The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
Norton Commando head steady #402574
11/08/11 12:42 am
11/08/11 12:42 am
Burnaby B C
Jim H Offline OP
Jim H  Offline OP
Burnaby B C
"Norton Head Steadies" What are the pros or cons of installing one? Do they help eliminate or increase vibrations? The two rubber bungs on the pre MK3 appear to be a little wimpy and do little to stabilize the top of the motor. The Dave Taylor unit with the adjustable spring looks impressive, certainly looks like it might be an improvement over the 2 rubber muffler mount bungs. I would love some feedback positive or negative. I have installed Vernier adjustable front and rear isolastic units on my 74 Norton Commando and thought maybe I should look into a head steady.
Thanks Jim
Re: Norton Commando head steady [Re: Jim H] #402648
11/08/11 9:37 am
11/08/11 9:37 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
I suggest you go to the accessnorton website forum and search "headsteady" or "head stady" as that will bring up literally hundreds of results which will give you plenty of information.
Re: Norton Commando head steady [Re: Jim H] #402693
11/08/11 4:30 pm
11/08/11 4:30 pm
The taylor unit is in the "better" range of available units. A good value.
I recommend a front steady as well, there are bolt-on units available.
The ultimate setup also incorporates a rear/lower rod joint unit. What this does is limit ALL of the three iso units range of motion to strictly fore/aft - up/down, and eliminates ALL side-to-side play.
The top steady is just the first (albeit very significant) step in addressing the isolastic system's allowance of the swingarm to have "free range" out back.
Re: Norton Commando head steady [Re: GrandPaul] #402695
11/08/11 3:35 pm
11/08/11 3:35 pm
Musings / ramblings...
I'd love to see a massive fixed jig with a Commando solidly bolted in place by the frame, with a video made of the rear wheel being forced through the entire range of motion of the standard isolastic system.
That must be an impressive figure-of-eight!
On a related note, the swingarm spindle root tube welded into the transmission cradle can typically become wallowed out, allowing significant undesireable swingarm play. The late Heinz Kegler designed a simple set of drill and bolt-on clamps that cure this issue once and for all time on a typical Commando. They are still being made and are highly recommended (new swingarm bushings DO NOT address this issue).
Re: Norton Commando head steady [Re: Jim H] #403115
11/10/11 8:39 pm
11/10/11 8:39 pm
Winter Springs, FL
Tom Sanders Offline
Tom Sanders  Offline
Winter Springs, FL
I've been using the dave taylor model for 3-4 years. I'm quite happy with it.
I have used Norvil isolastic unit I'll sell for cheap.
LONG LIVE LOCKTITE
74 Roadster 880cc
1962 Norton 650SS
75 Ducati 860GT
1968 Commando Fastback SN 126157
1975 Honda CB400f AHRMA racer #842
email addy: sargehopp@gmail.com
Re: Norton Commando head steady [Re: Jim H] #403243
11/11/11 12:11 pm
11/11/11 12:11 pm
Peter R Offline
Peter R  Offline
Another vote for the Dave T headsteady. After having used a Norvil steady for many years, I noticed a significant improvement in handling after I fitted the Dave T headsteady.
The Dave T headsteady may need some re-work when fitted to one of the Italian made (read Metric) frames.
Re: Norton Commando head steady [Re: Peter R] #403291
11/11/11 3:11 pm
11/11/11 3:11 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
Originally Posted by Peter R
<SNIP>
True. I fitted a Dave T steady recently to a 1973 Commando, and found the frame clamp to be too loose. Milling about 0.010" off each face of the clamp allowed it to grip the tube properly.
.. Gregg
magneto@spyder-it.com
Re: Norton Commando head steady [Re: gREgg-K] #416868
02/04/12 5:32 am
02/04/12 5:32 am
California, USA
dmat Offline
dmat  Offline
California, USA
How much increase was there in the vibration?
75' 850 Commando
67' Bonnie (on the lift being restored)
Honda CB160, CB350, SL100
BMW K1200LT
KTM 450 & 950 Adventure
Re: Norton Commando head steady [Re: Jim H] #416950
02/04/12 5:36 pm
02/04/12 5:36 pm
Springfield Nebraska
Richrd Offline
Richrd  Offline
my experience with rod end type steadies on two different bikes was that there is not much difference. unless you're running the corners way to hard to be legal you won't notice any improvement.
The best thing to improve handling on a pre mk3 is fit a set of Windy's swingarm collars.
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Norton Commando head steady [Re: Jim H] #417457
02/07/12 5:43 pm
02/07/12 5:43 pm
Winter Springs, FL
Tom Sanders Offline
Tom Sanders  Offline
Winter Springs, FL
Amen to the swing arm collars. I would not run without them.
LONG LIVE LOCKTITE
74 Roadster 880cc
1962 Norton 650SS
75 Ducati 860GT
Re: Norton Commando head steady [Re: Jim H] #417476
02/07/12 8:02 pm
02/07/12 8:02 pm
Annapolis, MD
Dennis B, R.I.P. Offline
Annapolis, MD
Hi All
What are swing-arm collars? are these anything like gussets?
I don't think I've ever heard of them.
Can anyone direct me to a link with info?
TIA
Dennis B
Member # 182
'73 750 Commando
'72 Combat Commando
'71 Triumph Blazer
'69 Victors
'68 Starfire
'51 Royal Enfield 250 'S'
Re: Norton Commando head steady [Re: Jim H] #417494
02/07/12 11:12 pm
02/07/12 11:12 pm
Richrd Offline
Richrd  Offline
tech term I believe is "split shaft collar". the common norton set up was made by Heinze Kegler, now deceased.
They are now made and are available thru Windy. (Bill50cal)
They mount on the swingarm, a hole is drilled thru the swingarm tube and a bolt is inserted that bears on the s/a spindle and takes up the slack.
On the typical Commando, not all the left to right movement of the rear wheel is due to the isos, some is the play in the swingarm, and in my opinion this is most of the vague feeling you get in corners.
The MK3 has a modified swingarm with cotters to take up the slack.
Hey Bob, you need a pair of these too!
and the Snake Bike
and a Honda?
Re: Norton Commando head steady [Re: Dennis B, R.I.P.] #417501
02/07/12 11:27 pm
02/07/12 11:27 pm
Norfolk, UK
Norfolk, UK
http://www.nortonfastback.com/html/mods.html
Re: Norton Commando head steady [Re: L.A.B.] #417514
02/08/12 12:27 am
02/08/12 12:27 am
St. Petersburg, Florida
cmessenk Offline
cmessenk  Offline
I run with the DT headsteady AND the Kegler swingarm fix (installed by Windy / bill50cal)...transformed my bike.
Chip
'72 Combat
Re: Norton Commando head steady [Re: Jim H] #417523
02/08/12 1:08 am
02/08/12 1:08 am
Annapolis, MD
Annapolis, MD
Thanks Rich, L.A.B. & Chip
the link was very helpful, I do have the two nuts welded setup
Dennis B
Member # 182
'73 750 Commando
'72 Combat Commando
'71 Triumph Blazer
'69 Victors
'68 Starfire
Re: Norton Commando head steady [Re: Dennis B, R.I.P.] #417566
02/08/12 10:07 am
02/08/12 10:07 am
Peter R Offline
Peter R  Offline
The two welded nuts will work fine, no need to replace these for the collars.
Re: Norton Commando head steady [Re: Richrd] #417597
02/08/12 2:59 pm
02/08/12 2:59 pm
Originally Posted by Richrd
tech term I believe is "split shaft collar"... They mount on the swingarm, a hole is drilled thru the swingarm tube and a bolt is inserted that bears on the s/a spindle and takes up the slack.
I believe you mean they mount on the tranny cradle spindle tube...
Re: Norton Commando head steady [Re: Richrd] #417695
02/09/12 2:18 am
02/09/12 2:18 am
Howard Inough Offline
I sure do need these. I had the mag base and long travel indicator set up today evaluating what I have. Binned the indicator in favor of the tape measure. Richrd, are the replacement iso parts any better from brand or another? I assume I want the MKIII style threaded adjust kit?
1974 Norton Commando 850
1973 Yamaha TX750
1975 Yamaha DT400B
1984 Yamaha RZ350
2007 Triumph Tiger 1050
2014 Triumph Rocket III
Re: Norton Commando head steady [Re: Jim H] #417728
02/09/12 1:05 pm
02/09/12 1:05 pm
Richrd Offline
Richrd  Offline
bob, email at ya
and the Snake Bike
and a Honda?
Re: Norton Commando head steady [Re: Peter R] #419511
02/19/12 6:41 am
02/19/12 6:41 am
Portland, Oregon
swooshdave Offline
swooshdave  Offline
Portland, Oregon
If you have a welder...
Re: Norton Commando head steady [Re: Jim H] #421939
03/02/12 12:21 am
03/02/12 12:21 am
Omaha, NE, USA
Paul Sammut Offline
Paul Sammut  Offline
Omaha, NE, USA
In answer to the Taylor head-steady question - I guess I will differ from others. I found that it increased vibration too much and I reverted to the original set-up and am much happier.
Paul.
Paul
'74 Commando - Interstate
"74 Commando - Hi-Rider, possibly
'65 Atlas, mostly anyway
'15 R1200 GS Adv
'51 Vincent Rapide
'58 Ariel Square Four
Moderated by  Dave Comeau
