beezageezauk
beezageezauk
North East England
44 registered members (Andrew Dunham), 281 guests, and 142 spiders.
10381 Registered Users
Mori55 96
NickL 91
Stuart 86
DavidP 78
Triless 71
reverb 69
Rohan 64
688,586 mail-order LSR
Topics68,012
Posts661,601
Members10,381
Kick start keeps jamming #429808
04/15/12 1:09 pm
04/15/12 1:09 pm
Cleveland, OH
TheInvisibleCity Offline OP
Cleveland, OH
About every 5 or so kicks on my A65, the teeth on the kick start spindle doesn't mesh quite right with the pinion on the mainshaft and everything gets all jammed up. Seems to be the last tooth on the spindle because it won't jam if I don't let it return all the way, but that is almost impossible to regulate unless I'm really thinking hard about it.
I have had it apart and couldn't really see anything wrong with it. This bike is a bitsa, so I'm wondering if the spindle and pinion are slightly different for different years and maybe I have a pair that doesn't like each other? Or is there something else that could be somehow catching up and I'm just missing it? The motor is a '68.
'69 A65T
'66 A65T
Late 60's Lightning Bitsa
Re: Kick start keeps jamming [Re: TheInvisibleCity] #429820
04/15/12 3:01 pm
04/15/12 3:01 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
This not uncommon on these 40+ yr old bikes, in my opinion anyway. I have experimented with "fixes", which is a pain, because you have to assemble/dis-assemble to see if that works each time..... Anyhow, AND I WILL NOT PROMISE IT'S THE ANSWER, I did have some luck just grinding off the 1st tooth on the kicker shaft. It seems like that one gets flattened, and is the start of the jamming. The gear teeth on the trans get flat too, so try to find a better one if possible. My $.02.... KC
Oops,.. add 1 Sporty
Re: Kick start keeps jamming [Re: KC in S.B.] #429899
04/15/12 9:05 pm
04/15/12 9:05 pm
Originally Posted By: KC in S.B.
I did have some luck just grinding off the 1st tooth on the kicker shaft. KC
Oh, you mean make the thing like a Triumph kicker quadrant? What an idea!
The same thing happens with mine, just a part of the BSA, "charm."
72 T150V yet to be named
Re: Kick start keeps jamming [Re: TheInvisibleCity] #430134
04/16/12 10:39 pm
04/16/12 10:39 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
This has pretty much been an issue with A65s from day one. Ive heard all sorts of theories including it was a tooling problem that never got addressed and the gear center geometry didnt match up properly (wouldnt surprise me that much)
My personal opinion is that the gear modual (or what ever the technical term is Ive forgotten) is not sufficently course to prevent the crests of the teeth interfeering in some positions ie the crests lock rather than mesh properly.
Dont know the soulution apart from constant new bits ....Ive tried relieving the first tooth or 2 on the quadrant ...didnt make any diffrence,....its always been an issue .....the pre unit kick starts are much heavier and never seem to give a problem....just BSA cost cutting probably.
Im surprised there havent been more comments and theories on this topic
Re: Kick start keeps jamming [Re: Ignoramus] #430157
04/17/12 1:09 am
04/17/12 1:09 am
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
the kicker on my A65 has never jammed...the one on my T120V takes 'spells' and sometimes will do it frequently but has not done so for the last couple of months ...when it does, i just cuss, put it in gear and rock the bike, and then it is free.....in other words, live with it.
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
Re: Kick start keeps jamming [Re: TheInvisibleCity] #430161
04/17/12 1:26 am
04/17/12 1:26 am
Mark Z Offline
Mark Z  Offline
This MIGHT be worth looking into... Coupla things: 1. You said it doesn't jam if you let it return all the way - weak return spring?
2. There's supposed to be a stop threaded into the inner timing cover; I've seen them missing altogether. Oh yeah, the kickstart quadrant still stops, by jamming against the timing cover!
I've had 'em jam and not jam. When they jammed, something wasn't right. Take another look.
Re: Kick start keeps jamming [Re: TheInvisibleCity] #430167
04/17/12 2:24 am
04/17/12 2:24 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Just from my observations, I would agree with Ignoramus. Mine's always done that and I just pull in the clutch lever and tap on the kickstart lightly with my foot until it frees up.
Josh
Re: Kick start keeps jamming [Re: TheInvisibleCity] #430199
04/17/12 10:30 am
04/17/12 10:30 am
gavin eisler Online content
gavin eisler  Online Content
IME "you get that with them Sir" its not helped by wear.
