halmc
halmc
Tallahassee, FL
21 registered members (Alan_nc), 168 guests, and 100 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
DavidP 72
btour 66
690,426 mail-order LSR
Topics68,045
Posts662,084
Members10,387
wrist pin reamer for 650 bonneville #433411
05/05/12 4:00 am
05/05/12 4:00 am
vancouver,b.c.
black13 Offline OP
black13  Offline OP
vancouver,b.c.
can some one tell me the size of reamer to use for new bushing at wrist pin on triumph 650 bonneville ...seems i forgot to check them with my new pistons ...now i see i have to replace them on one side as there is a bit of play .....oops should have done it when i had them on the bench ! thank you ....i did my cam bushes fine and they are nice ! ...so i know i can ream the wrist pins ...thank you again for all the help advice , general slander !
"HOUSTON, WE HAVE A PROBLEM"
Re: wrist pin reamer for 650 bonneville [Re: black13] #433462
05/05/12 1:51 pm
05/05/12 1:51 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Use an adjustable reamer, not a fixed reamer, so you can get the right fit. The nominal bushing IDs are in fractions of an inch.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: wrist pin reamer for 650 bonneville [Re: black13] #433700
05/07/12 8:24 am
05/07/12 8:24 am
angeles city, rp
jaycee Offline
jaycee  Offline
angeles city, rp
i know the factory service manual calls for a light push for correct fit,zero clearance on an inaccurate ream fit.why not have them honed for a more accurate, truer,fit? just my two cents worth.
Re: wrist pin reamer for 650 bonneville [Re: black13] #433757
05/07/12 5:16 pm
05/07/12 5:16 pm
vancouver,b.c.
black13 Offline OP
black13  Offline OP
vancouver,b.c.
Ya i was but i put the engine together already!
Re: wrist pin reamer for 650 bonneville [Re: black13] #433793
05/07/12 8:17 pm
05/07/12 8:17 pm
John Healy Offline
John Healy  Offline
The pin fit is only half the job. The other part is making sure that the new bushing holds the pin parallel with the big end. Even honing the bushing does not insure that the bushing is finished to size and square.
If the piston is cocked side to side, oil control can be an issue, and it puts undue stress on the rod and rod bearing.
Re: wrist pin reamer for 650 bonneville [Re: black13] #433878
05/08/12 8:17 am
05/08/12 8:17 am
dave jones Offline
dave jones  Offline
I had to replace a small end bush on my 3TA and just followed the manual, not knowing that it was better to have them line bored when stripped. Anyway, I took the whole bottom end down to the garage and explained what had to be done. You have to line ream them using the other small end as a guide. It was ok and the bike ran fine. I checked the pistons after a fair bit of running and they were fine. Was only a 3TA though. As a teen I wouldn't have relished stripping the whole bottom end for one small end bush! Line boring is a safer bet.
