Mike-71-650
Mike-71-650
Al, Birmingham
196 registered members (79T140E), 2,136 guests, and 585 spiders.
koan58 90
Lannis 88
NickL 86
505,871 mail-order LSR
Topics66,065
Posts639,435
Space left by Tapered Steering Head Bearings #427747
04/03/12 8:26 pm
04/03/12 8:26 pm
Tampa, Florida
GTSRider Offline OP
GTSRider  Offline OP
Tampa, Florida
I know this has been covered before, but does anyone make
a spacer to make up the gap , left by the Tapered Bearing in
the steering head ?
I am building my 71 Triumph 500... and the space is unsightly.
I was thinking by now ...someone has machined a black anodized spacer .
Pete
PM
Re: Space left by Tapered Steering Head Bearings [Re: GTSRider] #427838
04/04/12 2:38 am
04/04/12 2:38 am
Tampa, Florida
GTSRider Offline OP
GTSRider  Offline OP
Tampa, Florida
Yep.... I should of....
I know it's a know issue...so I thought someone may have come up with something by now....
PM
Re: Space left by Tapered Steering Head Bearings [Re: GTSRider] #427839
04/04/12 3:08 am
04/04/12 3:08 am
Illinois, USA
TR6Ray Online content
TR6Ray  Online Content
Illinois, USA
Pete,
I'm no help to you, but was wondering if you could put up a picture showing the problem. I installed tapered roller bearings on on my dry frame TR6 steering stem with no issues whatsoever -- a perfect fit. They came from Conventry Spares, bought through a local supplier. I have heard of people having trouble with the "All Balls" roller bearing kits on the Japanese bikes if they use the wrong spacer.
I'm just trying to learn here -- is that an issue with the later bikes?
Re: Space left by Tapered Steering Head Bearings [Re: GTSRider] #427843
04/04/12 3:19 am
04/04/12 3:19 am
I've installed them in a variety of bikes, some with more gap than others. One thing you'll need to be certain of is that the races are fully seated in the frame.
I've successfully ground the inner bearing to allow a better fit. This is a touchy job. It can be done, but only if there is a very small gap.
I've used spacers made from stainless tubing to fill the gap, also.
I really like the more positive handling from these bearings and think the effort is worth it.
Re: Space left by Tapered Steering Head Bearings [Re: HawaiianTiger] #427858
04/04/12 5:12 am
04/04/12 5:12 am
USA, WA state
russrudolph Online content
russrudolph  Online Content
USA, WA state
I just used a black plastic tie to cover the space on mine. have to look very close to notice it.
Re: Space left by Tapered Steering Head Bearings [Re: GTSRider] #427866
04/04/12 6:26 am
04/04/12 6:26 am
I ground the bearing inners to get enough threads engaged and the small gap left I covered with black tape, you can also mill the bottom of the top triple tree on the underside of the centre hole to close the gap further.
Page Time: 1.922s Queries: 15 (0.014s) Memory: 1.0252 MB (Peak: 1.1854 MB) Zlib disabled. Server Time: 2018-02-25 17:49:08 UTC
