Timecycles
Timecycles
Alberta, Canada
20 registered members (Alan_nc), 154 guests, and 433 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,042 mail-order LSR
Topics68,853
Posts670,686
Members10,478
Smiths gauge fitment list #419192
02/17/12 4:57 pm
02/17/12 4:57 pm
so. cal
Torch2 Offline OP
Torch2  Offline OP
so. cal
where can I find an online fitment list for Smiths gauges?
specifically the Triumph M/C list.
I've got to find the right tack for a 57 T110, the RC/83 I have is a 2 to 1 and I think I need a 4 to 1 drive?
Nisonger can convert it but it's pricey.
Re: Smiths gauge fitment list [Re: Torch2] #419224
02/17/12 7:16 pm
02/17/12 7:16 pm
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
You might want to contact Scott Thomas at Triumph Restorations. His e-mail and phone numbers are:
scott@smithsgagerepair.com
224-595-2037
He let me spend the day in his shop with him, watching over his shoulder as he rebuilt both my gages, and I can't say enough good things about his workmanship and knowledge. He is the guy who advertises as Smiths Magnetic Instrument Repair in Motorcycle Classics Magazine.
Here are some pics of the work he did for me.
Re: Smiths gauge fitment list [Re: Torch2] #419242
02/17/12 8:54 pm
02/17/12 8:54 pm
Waldorf, Maryland
Tiger Dale Offline
Tiger Dale  Offline
Waldorf, Maryland
WOW Ray what did he charge for that?
TD
Re: Smiths gauge fitment list [Re: Torch2] #419249
02/17/12 9:37 pm
02/17/12 9:37 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
RC 126
Re: Smiths gauge fitment list [Re: Tiger Dale] #419280
02/18/12 1:36 am
02/18/12 1:36 am
Illinois, USA
TR6Ray Offline
TR6Ray  Offline
Illinois, USA
TD
That was in November, 2009, and he charged US$185 each gage for a total of $370.00. I don't know what it would cost now. Both gages were disassembled, and cleaned and lubed, and parts replaced as needed. They were tested throughout their range on a test bench. Both came with a year guarantee. The cases off my gages went on the shelf as "cores" and were replaced with identical parts that he had already refurbished. The faces, glass, and chrome bezels were replaced with new. He had a unique method of crimping the bezel into place to hold the glass, the case, and the seal in place. It was done on his lathe, with tooling that he had made himself. There was a Triumph wheel bearing mounted on the lathe cross slide that came in against the bezel and roll-crimped it without scarring the metal.
It was a most interesting day, and he is a unique, highly skilled workman to say the least.
Re: Smiths gauge fitment list [Re: TR6Ray] #419309
02/18/12 4:34 am
02/18/12 4:34 am
Jon W. Whitley Offline
I like to think I am up-to-date and know of pretty much all suppliers/shops but this one is new to me. Looks like a real good shop to do business with.
Re: Smiths gauge fitment list [Re: TR6Ray] #419312
02/18/12 4:59 am
02/18/12 4:59 am
Nebraska, USA
E
ed_h Offline
ed_h  Offline
E
Nebraska, USA
"Rolling" the crimp on the bezel probably looked similar to this. I've also seen it done where the bearing first comes in at a small angle to start the crimp, and subsequent passes are made with a greater angle until the tool is parallel with the side of the case.
For just a little more, you can do it yourself!
Re: Smiths gauge fitment list [Re: L.A.B.] #419381
02/18/12 4:57 pm
02/18/12 4:57 pm
so. cal
Torch2 Offline OP
Torch2  Offline OP
so. cal
L.A.B>- thanks for the model # info, and I assume a RC/126 is a 4/1 ?
I was also told 1307/02
is there an online place where I can find the fitment list?
Re: Smiths gauge fitment list [Re: Torch2] #419387
02/18/12 5:48 pm
02/18/12 5:48 pm
Norfolk, UK
Norfolk, UK
2:1 Apparently?
http://omega-13.com/smiths/smiths_2.htm
"RC 126(RC1305/00)
8000rpm
ratio 2:1
Clockwise"
The RC 126 tacho appears to have been optional equipment for Triumph twins during that period but there's no tacho drive gearbox for that application in the Smiths '54-'58 list.
http://www.flickr.com/photos/9383961@N05/2982504702/in/set-72157608455625820/
Re: Smiths gauge fitment list [Re: L.A.B.] #419493
02/19/12 3:51 am
02/19/12 3:51 am
so. cal
Torch2 Offline OP
Torch2  Offline OP
so. cal
ok but the way I'm thinking is if the cam cover tack drive is a 2/1 drive and it's running off of the exhaust cam which is 2/1 from the engine then shouldn't the tack be a 4/1 tack?
Re: Smiths gauge fitment list [Re: Torch2] #419524
02/19/12 9:39 am
02/19/12 9:39 am
Norfolk, UK
Norfolk, UK
But what makes you think the original tach drive gearbox would have been 2:1? It could have been 1:1.
Re: Smiths gauge fitment list [Re: Torch2] #419567
02/19/12 3:21 pm
02/19/12 3:21 pm
so. cal
Torch2 Offline OP
Torch2  Offline OP
so. cal
well, I spun it around and counted the turns, I'll do it again and see if my counting skills have also diminished with age.
I hope I'm wrong because I just bought an RC 126 on eBay.
the RC83 I have says it's a 2/1 drive.
Re: Smiths gauge fitment list [Re: Torch2] #419571
02/19/12 3:39 pm
02/19/12 3:39 pm
Norfolk, UK
Norfolk, UK
Yes, but how do you know it's the original?
Re: Smiths gauge fitment list [Re: Torch2] #420121
02/22/12 4:29 am
02/22/12 4:29 am
San Diego
lurkingclass Offline
San Diego
I recently did quite a bit of research on this topic, and based on the Smiths fitment chart/parts list and the various chronometric tachs and drive I've found, here's what I can confirm-
The pre-unit tach drive covers with the cast-in tach drive covers take a 4:1 counterclockwise RC109 or RC1307. I also stumbled on an RN1102/00 small magnetic Smiths tach that's correct for the early Cub with the tach drive- that is also a counterclockwise 4:1 tach and will work on a pre-unit.
The RC 126 is a 2:1 clockwise rotation tach that works with the GP/Race Kit/T100R racing drive that takes the place of the generator.
The RC83 fits Norton Manx and Goldstar, I believe. It's 2:1, but counterclockwise.
There's a good post on the Jockey Journal about this same topic-
http://www.jockeyjournal.com/forum/showthread.php?t=52391&showall=1
