Barb
Barb
Western Washington State (USA)
25 registered members (Andy Higham), 185 guests, and 405 spiders.
10256 Registered Users
Stuart 75
Lannis 66
608,497 mail-order LSR
Topics67,110
Posts651,229
Members10,256
Clunk...WTF... #412665
01/10/12 11:58 am
01/10/12 11:58 am
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
So..I have finally removed the trans from my 70' A66, and im ready to install the new one... but before i did i wanted to make sure the upper end of the motor was in proper working order. I re-assembled the spindles, tappets etc etc.. torqued everything down all proper like,installed the push rods and set the valve gap.
Up until this point the Motor cranked smooth by hand, even had decent compression.(well as close as i can tell cranking the motor by hand and covering the plug port),... But now that i have installed the components to the head it only cranks about 1-1.5 turns and stops dead with a light "clunk" in either direction. I have never encountered this before on any motor I've had... Anyone have any idea as to what is causing this??
1967 BSA Lightning(w)
1969 BSA Thunderbolt(e)
1966 BSA Thunderbolt(?)
Re: Clunk...WTF... [Re: BSA-Jay] #412667
01/10/12 12:09 pm
01/10/12 12:09 pm
Surrey UK
Mattsta Offline
Mattsta  Offline
Surrey UK
I think you need to check your valve timing
It sounds like you might have valves open at TDC
1952 Triumph T100 in a BSA A7 Frame
Re: Clunk...WTF... [Re: BSA-Jay] #412684
01/10/12 2:18 pm
01/10/12 2:18 pm
Do those pushrods again.
Re: Clunk...WTF... [Re: BSA-Jay] #412687
01/10/12 2:23 pm
01/10/12 2:23 pm
derby england
wak Offline
wak  Offline
derby england
sounds like a pushrods not fitted properly at the bottom or on the wrong follower
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: Clunk...WTF... [Re: wak] #412699
01/10/12 2:51 pm
01/10/12 2:51 pm
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
I have the intakes on the outer followers and the exhaust on the inner 2. I did have a bit of trouble with the right side exhaust rod.. it was hanging up a bit but got it seated properly.I then removed the pushrods and checked the piston position before installing again.. it looked correct. I had assumed that since the motor was redone recently that everything "should be set correctly".. as i didn't make any changes, only removed the tranny.
Re: Clunk...WTF... [Re: ] #412779
01/10/12 8:56 pm
01/10/12 8:56 pm
Originally Posted By: 1968BSA
Sounds like that to me too
Whip the rocker cover off and take a plug and and drop a rod down to see how high the piston is, then try and put it in gear and turn the wheel backwards
Hopefully you haven't done any damage.
Do your valve timing maks line up?
Unless he took the inner timing cover off, and the idler gear came out with it, the timing marks had no way to change ....
Gotta be pushrods on the wrong cam lobes ...
Re: Clunk...WTF... [Re: Lannis] #412893
01/11/12 11:58 am
01/11/12 11:58 am
BSA_WM20 Offline
BSA_WM20  Offline
Also have a close look at the valve ends.
You can get a little rust on the stem when the head has been sitting for a while.
This is oft just enough to make the valve jamb open and smack the piston.
Re: Clunk...WTF... [Re: BSA-Jay] #412906
01/11/12 1:34 pm
01/11/12 1:34 pm
Ponoka ,Alberta,Canada
A.k.a Homer Offline
A.k.a Homer  Offline
Do you have the right head on it ?
Aka homer
A day with out learning something new is a bad day indeed.
Re: Clunk...WTF... [Re: A.k.a Homer] #412955
01/11/12 6:04 pm
01/11/12 6:04 pm
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
BSA,
The valves are seated correctly, i have a tendency to oil all metal bits on the head and wrap them it a plastic bag while off the motor.
Homer,
yes, its the head that came with the motor as well as the pistons, cam etc etc..., for a Stock A65 Thunderbolt.
I'm going to take another crack at it Tomorrow(thurs)I'll look into all sugestions.
Thanks alot guys, I'll let you know how it goes.
Re: Clunk...WTF... [Re: BSA-Jay] #413058
01/12/12 10:38 am
01/12/12 10:38 am
derby england
wak Offline
wak  Offline
derby england
Did you disturb the cam idler pinion when you took the timing cover off to change the tranny?
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: Clunk...WTF... [Re: ] #413096
01/12/12 6:08 pm
01/12/12 6:08 pm
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
I think there might be a bit of miss understanding, I was reffering to the pushrods sitting on the ball ends of the tappets and rockers, it's all to easy for them not to seat here, regardless of if the valves are ok or not
Sorry 1968, i was replying to BSA 420's reply concerning the Valves seating/ rusting...
Re: Clunk...WTF... [Re: wak] #413098
01/12/12 6:24 pm
01/12/12 6:24 pm
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
WAK,
I may have... I'll look tonight when i get over there.
If i did all i should have to do is set the pistons @ 28 degrees before TDC, then re-install correct?? Its been like 8 years since I've had to do anything with the bottom end of the motor so im a bit rusty.
Re: Clunk...WTF... [Re: BSA-Jay] #413103
01/12/12 7:04 pm
01/12/12 7:04 pm
Originally Posted By: BSA-Jay
WAK,
28 whu? All you have to do is line up the timing marks.
Re: Clunk...WTF... [Re: BSA-Jay] #413147
01/12/12 11:36 pm
01/12/12 11:36 pm
Jon W. Whitley Offline
J,
I could be wrong but it sounds to me like you do not have a workshop manual. You will need to remove the idler pinion to re-align the timing marks and make certain the valve timing is correct.
Re: Clunk...WTF... [Re: BSA-Jay] #413185
01/13/12 7:10 am
01/13/12 7:10 am
It also helps to back off the valve adjusters so nothing is under tension when you rotate the cam shaft to align the gears.
That said, I had a similar problem years ago with a triple. I got resistance to turning in each direction. Turned out that at least one tappet was tight in its block. You didn't swap tappets around, did you?
Re: Clunk...WTF... [Re: DavidP] #413196
01/13/12 12:40 pm
01/13/12 12:40 pm
Boonton, NJ, USA
BSA-Jay Offline OP
BSA-Jay  Offline OP
Boonton, NJ, USA
No,i do not have a proper workshop manual only the cheeseball Hanes manual that covers like 4different BSA's, and what i can remember from my other rebuilds...
DavidP, this motor had nothing in the upper end when i got it, i ordered all new spindles, rockers, tappets and rods, and when i assembled i left them all less than hand tight.
I did however check the Pinion gear and it was in line.. .checked the Push rod seating which also looked ok... until i sent a dental mirror down the tower to the cam followers and cranked the motor did i realize the problem... somehow the left exhaust follower wasn't seated straight.. it was cocked to the left(almost like someone jammed a flathead down there) causing the rod to jam into his neighbor.
2 hours, and a new set of cam followers later problem solved... Although i did notice a crack in the tower so a new set of Cylinders are in order
thanks Everyone for the advice, I appreciate it.
