Mike Austin
Mike Austin
Murrieta California
201 registered members (79T140E), 2,151 guests, and 558 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
NickL 86
koan58 85
Lannis 81
504,269 mail-order LSR
Topics66,036
Posts639,165
Members10,077
Quick question A65 timing with STROBE light, mark on Rotor #40984
07/22/08 7:27 am
07/22/08 7:27 am
Auckland NZ
Ignoramus Online content OP
Ignoramus  Online Content OP
Auckland NZ
with the latter model A65's (std set up points ect not Boyer) Lucas provided a mark on the Alternator Rotor which lines up with a pin in the drive side cover for ignition timing.
My faltering memory tells me that this mark when checked with a strobe light (timing light) should be in line with the pin at FULL ADVANCE (37 crank angle before TDC)
IE the idol position (full retard, 12 dergrees before TDC) will show the line up with the strobe ANTI-clockwise (to the right of the pin) and move towards the pin as the revs are increased
The line is the full advance mark lined up with the pin??
I am right arnt I???
Havent checked it in ages and have borrowed a good timming light just for a couple of days
Thanks Guys
Re: Quick question A65 timing with STROBE light, mark on Rotor #40985
07/22/08 10:15 am
07/22/08 10:15 am
BSA_WM20 Online content
BSA_WM20  Online Content
The pin should line up with the mark @ full advance.
There are several places for the pin to be located depending upon which engine the cases became a part of.
All Lucas motorcycle alternator rotors have the same shaft size & taper so they are all interchangeable so some of the wrong marks could end up behaving in the manner you describe but it was not by intentional ( nor intellergent) Design.
It is always prudent to check that the timing marks you are using are correct for your engine as there is a good chance that the rotor it is wearing now is not the same one it left the factory with.
Could not count the number of owners who cursed Boyer up hill & down dale because they just could not get their A 65 to run only to find that they were trying to time it to Triumph ignition marks.
Re: Quick question A65 timing with STROBE light, mark on Rotor #40986
07/22/08 1:12 pm
07/22/08 1:12 pm
That's right, Ig. Just make sure the pin is in the right place for an A65. A50 use the pin in another hole...less advance that is.
Re: Quick question A65 timing with STROBE light, mark on Rotor #40987
07/22/08 7:44 pm
07/22/08 7:44 pm
Auckland NZ
Auckland NZ
Thanks Alex and Trevor, It was just doing my head in thinking about it, couldnt remeber if it was Idol mark or full advance mark..I have the earlier shop manual that doesnt cover that year...and wanted to get it clear in my mind before i applied the strobe.
Good point about the rotor/case not being ex factory, as a general case, but on this bike I have owned it from new and never changed either
Thanks again for your conformation.
BTW Trevor I fixed the strange coil sparking prob you made helpfull comments about..just loose and dirty conectors..they did look ok however. Eyes detereorating eh.
Re: Quick question A65 timing with STROBE light, mark on Rotor #40988
07/22/08 8:05 pm
07/22/08 8:05 pm
, Lower -Lower michigan
Bob S Offline
Bob S  Offline
Do A SEARCH!!! 'Its all under search; "timeing" I put these guys thru this a short time ago.You will find everything you need to know.......as i didn't know anything ignoramus
bob s
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
Re: Quick question A65 timing with STROBE light, mark on Rotor #40989
07/22/08 8:19 pm
07/22/08 8:19 pm
Auckland NZ
Auckland NZ
BSATRI32
I did a search before I posted ...I dont think im to good on using the search feature ....couldnt find much...tried searching "a65 timming" "a65 strobe marks" A65 rotor advance ect ect ...I knew there would be stuff on here but just couldnt find it. I mainly found stuff about Boyer...will try again as I copy stuff onto a file for referance latter...specialy pics cheers
Re: Quick question A65 timing with STROBE light, mark on Rotor #40990
07/27/08 11:55 am
07/27/08 11:55 am
fairport new york
richard p Offline
richard p  Offline
fairport new york
Another thing I would mention..... I have had trouble with the newer induction type strobe lights..... would not always work! I have since bought an "old school" type..... and it works much better.
Page Time: 0.208s Queries: 14 (0.007s) Memory: 1.0345 MB (Peak: 1.1986 MB) Zlib disabled. Server Time: 2018-02-23 06:23:05 UTC
