Kenacu
Kenacu
RED BANK NJ
203 registered members (1xfatboy), 2,165 guests, and 544 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
How to convert positive earth to negative earth? #42560
02/19/05 9:48 pm
02/19/05 9:48 pm
martinsville, Virginia
Patrick Offline OP
Patrick  Offline OP
I have a 77 Triumph. I am going to install a tympanium unit. I want to convert the bike to negative ground first. How do you convert a british bike to negative ground?
Re: How to convert positive earth to negative earth? #42561
02/19/05 10:58 pm
02/19/05 10:58 pm
North Georgia, USA
RF Whatley Online content
RF Whatley  Online Content
North Georgia, USA
Not sure why you'd want to do this, but here goes....
On a stock system, the only things that really give a hoot about the grounding are the Zener and the rectifier. Both these units will be removed and replaced by the Tympanum any way.
The ignition coils would then be the only remaining polarized items. So plug the Blk/Wht and Blk/Yel points wires to the Neg (-) side of the coil. Then plug the Wht, Wht/Yel or Wht/Blu wires that supply power to the coils to the Pos (+) side of the coils. (In other words reverse all the wires plugged to both coil terminals.) You may have to physically rotate the coils by 180 deg to get the wires to reach.
If you have a Boyer and are using dual 6V coils you do the same polarity reversal, including the jumper wire between the 2 coils.
If you do this be sure and alert every Brit mechanic you take it to for ever more.
Hope this helps.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: How to convert positive earth to negative earth? #42562
02/20/05 12:05 am
02/20/05 12:05 am
Patrick Offline OP
Patrick  Offline OP
Thanks for the info. Do I also reverse the wires to the battery? I'm doing this because I want a head and taillight modulator and the companies tell me they will not work with positive ground.
Re: How to convert positive earth to negative earth? #42563
02/20/05 1:37 am
02/20/05 1:37 am
philadelphia
supertrump Offline
supertrump  Offline
philadelphia
seems like a lot of dedication for modulation.
have you considered simply flicking between high and low beam with your thumb? wink
Re: How to convert positive earth to negative earth? #42564
02/20/05 11:13 am
02/20/05 11:13 am
Patrick Offline OP
Patrick  Offline OP
Actually, I don't want to worry about the manual use of the high and low plus I want the taillight modulation.
Re: How to convert positive earth to negative earth? #42565
02/20/05 12:25 pm
02/20/05 12:25 pm
North Georgia, USA
North Georgia, USA
Patrick -
Forgive me, how stupid of me. Yes the battery wires will need to be reversed. :rolleyes:
If you have a Boyer, then read the instructions (or look it up online) that came with it. There's a blurb in there about Neg ground.
BTW... I believe in HL modulation. It has been shown to reduce frontal wrecks (cars pulling out in front of you) by something like 50%. However there is no such evidence for tail lamp or brake lamp modulation. All you can really do there is add more/ brighter lighted area by 1) installing an LED tail lamp bulb, 2) adding LEDs so that the rear turn signals become running lamps, or 3) adding another lamp to the rear. Notice all this lighting is done with LEDs so you don't add more load to the stock charging system. The best place to get these lamps is:
http://www.superbrightleds.com/truck_lights.htm
Notice I didn't take you to the motorcycle section. (Check that out too.) Anything for m/c (a hobby) is $70. However, in the TRUCK section (a business) everything is $20. That's more in my price range. Notice some of these units will fit inside your stock tail lamp. AND THESE BABIES ARE BRIGHT !! All their 2-wire lamps will work on Pos or Neg ground.
BTW2... Or you could do what I did... remove the rider, set a negative ground Hinckley in the driveway, and re-install rider. Works like a charm.
Hope this helps. bigt
RF Whatley
Cornelia, GA
Re: How to convert positive earth to negative earth? #42566
02/20/05 11:58 pm
02/20/05 11:58 pm
Patrick Offline OP
Patrick  Offline OP
Thanks Redneck,
I installed the tympanium today. I'll change the grounds according to your instructions later this week. I agree with the stats on the headlight modulator.
Thanks again,
Patrick
Re: How to convert positive earth to negative earth? #42567
02/24/05 12:03 am
02/24/05 12:03 am
North Georgia, USA
North Georgia, USA
St. Patty -
Be sure and disconnect the Zener and old rectifier from the harness. The best way to install the tynpanum is to crimp male 1/4" spade connectors onto it's short leads. In this way you can connect to the stock harness (female spades) without destroying it. You can also swap back to Pos ground by simply re-plugging.
Ability to return to Pos ground would be VERY helpful when traveling south of the equator, since electrons swirl down the drain in the opposite direction in those latitudes. bigt
RF Whatley
Cornelia, GA
Page Time: 0.058s Queries: 14 (0.006s) Memory: 1.0419 MB (Peak: 1.2171 MB) Zlib disabled. Server Time: 2018-02-24 14:02:44 UTC
