Transgarp
Transgarp
Quebec, Canada
190 registered members (1xfatboy), 2,118 guests, and 549 spiders.
koan58 90
Lannis 84
505,385 mail-order LSR
Topics66,055
Posts639,346
A65 Case joining paste/sealer #430706
04/20/12 12:32 pm
04/20/12 12:32 pm
Steve S Offline OP
Steve S  Offline OP
Have had a persistent oil leak from around the sump plate and a couple of other jobs needed doing so i pulled the engine out and split the cases in the dim distant past this engine has throw a rod and the case has been welded and on examination its distorted near the sump plate I used Loctite Gasket Eliminator 515 but to cure needs no air I could see the case don't pull tougher tight can get 14th feeler in it I don't want to use silicone sealer as petrol attacks it.
So what you recommendations guys ????
Re: A65 Case joining paste/sealer [Re: Steve S] #430713
04/20/12 1:09 pm
04/20/12 1:09 pm
I use Loctite 518, but looking at the data sheet there's not much difference between that and 515. They say it will fill a gap up to 0.025 mm. That's .010" and that's a pretty good gap, but you have to wait at least 72 hours to let it cure at that thickness.
Re: A65 Case joining paste/sealer [Re: Steve S] #430727
04/20/12 2:07 pm
04/20/12 2:07 pm
SE Wisconsin
Squariel Offline
Squariel  Offline
SE Wisconsin
Alex, you meant 0.25mm, right?
58 & 59 Ariel Sq4
58 Super Rocket
59 Gold Star
66 Bantam Silver
66 & 67 Victor Enduro
68 Starfire
69 Thunderbolt
70 Royal Star
67 Matchless G80CS & G15
65 Norton N15CS
49 Sunbeam S7 Deluxe
Re: A65 Case joining paste/sealer [Re: Squariel] #430750
04/20/12 3:30 pm
04/20/12 3:30 pm
Yes, sorry...decimal wandered over. Good catch.
Re: A65 Case joining paste/sealer [Re: Steve S] #430825
04/20/12 11:52 pm
04/20/12 11:52 pm
Mark Parker Online content
Mark Parker  Online Content
There is silicon and silicon, 3bond supersealer is very good, its grey. Toyota use a black seal packing to seal sumps with no gasket and various other types of silicon based stuff for G/boxes etc. If these products had been available I'm sure BSA would have used them. I don't use many gaskets on my BSA and it seals better.
If you have it apart why not build up the low area with JB weld then use a file to true it up.
Page Time: 0.310s Queries: 15 (0.014s) Memory: 1.0163 MB (Peak: 1.1669 MB) Zlib disabled. Server Time: 2018-02-24 22:11:14 UTC
