Dave Lid
Dave Lid
West Midlands UK
34 registered members (998John), 168 guests, and 68 spiders.
10381 Registered Users
Mori55 94
NickL 93
Stuart 86
DavidP 77
reverb 69
Triless 68
Rohan 65
688,696 mail-order LSR
Topics68,014
Posts661,634
Members10,381
Page 2 of 2 1 2
Re: 1973 T140 rocker spindles. Oil grooves? [Re: Coco] #407960
12/09/11 5:30 pm
12/09/11 5:30 pm
Regina Sk, Canada
Coco Offline OP
Coco  Offline OP
Regina Sk, Canada
I am finally getting my rocker boxes back together and want to put my new top end on this weekend.
Just to recap:
Move thackary washer(spring washer)up against inner rocker box and have flat washers butted up against the ends of rocker arm.
Do I need to add an extra washer between the spring washer and inner rocker box? It seems the end of the spring washer can dig into the aluminum inner surface of the rocker box.
I read somewhere to buy a couple extra 1/2" ID washers (which I did) and I can't recall what I'm supposed to do with them or where they go.
Colin
1975 MKIII Norton Commando
'73/'70 Triumph 750 chop in the works
Re: 1973 T140 rocker spindles. Oil grooves? [Re: Coco] #407977
12/09/11 7:33 pm
12/09/11 7:33 pm
JubeePrince Offline
JubeePrince  Offline
Correct.
No. It seems like that is what will happen, but in fact will not.
They replace the 3/8" washers (2) that originally came with the asssembly(ies). If you look closely at the spindle, there is a step/shoulder near the threaded portion of the spindle. When you move the thackery further toward the end of the spindle, the flat washer needs to be 1/2" to clear the step/shoulder.
HTH,
Re: 1973 T140 rocker spindles. Oil grooves? [Re: JubeePrince] #408064
12/10/11 3:49 pm
12/10/11 3:49 pm
Regina Sk, Canada
Coco Offline OP
Coco  Offline OP
Regina Sk, Canada
Correct.
HTH,
Steve, that helps so thanks for the info.I had one assembled and I did it the right way. I just wanted to make sure before I push it all in and get the o-ring seated in there.
Colin
Page 2 of 2 1 2
