Kerry W
Kerry W
Middle East,
40 registered members (Andy Higham), 304 guests, and 397 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 99
Stuart 83
reverb 82
NickL 73
koan58 56
549,701 mail-order LSR
Topics66,547
Posts645,114
Members10,170
Spoke Tension - #404674
11/20/11 10:49 am
11/20/11 10:49 am
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
I just had my first ever go at re-lacing a wheel and I'm pleasantly surprised that it wasn't nearly as hard to do as I envisaged. I've managed to get the wheel running pretty true. There is a slight bit of runout where the rim is welded together and I don't think this can be tweaked out. My side to side runout is about 1/32" which I think is acceptable but I haven't finished tweaking yet.
The thing I'm not so sure about is the spoke tension. I'm using the spokes as a tuning fork to try to get them all similar but I'm not absolutely sure what amount of tension is necessary having never done a wheel rebuild before.
The one thing I did notice during the process is that the spokes become tensioned very quickly. Only a relatvely small turn on each spoke transforms the rigidity of the wheel.
I'd definitely recommend having a go on an old wheel just for the experience of having a go. I designed my own truing stand out of some 1" box stainless steel that was laying about at work which nobody had claimed so I designed a stand and had a fellow at work weld it up for me.
1952 Triumph T100 in a BSA A7 Frame
Re: Spoke Tension - [Re: Mattsta] #404698
11/20/11 4:20 pm
11/20/11 4:20 pm
Winona, MN
Swan Offline
Swan  Offline
Winona, MN
Tension will vary, your lateral and radial truth is more important. However, you do not want to over tighten your spokes because you risk breaking a spoke, pulling a nipple through the rim or breaking the spoke hole in the hub.
John Healy has great information, including spoke tension, in this article from Vintage Bike magazine
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Spoke Tension - [Re: Mattsta] #404706
11/20/11 5:31 pm
11/20/11 5:31 pm
Ideally, you want a spoke torque wrench, particularly if you lack the "feel" an experienced wheel lacer will have.
Torque=force X distance. A fish scale makes a nice force gauge and it usually comes with a hook you can hook into the end of your wrench. Pull at a right angle and your torque (in-lbs) is the displayed force (in lbs.) times the length of the wrench (in inches).
Re: Spoke Tension - [Re: Mattsta] #404723
11/20/11 7:19 pm
11/20/11 7:19 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Alex, So 10 lbs on my torque wrench using a 4 sideways inch wrench extension (say to get at a hard to get at nut) would give me 40 pounds of torque on the nut? What would the formula be for a metric distance, or does one always need or convert to inches? Just making sure I do this right in the future.
Peter
Re: Spoke Tension - [Re: Peter Quick] #404730
11/20/11 8:26 pm
11/20/11 8:26 pm
Stuart Offline
Stuart  Offline
Hi Peter,
No. By definition, a torque wrench is already applying a given force at a given distance, so the "10 lbs" is likely to be 10 lbs.-feet; i.e. the equivalent of 10lbs. applied 1 foot from the centre of the fastener, or 1 lb. applied 10 feet from the centre of the fastener.
Otoh, ...
Originally Posted By: Alex
A fish scale makes a nice force gauge and it usually comes with a hook you can hook into the end of your . Pull at a right angle and your torque (in-lbs) is the displayed force (in lbs.) times the length of the wrench (in inches).
... to translate. wink
"fish scale" = something for weighing fish, not something off the skin of a fish;
"wrench" = ordinary spanner, not "torque wrench";
"torque (in-lbs)" = torque and what everyone else would describe as "pounds-inches", i.e. like "pounds-feet" only smaller;
"force (in lbs.)" = force (in pounds), not the abbreviation for "inch(es)"
So what Alex was trying to say is:-
. if you use and ordinary spanner, open end on the spoke nipple and ring at the other, the "inches" part of pounds-inches will be the distance from the centre of the spoke to the centre of the ring;
. if you hook the fish weighing scales on to the ring of the spanner and pull on the scales, the pounds indicated on the scales will be the "pounds" part of pounds-inches;
. the "pounds" figure multiplied by the "inches" figure is your torque, in "pounds-inches", which can be abbreviated to "lb.-in.".
Well, the metric unit of weight mass is the (kilo)gram, the metric unit of distance is the metre (or centimetre or millimetre), so kg-m, g-mm, whatever you want.
At the risk of confusing you (if you aren't already wink ), but in case 'L.A.B.' reads this and before he's along to correct me, wink most correctly 'f' would be inserted in the abbreviation directly after the weight mass unit - e.g. 'lbf.ft.' or 'kgf-m', to indicate 'pounds force-feet' or 'kilograms force-metres'. Then the S.I. unit of force is actually the Newton, hence metric torque settings can have 'Nm' after the number, rather than 'kgf-m'.
Re: Spoke Tension - [Re: Mattsta] #404731
11/20/11 8:37 pm
11/20/11 8:37 pm
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
So how would/should/shouldn't I use a torque wrench that I'm tightening head bolts on a BSA unit single (sorry for the thread hijack) on the two nuts that I cant get my torque wrench socket straight onto? Use an box end wrench on the nut to get sideways and then use a torque wrench on that, and then the formula? Or should I just go with dead reckoning to get "dead tight".? Peter
Re: Spoke Tension - [Re: Mattsta] #404754
11/21/11 12:07 am
11/21/11 12:07 am
Multiply the length of your torque wrench by the desired torque figure. Divide this by the length of your torque wrench plus the length of any extension.
The result is the torque spec you should read on your torque wrench.
Re: Spoke Tension - [Re: Stuart] #404764
11/21/11 1:32 am
11/21/11 1:32 am
Originally Posted By: Stuart
Well, the metric unit of weight is the (kilo)gram
The metric unit of weight (force) is a newton.
The metric unit of mass is a kilogram.
As for in-lbs vs. lbs-in it's just semantics. I guess one could argue that neither nomeclature is correct if they were being paid for picking nits since it's really lbs*in...and it being a scalar multiplication, thereby commutative the order is irrelevant.
Jeeeeeesh... crazy
Re: Spoke Tension - [Re: Mattsta] #404778
11/21/11 4:01 am
11/21/11 4:01 am
Jaffrey, NH, USA
Peter Quick Offline
Peter Quick  Offline
Jaffrey, NH, USA
Thanks David! Peter
Re: Spoke Tension - [Re: Mattsta] #404822
11/21/11 3:14 pm
11/21/11 3:14 pm
Broken Arrow, OK
BobAsh Offline
BobAsh  Offline
Broken Arrow, OK
Hey guys, I was thinking...why couldn't you use one of these?
30 inch/lb and it's only 27 bucks. Of course you'd have to mod the wrench since it's a 7/16" open end.
Link: http://www.grainger.com/Grainger/JONARD-Torque-Wrench-4AVJ9?Pid=search
Re: Spoke Tension - [Re: BobAsh] #404945
11/22/11 2:40 am
11/22/11 2:40 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
If you don't have a wrench like the above, you can use a lb-in torque wrench. If you will adapt the torque wrench to fit the open end of your spanner and place it at 90 degrees to your spanner, your wrench will click at the correct torque reading. You must be carefull to always be pulling at 90 degrees. It is not the best way but it does work. I do bicycle wheels by feel and I can't tell you what the torque is, but if I was doing a motorcycle wheel i sould like to get the first spokes tensioned correctly to some value....the rest will sort of fall into place as the wheel trues up. By design because of offset one side will be higher torque than the other. If you are just truing a wheel you don't need a stand...just get the wheel off the ground and use the the bike as a stand. You can make a little pointer to measure runout.
Re: Spoke Tension - [Re: Swan] #405880
11/27/11 5:37 pm
11/27/11 5:37 pm
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
Very strange formatting in that vintagebikemagazine article! It puts every word on a new line making it very difficult to read.
Anyway, I've had another go at this wheel because I was getting some vertical runout in the region around the weld and I wanted to have another go at truing the rim to see if I could improve it.
Max runout is exactly where the rim is welded together and recedes in both directions. The run out extends about 1/3rd of the circumference in total, from zero to max then back to zero. The side to side runout is negligable. Max runout is about 1/16" and there is a noticable flat band about 2-3" centred about the weld. It's a brand new Morad alloy rim.
Today I made a second attempt to true the wheel and minimize this vertical runout but I suspect I'm doing more harm than good trying to correct it. The rim definitely wants to take on the same set as the spokes are tightened. I'm thinking I should accept the 1/16" vertical runout and be done with it. What do you think?
Re: Spoke Tension - [Re: Mattsta] #405891
11/27/11 6:28 pm
11/27/11 6:28 pm
John Healy Online content
John Healy  Online Content
Mattsa try:
www.tioc.org/lacing371007rim.htm
One of the secretes of wheel building is to get both the alignment (offset) and truing set BEFORE you start tighten the spokes. You only need 12 spokes (six on each side) do get your initial setting. The key is not force the rim by tightening, but try loosing the opposite first. More lacing problems are caused by a couple of spokes that are over tightened. Evening tightening is the rule. This means loosening must be a part of the job.
If you are forcing a rim you do not have a handle on what you are doing.
Re: Spoke Tension - [Re: John Healy] #405903
11/27/11 7:18 pm
11/27/11 7:18 pm
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
Hi John
They definitely aren't over tightened.
The point I was trying to made is that the wheel does have a distinct flat spot in the rim and I'm not sure that I can do much to resolve it. I understand what I need to do to correct a vertical runout but I'm not convinced it will improve things very much.
Re: Spoke Tension - [Re: Mattsta] #406041
11/28/11 2:46 pm
11/28/11 2:46 pm
Mattsta, depending on how much of a flat spot, I think that it's not uncommon for steel rims to have as much as .060" of deviation from round at the weld. IME, this seems to be worse in the axial direction. If you can get runout better than that, that's great but I find that for a street bike it's hardly an issue. In general, I find alloy rims to be much better in this regard, both original borranis and excels seem to be very good.
And yes, you should have uniform tension all around, regardless of offset, etc.
Re: Spoke Tension - [Re: Alex] #406054
11/28/11 4:00 pm
11/28/11 4:00 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
Agreed with Alex, the weld area of all the new rims I've bought recently have not been as uniform as the old originals they've replaced.
This said, the only part of the wheel rim to measure during truing is the seating area, where the tire/rubber actually locates. When the wheel's inner faces run true, you may be surprised by the axial runout of the external faces, but that is not all that important on a road bike.
By all means however, do what you can with the spokes to eliminate "hop", since that will be annoying in use.
.. Gregg
magneto@spyder-it.com
Re: Spoke Tension - [Re: Alex] #406208
11/29/11 10:38 am
11/29/11 10:38 am
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
Hi Alex
Actually, the rim is a new Morad Alloy, the unvalenced type.
I have got consistency for about 2/3 the circumference, then the rim deviates to about 20 thou in both directions until it meets a flat spot about 2.5-3" wide in the area where the rim is welded together. In this zone, the runout is quite noticeably more prominent, over 40 thou (1mm.............annoying!
I wont be able to correct this flat spot but I think I can improve the deviation on either side
Re: Spoke Tension - [Re: gREgg-K] #406209
11/29/11 10:42 am
11/29/11 10:42 am
Surrey UK
Mattsta Offline OP
Mattsta  Offline OP
Surrey UK
.. Gregg
Gregg
Yes, good point about measuring the deviation where the tyre seats in the rim. I will reset my truing stand and check it from there instead.
Re: Spoke Tension - [Re: Mattsta] #410046
12/23/11 11:50 pm
12/23/11 11:50 pm
Mercer Island, WA / Austin, TX
Rick in Seattle Offline
The thumb of an American male can exert 10 pounds of force (easy to check with a fish scale). Placing the thumb on the spoke wrench 3 inches from the spoke and pressing down (thumb only, no wrist, no arm) will produce a repeatable 30 inch-pounds of torque on the spoke nipple. As many others have pointed out, iteration is the key to an accurate and safe wheel tuning; approach the 30 inch-pound limit slowly, after several iterations.
Rick in Seattle
1970 BSA 441 Victor Special
1972 Norton Commando 750 Combat
1975 Norton 850 Commando Mk3
1960 Triumph TR3A
Re: Spoke Tension - [Re: Rick in Seattle] #410410
12/26/11 11:55 pm
12/26/11 11:55 pm
pachy Offline
pachy  Offline
Have you a chart showing other countries thumb strength ?
laughing
Re: Spoke Tension - [Re: pachy] #410967
12/31/11 12:05 am
12/31/11 12:05 am
Patchy,
I came up with this "calibrated thumb" idea years ago in grad school. Several of us were building a gas laser and needed to quickly sort through a box of unmarked metal bellows of differing spring constants. The method was remarkably consistant over the half-dozen researchers on the project, say within 20%. Alas, the group was 100% American male, hence my disclaimer. However, I'd be happy to add your result to the data base, to give it an international flavor. Remember, no wrist, no arm.
Rick in Seattle
1960 Triumph TR3A
Re: Spoke Tension - [Re: Mattsta] #410969
12/31/11 12:43 am
12/31/11 12:43 am
Springfield Nebraska
Richrd Offline
Richrd  Offline
spoke tension is measured in INCH pounds. there are specially designed spoke torque wrenches. the threads need to be lubed, ESPECIALLY if stainless.
too tight and you have a very real chance of breaking a hub flange. the torque specs listed on some sites (such as buchannans)are for modern bikes and are double to triple what old brits can take.
too loose and the spokes will weaken from flexing and possibly break.
don't try to "true" the weld.
a spoke will start to "ring" at as little as 10 inch pounds.
have fun.
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: Spoke Tension - [Re: Mattsta] #412293
01/08/12 11:40 am
01/08/12 11:40 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Know this doesn't answer your principal question.
I was talking to a wheel builder 2 days ago. His business is only doing spoked wheels. I was asking about Morad rims for my current project. He said Morad rims tend to be 'less true' around the weld than say (his example) Excel rims.
I did a Morad flanged rim for the back of my A65. It had some residual axial runout at the weld. Can't quote a figure though, but probably in the order of what you mention. And this was likely measured on the outer rim not the seating point for the tyre. This did not extend very far around the rim and was pretty much restricted to the weld. When the tyre was fitted there was no runout on the tyre at that point. You may not need perfection, but my guess would be that is conditional on how far around the rim the runout extends.
So, as other suggest this may not be a drama for a road bike
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Spoke Tension - [Re: Mattsta] #412300
01/08/12 1:27 pm
01/08/12 1:27 pm
For Stainless nipples, and stainless rims using chrome/zinc plated nipples, it is especially important to lubricate the shoulder of the head of the nipple where it bears on the rim.
Page Time: 0.315s Queries: 15 (0.008s) Memory: 1.1931 MB (Peak: 1.5433 MB) Zlib disabled. Server Time: 2018-04-20 20:03:55 UTC
