nisse
nisse
sweden
22 registered members (blackrag), 167 guests, and 458 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,816 mail-order LSR
Topics67,150
Posts651,648
Members10,257
fork lower assembly A65 shuttle valve type #41407
08/08/08 4:00 pm
08/08/08 4:00 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
at long last i have some sliders for my project and will have the rolling chassis done in a couple of weeks.......i am using triumph type shuttle valve forks with A65 tubes...the sliders i got came with a piece in the bottom that looks like a slender cone...the bolt that holds it goes through the bottom of the slider,,,how is this piece reassembled??? i see it has a slot and the drain plug on the side has a protuberance.....
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: fork lower assembly A65 shuttle valve type #41408
08/09/08 5:47 am
08/09/08 5:47 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Does the cone piece not have a hex on the bottom? You should be able to use a deep well socket to tighten it. The cone is to cut off the oil flow through the shuttle as the fork approaches bottom.
Re: fork lower assembly A65 shuttle valve type #41409
08/09/08 12:48 pm
08/09/08 12:48 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
no hex....it's smooth but has a slot cut in the side of the base...i'm thinking the protuberance on the drain plug engages the slot but how?
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41410
08/09/08 1:03 pm
08/09/08 1:03 pm
Dallas Texas
RPM Offline
RPM  Offline
Dallas Texas
What you have is the early type cone piece. It is held by the drain plug. The later type that you need have a hex and use a different bolt at the bottom. You also will need new drain bolts as they are shorter.
Re: fork lower assembly A65 shuttle valve type #41411
08/09/08 1:54 pm
08/09/08 1:54 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
will the type i have not work with the shuttle valve??
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41412
08/09/08 2:07 pm
08/09/08 2:07 pm
Dallas Texas
RPM Offline
RPM  Offline
Dallas Texas
No, you need 2each of part 97-2090, 97-1062,97-2126,97-3893,97-3894. Nothing else will work.
Re: fork lower assembly A65 shuttle valve type #41413
08/09/08 2:31 pm
08/09/08 2:31 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
thanks...
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41414
08/09/08 9:32 pm
08/09/08 9:32 pm
Yup, problem is, the cone for the early non-shuttle valve forks is too fat and won't fit inside the hole in the shuttle valve. I suppose you could turn them down if you had access to a lathe, but in the end, I would just get the proper bits.
Re: fork lower assembly A65 shuttle valve type #41415
08/09/08 9:54 pm
08/09/08 9:54 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
thanks again fellers..i made up a list for all the new pieces and am going to order them this week,,then I will have totally new forks inside, new stanchions and powder coated sliders ......another hurdle cleared.....
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41416
08/09/08 11:26 pm
08/09/08 11:26 pm
raf; It sounds like you have the bottem bits for the BSA rod damper system.
The tube would look like this one if it is BSA.
Re: fork lower assembly A65 shuttle valve type #41417
08/10/08 12:55 am
08/10/08 12:55 am
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
no holes in the cones..they are solid
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41418
08/10/08 2:59 pm
08/10/08 2:59 pm
E
EWebster Offline
EWebster  Offline
E
Check the length of the backing plate peg before you start ordering parts.
Re: fork lower assembly A65 shuttle valve type #41419
08/10/08 3:02 pm
08/10/08 3:02 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
hi....i've already test fitted backing plate peg/axle and everything fits...just got to get correct 'innards'
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41420
08/11/08 7:57 pm
08/11/08 7:57 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Raf...RPM is right, the ones you have are for the 68 damper rod forks.
One thing ive wondered about them is how exactly does the oil not leak out through the allen head bolt that hold the cone? Does it just rely for sealing on the assembly parts being a tight steel to steel fit since there is no oil seal shown in parts diagram?
http://www.britbike.com/ubb/noncgi/ultimatebb.php?/ubb/get_topic/f/10/t/007754.html#000000
this thread has parts book pics of 68 and latter shuttle valve forks
Re: fork lower assembly A65 shuttle valve type #41421
08/11/08 9:27 pm
08/11/08 9:27 pm
Ig, I think Raf has some pre-shuttle valve triumph legs. They used a much fatter restrictor pin (cone), but are otherwise pretty much the same as the shuttle valve forks.
Re: fork lower assembly A65 shuttle valve type #41422
08/11/08 9:45 pm
08/11/08 9:45 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Alex..I missed that bit....so Triumph brought in the shuttle valve forks before BSA?...you live and learn eh.
Re: fork lower assembly A65 shuttle valve type #41423
08/11/08 11:36 pm
08/11/08 11:36 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
you win a ceegar! the lowers came off a 68 bonneville....they are in great shape but i paid dearly for them .......gonna order innards soon....i put the bike up on the centerstand tonite for the first time........
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: fork lower assembly A65 shuttle valve type #41424
08/12/08 1:33 am
08/12/08 1:33 am
E
EWebster Offline
EWebster  Offline
E
If they are truly off a 68 Triumph, the backing plate will have minimal engagement with the peg on the slider. If you use the BSA spacing on the triple clamps that is. You have to put everything together to be sure, especially if you have the short Tri axle.
Re: fork lower assembly A65 shuttle valve type #41425
08/12/08 1:13 pm
08/12/08 1:13 pm
Triumph had the shuttle valve-type forks before '69, except they didn't have shuttle valves. They act kind of like the pre-damper rod BSA forks with pretty minimal rebound damping.
