YankeeJerry
YankeeJerry
Connecticut
25 registered members (Al Eckstadt), 195 guests, and 443 spiders.
10257 Registered Users
Stuart 75
Lannis 56
610,370 mail-order LSR
Topics67,139
Posts651,527
Members10,257
Help, exhaust pipe loose in head, is there a fix? #317111
06/05/10 9:13 pm
06/05/10 9:13 pm
Birmingham, UK
Rob_Heap Offline OP
Rob_Heap  Offline OP
Birmingham, UK
Hi all, need some help again from you generous folks...
My left hand exhaust pipe is loose in the head and blowing, bike is a 71 TR6 with the push in pipes.
Tried giving the pipe a whack with my rubber hammer but no go, still loose. Can't see any wear marks in the port but suspect it may still be worn. The pipes are none-original and don't have a balance pipe, I do have the original pipes but looking at the marks the PO also had this problem. oddly enough the right side seems ok.
I seem to remember a company in the UK that has a fix for this using a collar with a couple of studs tapped into the head but cant find a link to the company. Failing that is there a simple fix, maybe some sort of exhaust cement?
1971 TR6R Rolling restoration
07 Harley FXSTC 96ci
86 Kaw**ki GPZ900R that has to go...
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #317123
06/05/10 9:43 pm
06/05/10 9:43 pm
Charleston SC
Ob1quixote Offline
Ob1quixote  Offline
Charleston SC
Maybe this tool, carefully and cautiously applied?
http://www.amazon.com/gp/product/B000BN3...Z685230SBMWCMDG
When singing "Kung Fu Fighting" is outlawed, only outlaws will sing "Kung Fu Fighting"
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Ob1quixote] #317143
06/05/10 11:19 pm
06/05/10 11:19 pm
Melbourne Fl
Terry_tr6 Offline
Terry_tr6  Offline
Melbourne Fl
help me out. i thought the 71 tr6's had the spigots that threaded into the heads and the pipes were clamped to them. Were there different versions? Maybe european distribution vs US ?
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Terry_tr6] #317147
06/05/10 11:32 pm
06/05/10 11:32 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
We fix a lot of BSAs in our shop. They always used the slip-in system too. We've been wiping the inside of the head and the end of the pipe with regular GE silver silicone sealer from Home Depot for 15 years or more.
It works great. If you'll wipe off the excess and just let it sit to cure it will be invisible when finished. It will last up to a year and it doesn't blow out. After a year you'll need to take your pipes off for something else and you simply seal 'er up again.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Help, exhaust pipe loose in head, is there a fix? [Re: RF Whatley] #317149
06/05/10 11:40 pm
06/05/10 11:40 pm
Birmingham, UK
Rob_Heap Offline OP
Rob_Heap  Offline OP
Birmingham, UK
Deffo no spigots, bike is registered as a 71, it's a first generation OIF.
That explains why it had traces silicone on the pipes when I got bike, must say I'ma amazed that silicone can stand up to the heat and the pressure....
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #317156
06/06/10 12:09 am
06/06/10 12:09 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
There's no real pressure and the heat is only about 350F.
RF Whatley
Cornelia, GA
Re: Help, exhaust pipe loose in head, is there a fix? [Re: RF Whatley] #317220
06/06/10 1:32 pm
06/06/10 1:32 pm
Birmingham, UK
Rob_Heap Offline OP
Rob_Heap  Offline OP
Birmingham, UK
Cheers RF, that's saved me a few bob and a lot of work. The bike is just starting to come together after an extended de-bodge so I really didnt need another lay up of the bike.
Ive traced this Loctite high temp stuff that looks suitable Loctite Premium Silicone 5920 ,can get locally for about five quid.
Suspect that my recent antics while travveling to work on the bike are the cause of the blowout, holding 85mph on the highway and occasional blasts up to the ton to test my bicyle speedo .. ahem...
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #317231
06/06/10 3:16 pm
06/06/10 3:16 pm
Rhode Island
cabletech Offline
cabletech  Offline
Rhode Island
I have used J B Weld and it worked great. After two seasons with out a leak the pipes came off with quite some resistance.
None of the JB material was permanently bonded to the pipes or head.
http://jbweld.net/index.php
1983 Husqvarna WR430
1973 T150
1974 T150
1975 T160
1975 T160
I'm now a triple Freak!
Re: Help, exhaust pipe loose in head, is there a fix? [Re: cabletech] #317274
06/06/10 7:41 pm
06/06/10 7:41 pm
Reading UK
twinspin Offline
twinspin  Offline
Reading UK
Originally Posted By: cabletech
None of the JB material was permanently bonded to the pipes or head.http://jbweld.net/index.php
How did you manage to achieve that? I don't think that I would recommend that if I wanted to remove them again sometime. Silicone works a treat.
1971 T100R
1970 T120
Re: Help, exhaust pipe loose in head, is there a fix? [Re: twinspin] #317277
06/06/10 7:57 pm
06/06/10 7:57 pm
Birmingham, UK
Rob_Heap Offline OP
Rob_Heap  Offline OP
Birmingham, UK
Found the link for the exhaust seal kit Push-in Exhaust Seal Kit anyone tried these?
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #317293
06/06/10 9:12 pm
06/06/10 9:12 pm
England
Paul744 Offline
Paul744  Offline
England
Hi Rob,
that looks like the kit from Final Cut Engineering & I know several people who use it and are very happy with it.
Re: Help, exhaust pipe loose in head, is there a fix? [Re: twinspin] #317296
06/06/10 9:26 pm
06/06/10 9:26 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
And if purchased in a silver color is invisible.
RF Whatley
Cornelia, GA
Re: Help, exhaust pipe loose in head, is there a fix? [Re: RF Whatley] #317356
06/07/10 11:08 am
06/07/10 11:08 am
Reading UK
twinspin Offline
twinspin  Offline
Reading UK
There are a lot of different types of silicone sealant with different properties and in this area probably most types will suffice and I am sure that Richard's silver seal serves the purpose and cosmetically is agreeable. I personally find that in the UK high temperature clear silicone adhesive as sold by Maplin is ideal. It seems to possess extra tackiness and doesn't sag like some types. Any excess can be easily wiped away using a cloth and white spirit. Being clear also makes it hard to see where it has been used.
1971 T100R
1970 T120
Re: Help, exhaust pipe loose in head, is there a fix? [Re: twinspin] #317608
06/08/10 7:23 pm
06/08/10 7:23 pm
Birmingham, UK
Rob_Heap Offline OP
Rob_Heap  Offline OP
Birmingham, UK
It works!
Used Loctite 595, temp up to 250C and a gap upto 8mm, left it to harden for a couple of days.
Must say I didnt realise just how tough this stuff is, or that there are so many types.
Many thanks to all for the advice beerchug
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Paul744] #408604
12/14/11 2:04 am
12/14/11 2:04 am
John Henry Offline
John Henry  Offline
Hello everybody. This is actually my first post to the site....
Does anyone have more feedback/info on the push in pipe seal kit? Do you have to modify the head at all? If I switched to a different set of headers down the line, could I use the kit again? Does the kit really work? Thanks for the help!
Re: Help, exhaust pipe loose in head, is there a fix? [Re: John Henry] #408619
12/14/11 7:12 am
12/14/11 7:12 am
redondo beach, ca
Bob G Offline
Bob G  Offline
redondo beach, ca
Another option to consider is the spigot conversion kits that let you use 70 and earlier pipes.
Bob Gregor
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Bob G] #408741
12/15/11 4:55 am
12/15/11 4:55 am
John Henry Offline
John Henry  Offline
I thought about the spigot conversion, but I'm not quite ready to buy new headers yet.
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #408784
12/15/11 4:17 pm
12/15/11 4:17 pm
FWIW: My A65 has been converted with the spigots. Previous owner says the ports were wallowed out. Previous owner also used hi-temp JB Weld to install the adapters. Result? RH pipe blew off at speed!
I had the adapters welded in place.
Re: Help, exhaust pipe loose in head, is there a fix? [Re: cabletech] #408870
12/16/11 3:02 am
12/16/11 3:02 am
DPO Offline
DPO  Offline
I Love JB WELD! I used it to stop a pesky "seep" coming from my OIF tank where the swingarm is welded. We re-welded best we could, but still had a small seep. Coated entire area with JBW, and have'nt seen a trace, totally dry over a year now....
1971 Triumph T120
2005 Triumph "America"
1976 BMW R90/6
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #408881
12/16/11 4:44 am
12/16/11 4:44 am
So, who needs fasteners? We got JB Weld and sillycone!
All I know is if that head pipe had gotten under a wheel at 75mph I would not be typing this now.
Proceed at your own peril!
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #408921
12/16/11 2:38 pm
12/16/11 2:38 pm
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
I'm confused, my 71 OIF Trophy has spigots, Motor is original and has never been apart, only 12k miles. So did Triumph switchover at some time to do away with spigots during 71?
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #408946
12/16/11 5:46 pm
12/16/11 5:46 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
Triumph changed the head to this set-up in Dec.1971(XG),but this of course was in the 72 model year. Jack
Re: Help, exhaust pipe loose in head, is there a fix? [Re: Rob_Heap] #408954
12/16/11 6:26 pm
12/16/11 6:26 pm
Deltona, FL
lrutt Offline
lrutt  Offline
Deltona, FL
ok, clears that up, thanks
1970 Tiger
1971 Trophy
1973 Commando
1976 CB750k
1965 CA77
1978 CB750k
1970 T250II
1971 RT1B
1977 Lemans
2001 M900
2001 XR650L
1994 FLSTC
2006 XL1200C
1984 XV1000
1981 C70
1973 Z50
1989 Hawk GT
2006 Scrambler
1970 CT90
1965 CT200
1977 R75/7
