42 registered members (Alan_nc),
262
guests, and 236
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,576
Posts645,450
Members10,173
Most Online3,995 Feb 13th, 2017
1961 5TA: 12-volt, electronic ignition options?
#424755
03/17/12 10:16 pm
03/17/12 10:16 pm
cattledogkeeper
I'm looking for 12-volt, electronic ignition options for a '61 Triumph 5TA that has the original distributor type ignition system. My preference is for a system that is self-generating such that I can substitute a capacitor for the battery - - - I have a lot of vintage bikes and I try to avoid batteries on everything but the electric start bikes. I'm in the U.S. so MOT inspections don't apply, and the bike won't be ridden at night. But if no battery-less plug-and-play solution exists, having a battery is okay. Electrex offers the STK-012 and STK 012D kits: Link to Electrex Kits And the Kirby Rowbotham Mark-2 and Mark-8 kits are options as well: Link to Kirby Rowbotham Kits Neither Boyer nor Pazon offer kits for the distributor type bikes. I am interested in hearing comments from folks who have experience with either the Electrex or Kirby Rowbotham kits.
Re: 1961 5TA: 12-volt, electronic ignition options?
[Re: cattledogkeeper]
#424764
03/17/12 11:12 pm
03/17/12 11:12 pm
Posts: 665 Sunny Sussex, UK
tbird649
Sunny Sussex, UK
I have a 56 Thunderbird with Kirby Rowbotham fitted Pazon EI in the distributor. I run a Vreg regulator with a capacitor fitted. This runs the bike fine, but as I have 55/60 watt headlight I need a small (7AHr) battery, or it dies at tickover. With the standard 35watt bulb its OK. My other bike, more relevant to your post, is a 61 T100A, with 18D2 distributor. I got the EI conversion from Al Osbourne, www.aoservices.co.uk . It is a Boyer MkIV, fitted into the distributor on a backplate, there is a bit of machining to do, but nothing too complicated, which I run on a Boyer Powerbox. My 500 is an off roader, used for Long Distance trials, I have a 35 watt headlight, 5 watt rear light, small horn, brake light. It all runs absolutely fine with no battery. The only thing you have to remember, is to make sure the lights are switched off before starting, but you can get a Boyer Powerbox which only gives power to the lighting circuit once the alternator is producing a certain voltage. AO services website is not the most modern, but if you phone Al, he is very knowledgable, and helpful. Hope this is of use.
#424870
03/18/12 1:26 pm
03/18/12 1:26 pm
tbird649
Sunny Sussex, UK
When I was looking to fit EI to the Thunderbird, Kirby Rowbotham was the only option I found, in fact he probably still is, as I dont know if Al Osbourne does a kit for a DKX2 distributor. I had to send the distributor away to be machined, and have the EI fitted, this took about 4 weeks, a bit longer than estimated (often the case!) When I did my T100A, last year, I found the Al Osbourne option on the 18D2 distributor, and when I spoke to him, he said he would machine the back plate to what in his experience was about right, it fitted perfectly, so I didnt have to send parts away, and then await their return. Another thing, he advertises the mod as a kit, including coils etc, I didnt require coils as I wanted one double ended coil to save space on my off roader, this wasnt any problem, he just sold me the bits I needed.
#424871
03/18/12 1:29 pm
03/18/12 1:29 pm
tbird649
Sunny Sussex, UK
Sorry, just read the second bit. I am running standard alternators and rotors on both bikes.
#424925
03/18/12 6:19 pm
03/18/12 6:19 pm
tbird649
Sunny Sussex, UK
As far as I know, it will only produce the higher output at higher revs, certainly higher than tickover. but as with my T100A, its no problem with a 35watt headlight bulb. If you do want better lights, you can get Halogen 35 watt bulbs, and LED tail/brake lights, in - and + earth. www.norbsa02.freeuk.com
[Re: leon bee]
#425307
03/20/12 6:23 pm
03/20/12 6:23 pm
cattledogkeeper
I didn't want to hijack the thread, but I'm fascinated by that Electrex setup for Tri/BSA- the alternator replacement CDI deal. Anybody here got one of those? Maybe best to start a new thread since this one is focused on electronic ignition options for the older distributor type ignition systems.
#429161
04/11/12 4:35 pm
04/11/12 4:35 pm
tbird649
Sunny Sussex, UK
Looks good, I will be interested to hear how it performs. The only downside I can see, is it only puts out 90 watts, as opposed to 120 for the standard single phase set up.
