The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
Page 2 of 2 1 2
Re: Bsa B40 WD Questions [Re: Hjalte] #419966
02/21/12 1:01 pm
02/21/12 1:01 pm
Denmark
H
Hjalte Offline OP
Hjalte  Offline OP
H
Denmark
My intake port is 27,5mm so ill go for 28mm ? with same settings ? or ?
Re: Bsa B40 WD Questions [Re: Hjalte] #419971
02/21/12 1:50 pm
02/21/12 1:50 pm
I don't think you'll get anything more out of the 28 mm carb. While I don't think it'll hurt anything, the WD cam and small inlet valve is just not going to allow for enough breathing to justify it. They really run well with the 626 Concentric and it's pretty easy to set up.
Re: Bsa B40 WD Questions [Re: Hjalte] #419973
02/21/12 2:06 pm
02/21/12 2:06 pm
Denmark
H
Hjalte Offline OP
Hjalte  Offline OP
H
Denmark
okay thank you
Re: Bsa B40 WD Questions [Re: Hjalte] #419993
02/21/12 4:08 pm
02/21/12 4:08 pm
Jaffrey, NH, USA
Peter Quick Online content
Peter Quick  Online Content
Jaffrey, NH, USA
One could always put in a 8.75 compression piston, a Victor cam, and a B44 round barrel head that takes a bigger carb and has a bigger intake valve. All pretty easy things to do. That should give you some more pep!
Peter
Re: Bsa B40 WD Questions [Re: Hjalte] #419997
02/21/12 4:25 pm
02/21/12 4:25 pm
^^^True dat^^^
But then it wouldn't really be a WD anymore, would it?
BTW, this may be of interest: http://www.eBay.com/itm/NOS-BRITISH...otorcycles_Parts_Accessories&vxp=mtr
Re: Bsa B40 WD Questions [Re: Alex] #420148
02/22/12 12:04 pm
02/22/12 12:04 pm
BSA_WM20 Offline
BSA_WM20  Offline
The WD B40s had a long spacer between the carb & the head . These were not needed with an alloy head but the WD still had memories of M20's boiling fuel in the carb.
Now these spacers have a hole in them to allow fuel to drain out instead of running into the pot and causing a hydraulic lock ( or worse).
To compensate for the regulated "Air Leak" the WD's were jetted very rich.
Fit a 626 and you are laughing. Put a 900 series float bowl with the drain plug in it and you will be laughing even louder.
Re: Bsa B40 WD Questions [Re: Hjalte] #420160
02/22/12 2:06 pm
02/22/12 2:06 pm
Trevor, I don't see how this spacer could have been installed on the GB bikes as the original carb is quite long and it really couldn't be much closer to the airbox. Maybe models for other militaries were different?
Also, I think all the newer 600 and 900 carbs use the drain plug style float bowl.
Re: Bsa B40 WD Questions [Re: Hjalte] #420161
02/22/12 2:10 pm
02/22/12 2:10 pm
Denmark
H
Hjalte Offline OP
Hjalte  Offline OP
H
Denmark
i just orderd a 626 from brand new so hope it will run good, and still a 350cc bike is not one you "race" on its just for transport and style not for preformance if i wanted preformance i would have bought myself a kawazaki 9000000cc with trippel OCH or somthing hehe
Re: Bsa B40 WD Questions [Re: Hjalte] #420197
02/22/12 5:58 pm
02/22/12 5:58 pm
Sverige
Pelle Offline
Pelle  Offline
Sverige
And you will have the bike running in Alingåbro on June 1-3, perhaps? (If so, I guess it will not be the only WDB40 there...)
Pelle
Re: Bsa B40 WD Questions [Re: Hjalte] #421586
02/29/12 11:44 am
02/29/12 11:44 am
Denmark
H
Hjalte Offline OP
Hjalte  Offline OP
H
Denmark
Thanks so far guys wink
got my new carburator today from burlen, very good service and fast. Can be recomended wink
i orderd some more parts hopefully they will come in the close future , then i can sum up on the last thins i need and order them.
progress so far is going a bit slow mostly grinding down old paint, flattning it ready for painting.
Page 2 of 2 1 2
