfect but when I pushed tickler down no gas came out, kept holding it down and gas eventually came out the intake of carb.? There is a slot in the tickler when looking at it with bowl removed, could the orientation of this cause the problem?
'73 Triumph TR7RV
'77 Suzuki GS750
Re: Gas not coming out of tickler? [Re: Cort C.] #433917
05/08/12 3:53 pm
05/08/12 3:53 pm
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
Probably when you changed the float you changed the height of the floast relative to the tickler. Remove the float bowl and press doown on the tickler button. Using a pair of side cutters, grasp the roll pin (the part that pushes on the float) near the carb body and *gently* lever it away from the tickler button a bit. This will lengthen the reach of the roll pin realative to the float.
Use the flat side of the side cutters as a fulcrum against the carb body to ease out the roll pin. Lever it gently, or you'll end up pulling the roll pin out of the tickler button sleeve and the tickler button and spring will launch across the garage!
Re: Gas not coming out of tickler? [Re: Cort C.] #433920
05/08/12 4:08 pm
05/08/12 4:08 pm
Vermont, USA
Cort C. Offline OP
Cort C.  Offline OP
Vermont, USA
Thanks, so even though the tickler is flooding out the carb since gas will eventually leak from intake if I hold it down long enough, it's still not long enough to go through tickler itself?
'73 Triumph TR7RV
'77 Suzuki GS750
Re: Gas not coming out of tickler? [Re: Cort C.] #433932
05/08/12 4:57 pm
05/08/12 4:57 pm
I screwed a self tapper into the bottom of the roll pin, screw in or out to adjust.
Re: Gas not coming out of tickler? [Re: Cort C.] #433941
05/08/12 5:52 pm
05/08/12 5:52 pm
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
Cort, didn't see that other part of your post. If you have gas flooding the bowl and carb, then you should be good to go. In theory, the further the roll pin sticks out of the bottom of the carb when tickler is depressed, the quicker the bowl should flood with fuel.
As to why the fuel is not exiting the tickler assembly, you must have the only dry-tickle Concentric in existence! crazy
Re: Gas not coming out of tickler? [Re: Cort C.] #433969
05/08/12 7:31 pm
05/08/12 7:31 pm
Massachusetts, U.S.A.
btour Offline
btour  Offline
I have a "dry" tickler also. I do not know what makes that way. Tight fit?
Re: Gas not coming out of tickler? [Re: btour] #434018
05/09/12 12:32 am
05/09/12 12:32 am
New Zealand
Excalibur Online content
Excalibur  Online Content
New Zealand
It's been a while, but I seem to recall inserting a slim pin punch into the roll pin. Then with a short sharp tap from small hammer, that was enough to move the tickler button. A millimeter at a time or so, till you get the required float deflection. This would have been with the early small steel tickler button though I'm assuming it would do for the later larger alloy buttons as well.
The whole thing is quite sensitive as to position and with any adjustment to float level, the tickler setting could well need adjusting to suit.
Hope this helps.
Re: Gas not coming out of tickler? [Re: Cort C.] #434048
05/09/12 6:30 am
05/09/12 6:30 am
Devonport Tasmania
TJD Offline
TJD  Offline
Devonport Tasmania
You didn't put the floatbowl back on the wrong way round after the service did you?
