Lucky Strike
Lucky Strike
Houston, Texas (West end of the Heights)
37 registered members (Bigtwin), 260 guests, and 407 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 98
Stuart 83
reverb 80
NickL 73
koan58 56
549,657 mail-order LSR
Topics66,547
Posts645,104
Members10,170
porting a t120 #406060
11/28/11 4:33 pm
11/28/11 4:33 pm
devon
kevin large Offline OP
devon
hi guys while i have the head off for twin pluging i would like to gas flow the ports any tips diagrams etc for best port shapes
Re: porting a t120 [Re: kevin large] #406070
11/28/11 5:33 pm
11/28/11 5:33 pm
John Healy Online content
John Healy  Online Content
For typical applications, including road racing, the ports are to big already. Get someone to do a good three angle valve job with a single point machine like a Serid or Newan and leave the ports alone.
To get an significant performance gain from a T120 head requires a lot of welding, especially on the exhaust port side.
Just my opinion!
Re: porting a t120 [Re: kevin large] #406128
11/28/11 9:48 pm
11/28/11 9:48 pm
How about spending the porting money on a 750cc conversion, to make better use of the ports you have?
Re: porting a t120 [Re: kevin large] #406137
11/28/11 10:37 pm
11/28/11 10:37 pm
Triton Thrasher: Bingo!!
Re: porting a t120 [Re: kevin large] #406176
11/29/11 2:41 am
11/29/11 2:41 am
Charlotte NC
RHall-HCV Offline
RHall-HCV  Offline
Charlotte NC
It depends on which T120 head you have....some were terrible on the intake side. The exhaust could definitely use to be welded but that requires seat removal and lots of work. That time is better spent on a stepped header system that will build velocity that is lost in the large ports. Several things to do to make a Triumph better. But a 750 with the right cams in the right place and some 34mm carbs on a good head can make 70hp on pump gas.
ROB HALL
HCV MOTORSPORTS
Re: porting a t120 [Re: kevin large] #406179
11/29/11 3:27 am
11/29/11 3:27 am
bon Offline
bon  Offline
I was always of the impression that the early bonnevilles were faster because the inlet ports were smaller and of a more suitable size to the capacity of the engine , compared to the later machines.
When i did my head all i did was to make sure there was no noticeable step between the inlet stubs and the head casting. Stan shentons book tuning triumphs has a chapter on cylinder head work and he doesn't recommend doing much more then that.
Re: porting a t120 [Re: kevin large] #406655
12/01/11 11:57 pm
12/01/11 11:57 pm
terra Australis
Pre Unit Offline
Pre Unit  Offline
terra Australis
the ' Tuneing Triumphs ' by Stan Shenton , of Boyers of Bromley .
is back in print .
Yes , its more 'cleaning up ' in respect of detail .
The porting in common with very few vehicals is pretty much right
as built .
However putting 1 9/16 int and 1 7/16 ex valves from a 750
in a 8 stud Bonneville head , will get them sitting out on
the unsunken area of the seats.
'Tuliping ' back , will get more advanced flow. A std. 3 angle
is a bit primitive.
P.M. for ' other ' details .
Mortified at a head shop newly taken over , that was once the best in N.Z. , as the propritor handed over a Bonne head to a
greaseball , with the words " Yea , those Triump Heads are pretty rough standard " .
A quick glance revealed he'd buggered the head and the two ports were butchered diferantly .
Not particularly unusual .
If youve got Monoblocks , theres a chance youll get it to carburate smoothly .
Substantial gains in output can be gained with exhaust modifications, and superb acoustics .
Re: porting a t120 [Re: John Healy] #406709
12/02/11 11:27 am
12/02/11 11:27 am
I only knew that because you wrote it here!
Re: porting a t120 [Re: Pre Unit] #406711
12/02/11 11:33 am
12/02/11 11:33 am
You make a good point: we're jumping to the conclusion that he has a big valve 650 and maybe he hasn't.
Putting those big valves you talk about into a Pre-unit head can also give the engine some power characteristics that the rider won't like. But I suppose you can say that about any speed tuning that actually has an effect.
Re: porting a t120 [Re: triton thrasher] #406955
12/04/11 1:27 am
12/04/11 1:27 am
terra Australis
Pre Unit Offline
Pre Unit  Offline
terra Australis
Warp Facor Six , Scotty !
Re: porting a t120 [Re: kevin large] #407640
12/07/11 7:39 pm
12/07/11 7:39 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
I think it's worthwhile tapering the intake guide,where it enters the port.I finish it to about 0.030"-0.040" wall thickness on the end.
Intake valve shape is good,but I still do a 35 degree back-grind to get 0.060" width on the contact face.
The O.D. of the valve seats would be 0.020"-0.030" less than the valve-head diameter,with a seat width 3/32".
If you want more flow,the only thing stopping it is valve-lift.The 1-1/8" port diameter is plenty big enough.1/2" valve-lift would not be wasted,if you want to take advantage of the port size.At 1/2" valve lift,you could justify removing a small amount of metal near the valve-guide,to keep up with the rest of the port.Other parts of the port will still be too big.Where was the flow-bench when they made these ports? Did they just not know how to use it?
You're not likely to get 1/2" valve-lift,without some serious work. 0.400" lift,or less,is more practical.The port will still be too big everywhere,and the valve is choking it.
The port is just plain too big when you get within 1/2" of the valve seat.How much you can fill it in without losing flow depends on your valve-lift.1-3/16" diameter,or equivalent area,would be about right.
Anyone have any better ideas?
Re: porting a t120 [Re: kevin large] #407658
12/07/11 9:07 pm
12/07/11 9:07 pm
As far as port size goes a sewer pipe can flow a lot of air, but lacks velocity.
In a comparison to our ports. A big port might flow a lot of air, but if the velocity is low the valve will close before you can get all that air moving. Tuners today are looking for air velocity of .5 MACH.
Put your engine specs into this calculator and play around with port diameters:
http://www.wallaceracing.com/machcalc.php
or if this has turned into a sickness get your wallet out and try:
http://www.maxracesoftware.com/pipemax36xp2.htm
Page Time: 0.071s Queries: 15 (0.007s) Memory: 1.0750 MB (Peak: 1.2890 MB) Zlib disabled. Server Time: 2018-04-20 18:05:11 UTC
