Kerry W
Kerry W
Middle East,
40 registered members (Andy Higham), 305 guests, and 401 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 99
Stuart 83
reverb 82
NickL 73
koan58 56
549,701 mail-order LSR
Topics66,547
Posts645,114
Members10,170
Which alternator wires to use? #432692
05/01/12 2:08 pm
05/01/12 2:08 pm
Jaffrey, NH, USA
Peter Quick Offline OP
Jaffrey, NH, USA
I picked up this 3 wire alternator and wonder which two wires I combine to feed into my 12 volt Podtronics regulator. Or does it matter which two I combine?
Peter
Re: Which alternator wires to use? [Re: Peter Quick] #432695
05/01/12 2:23 pm
05/01/12 2:23 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
The mid green and dark green are the two wires that need to be connected together.
Re: Which alternator wires to use? [Re: Peter Quick] #432701
05/01/12 2:44 pm
05/01/12 2:44 pm
Jaffrey, NH, USA
Jaffrey, NH, USA
Many thanks!
Peter
Re: Which alternator wires to use? [Re: Peter Quick] #432778
05/01/12 8:27 pm
05/01/12 8:27 pm
Jaffrey, NH, USA
Jaffrey, NH, USA
Allan,
I happen to have a handful of 2 wire alternators kicking around that would have done the job nicely. Perhaps I'm doing it to amuse myself. I like the look of those coils and copper. Are you saying that the result in joining two wires is inferior to a 2 wire alternator? Or are you implying I'm a fool with my money? If so it looks like I'm in good company here.
Cheers!
Peter
With a barn full of BSA's
Re: Which alternator wires to use? [Re: Peter Quick] #432806
05/01/12 11:17 pm
05/01/12 11:17 pm
Norfolk, UK
Norfolk, UK
It's unlikely that RM(15?,18?) stator will produce as much output as a two wire RM21, RM23.
Re: Which alternator wires to use? [Re: Peter Quick] #432813
05/02/12 12:04 am
05/02/12 12:04 am
Magnetoman Online content
Magnetoman  Online Content
I picked up this 3 wire alternator ...
I like the old style (unpotted coils) alternators like you have, because the exposed coils make it possible to resolder a connection if it fails. Unfortunately, the lack of potting means it is more likely to fail.
The problem is the AC current set up in each coil by the rotor also exerts a small AC force on the wires. This isn't (necessarily) a problem if the windings are completely tight, so individual windings cannot move with respect to each other, but it is a problem if a couple of the wires are even a little bit loose. The force reverses six times each revolution of the rotor, so even only 0.001" of looseness lets the wires rub that much against each other many hundreds of times a second. If this happens, eventually, the ~0.002"-thick insulation rubs through. If an electrical problem does develop, internal chafing within the coils isn't necessarily the most likely source of it. Wherever connecting wires are close to the stator core there is the potential for shorting to earth.
I lost one alternator to exactly this problem. I subsequently discovered a BSA (U.S.) racing bulletin issued in the early 1960s advising racers to dip their stators in glyptol to make them more reliable. Anyway, it would be ironic if you installed a new electronic voltage regulator with the goal of achieving greater reliability from your electrical system, but your old unpotted alternator let you down...
Re: Which alternator wires to use? [Re: Peter Quick] #432847
05/02/12 2:09 am
05/02/12 2:09 am
Jaffrey, NH, USA
Jaffrey, NH, USA
The alternator is new. I have one like it on my 1959 B33 and another on a 1965 BSA SS80. Both are working fine so I know they can last a long time. I'll take my chances. Also I'm using a Podtronics simply because I have one and don't have an old style rectifier. This will end up on a 1960 B40 that probably won't get all that many night miles on it. It can't be worse than the 6 volt system that the bike came with.
Peter
Re: Which alternator wires to use? [Re: ] #432895
05/02/12 10:59 am
05/02/12 10:59 am
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
Originally Posted By: Allan Gill
No one is more of a fool at spending his money than I, however as I have been beaten to the pinch in writing this, but a later 2 wire alternator would give you a better output.
Does anyone know what the output of the old unincapsulated units???? Dick
Re: Which alternator wires to use? [Re: Peter Quick] #432915
05/02/12 1:28 pm
05/02/12 1:28 pm
The one on my Royal Star lasted for forty years...should be good enough I think.
Re: Which alternator wires to use? [Re: Alex] #432931
05/02/12 3:46 pm
05/02/12 3:46 pm
The fact both BSA and Triumph issued issued service bulletins about these armatures, and discontinued the bare wire version, suggests that it was a problem with enough of them that it was an issue at the time. However, age isn't what brought on the failures (in the percentage of cases where there were failures), miles did, so the fact yours still works after 40 years (as do many others) isn't evidence they are reliable.
I couldn't find the BSA bulletin this morning, but a Johnson Motors Service Note from 1963, number 17-63 says "For competition purposes, we have found it advisable to dip the stator in heavy red protective sealer... Dipping of the stator in this manner protects the windings against vibrations and short circuits from metal particles in the primary case."
The OP subsequently said that he will be using a bare wire stator because he has it on hand, not because he is trying for higher reliability. That's fine, and there's a very good chance he never will have a problem in the way he intends to use that bike. However, my suggestion is that if anyone were interested in reducing the probability of failure from the present fairly low number to something even lower, they should use an encapsulator stator for the reasons in the JoMo bulletin and in my earlier post.
Re: Which alternator wires to use? [Re: Peter Quick] #432934
05/02/12 4:18 pm
05/02/12 4:18 pm
I don't think anybody is arguing that the potted stators aren't more rugged. But I think peter will be just fine with alternator, particularly if it isn't going to be on his daily ride or road racer. I'm just trying to counter the notion that EVERY part has to be upgraded ASAP on our old machines. Yea...stuff fails on occasion...and we deal with it, Peter, I think knows that and is willing to deal with it.
Incidentally, the one that eventually did fail on my Royal Star (I have no idea how many miles it had on it, but it was a lot) failed because the insulation paper got brittle and started to disintegrate. Once it stopped holding the coils in place, they started to rub through the insulation and charging gradually got weaker until it couldn't support the halogen headlamp and Boyer in traffic any more. A nice, gradual decline...I like failures you can procrastinate on...
Re: Which alternator wires to use? [Re: Alex] #432940
05/02/12 4:38 pm
05/02/12 4:38 pm
I completely agree. This is why it usually is important to know an intended application in order to make a good recommendation. Preparing a bike to make a cross-country ride suggests a solution that increases reliability, while preparing a bike that will be used around town a small number of weekends each year suggests making do with existing components.
The one that failed on me was because I deliberately used a bare wire alternator so that I could repair it if it failed. I put several thousand miles on the bike before the stator failed, but when it did it was a big headache because of where it happened. I should have used the encapsulated stator the first time...
Old tube electronics were ideal for giving you plenty of warning as they very slowly got worse. This is also why I prefer points to electronic ignitions (except for my Trident, where dealing with three sets of points is just too much to contemplate).
Re: Which alternator wires to use? [Re: Peter Quick] #432942
05/02/12 4:43 pm
05/02/12 4:43 pm
kommando Offline
kommando  Offline
Seems alternator (or is that generator) threads are becoming like oil threads and best avoided wink
Re: Which alternator wires to use? [Re: kommando] #432955
05/02/12 5:35 pm
05/02/12 5:35 pm
Originally Posted By: kommando
Seems alternator (or is that generator) threads are becoming like oil threads and best avoided)
Unlike oil threads, where everybody gets to have an opinion, alternator (and generator) posts either are based on the laws of physics and on commonly used terminology, or they're not. This current thread has been completely civil and based on facts. No one has even objected when opinions were offered on under what circumstances one stator might be more reasonbly used than another. But, that said, it doesn't change the fact that Castrol is indisputabily better than...
Re: Which alternator wires to use? [Re: kommando] #432956
05/02/12 6:07 pm
05/02/12 6:07 pm
WHUT?
I'm getting this tattooed on my knuckeles:
NGK4 EVR!
Re: Which alternator wires to use? [Re: ] #432969
05/02/12 7:29 pm
05/02/12 7:29 pm
Stuart Offline
Stuart  Offline
Very definitely, but only because the Lucas 3-wire single-phase alternators pre-date the 2-wire single-phase alternators, each succeeding 'generation' developed more power than the previous ones, and the 3-wire alternator you have is an early one.
Afaict, Lucas seems to have produced two versions of each 'generation' of alternator - a 'high-power' version for bikes presumably intended for the police/military/government customers with extra electrical consumers (e.g. radio, flashing lights, two-tone horns) and a 'low-power' version for Joe Public's bikes.
The most powerful 3-wire single-phase was the 'high-power' RM20, supplied from the early to the late 1960's; it was rated the same (10.5A @ 5,000 rpm) as the 'low-power' RM21 2-wire single-phase supplied from the late 1960's 'til 1978.
However, from the cable colours, you appear to have a late 1950's RM13 or RM15, which pre-dates the RM20 and related 'low-power' RM19. Unfortunately, I don't have an rpm vs. Amps curve for either but Triumph's "Instruction manual No.4" that covers the early unit 350 and 500 that had these alternators states, "The alternator is designed for use with headlamp bulbs not exceeding 30 watts (sic) rating".
apparently when connected for 12v these units will give you more power
If, by "power" you mean Watts, obviously; if you're doubling the regulated Voltage, as long as you don't halve the Amps, by definition, you're going to have more Watts.
Page Time: 0.072s Queries: 15 (0.005s) Memory: 1.1174 MB (Peak: 1.3758 MB) Zlib disabled. Server Time: 2018-04-20 20:00:31 UTC
