Buckshot1
Buckshot1
Diamond Springs, Kalifornia
39 registered members (Al Eckstadt), 325 guests, and 361 spiders.
10419 Registered Users
btour 88
reverb 75
Triless 75
711,216 mail-order LSR
Topics68,310
Posts665,061
Members10,419
Page 2 of 2 1 2
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #424995
03/18/12 10:41 pm
03/18/12 10:41 pm
gavin eisler Online content
gavin eisler  Online Content
That looks like acceptable wear on the kickstart spindle and Ive seen worse cotter pins. The pin looks like its been recycled , the face having been dressed by a bastard file. The taper should not extend to the end of the pin shaft.
If the kickstart was indeed spinning on the spindle , when the lever returned it would be way off the starting position, is this the case?
I used to source cotter pins from cycle , /pushbike shops, older bikes used these to secure pedals to the crank spindle, there are more than one size, if you take your old pin to and old school cycle shop they may have something suitable.
kommando has an excellent plan , I didnt know blank pins were available
One way to help prevent this wear is to drive home the cotter pin with a good drift before tightening the nut, after a week or so of use, drift again and retighten.
other primitive dodges I have used to get more life out of cheese like cotter pins is to case harden them by heating to cherry red and plunging into a bowl of sugar.
Re: 71 BSA Thunderbolt kick start [Re: ] #425010
03/19/12 12:34 am
03/19/12 12:34 am
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
The other possibillity is that this might be a design feature.
Every now and then I go to kick the Thunderbolt (or the Firebird) and it feels like it's catch tooth on tooth (i.e. it won't kick). So I rock the bike forward a bit against the 1st gear then back to neutral and WALLA it kicks. Save a bit o wear on the spindle cotter bits kicking it when it doesn't want to. Mind you it is not slipping though....
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425056
03/19/12 10:46 am
03/19/12 10:46 am
kommando Offline
kommando  Offline
All you need to know about cotters and more
http://sheldonbrown.com/cotters.html
I bought some fully round cotters from Roy Pellett but he is currently not selling.
From memory Triumph cotters have a deeper flat on the cotter and do not grip properly when used on a BSA as the nut uses the full length before it is fully tight which looks to be the problem here.
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425059
03/19/12 11:34 am
03/19/12 11:34 am
Norway
Ola Offline
Ola  Offline
Norway
If you have the pre 71 quadrant, and the post 71 kicker, I think you may end up like you have.
http://www.britbike.com/forums/ubbthread...3556#Post413556
Best regards
(Doug Hele, 1919 - 2001)
Re: 71 BSA Thunderbolt kick start [Re: ] #425089
03/19/12 3:25 pm
03/19/12 3:25 pm
Boulder, Co, United States
sam_tots Offline OP
sam_tots  Offline OP
When you say pull the left side engine cover off and kick it over, if the pressure plate turns but chain does not than the clutch is slipping?
SAm
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425093
03/19/12 3:40 pm
03/19/12 3:40 pm
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Yes.
Josh
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425824
03/23/12 5:36 pm
03/23/12 5:36 pm
sam_tots Offline OP
sam_tots  Offline OP
Update: Just ran through the clutch test mentioned above with the side cover off and the systems are ok.
Sam
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425828
03/23/12 5:45 pm
03/23/12 5:45 pm
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Have you adjusted the clutch rod as per gavin's post?
Josh
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #425834
03/23/12 6:24 pm
03/23/12 6:24 pm
So, presumably the kicker assembly is reassembled and AOk?
with the primary cover removed and clutch disengaged check that there is no wobble in the pressure plate when the motor is kicked over, this is corrected by adjusting clutch spring tension so that the plate withdraws evenly.
There is a slim possibility that the woodruff key on the clutch centre hub taper has failed/sheared, IME this gives total drive failure , not the intermittent slipping you report.
More likely is a worn out and notched clutch basket and hub, when the clutch is disengaged it fails to fully re engage because the plate tangs get hung up on the wear notches instead of completely re engaging.
DPOs may have replaced tired friction plates and springs in the past, neglecting to address other wear issues. Every part of the clutch is a wear item.
Re: 71 BSA Thunderbolt kick start [Re: sam_tots] #429020
04/10/12 8:15 pm
04/10/12 8:15 pm
sam_tots Offline OP
sam_tots  Offline OP
OK, we are all good now! Thanks everyone so much for the help. The problem was a combination of clutch adjustment and some refurbishing of the kick-start mechanism. Starts first or second kick again and no more problems with the kick. So awesome, first ride in 6 months today, was great.
Sam
Page 2 of 2 1 2
