chris b33
chris b33
oregon usa
46 registered members (Adam M.), 192 guests, and 56 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,140 mail-order LSR
Topics68,856
Posts670,718
Members10,478
Meriden Thruxton 650 engine spec #381074
06/27/11 6:56 am
06/27/11 6:56 am
Cheshire UK
Phatt Bob Offline OP
Cheshire UK
Hi all,
Does anyone have access to the engine spec for any of the factory Thruxtons made in the 60's. Info seems to be vague from the usual sources. I don't suppose there are any big secrets we haven't stumbled across already, but it would be nice to see them all in one place.
Looking for things like compression ratio, ignition timing etc. Service sheet 310 is OK so far as it goes for cams and followers etc but were any others fitted? Also to what extent was any lightening work carried out on the top and bottom ends? I once one had a "Thuxton" crank with a very narrow flywheel.
Any advice gratefully recieved.
Thanks and regards
Phatt Bob
'95 Daytona 1200
'98 Daytona 1200 dragbike
ex-850 T140 Caff Racer, 850 Triton, Morgo T120, Starfire and Pretend Daytona 500 owner
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381076
06/27/11 8:03 am
06/27/11 8:03 am
back down the 'smoke',England
6T Offline
6T  Offline
..can't help much regarding internals,mines only done 500(none racing)miles but its got the morgo 750 kit & quaiffe 5 speed box..here's some photo's.Notice the pushrods that had not seated properly in the standard rockerboxes,more on that later(another thread)Cheers...[Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image]
T120R '67
6T 1965
T110 1958
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381082
06/27/11 9:58 am
06/27/11 9:58 am
melbourne, australia
7
76degree-triumph Offline
Gday Bob, years ago I bought a genuine Boyer race engine. Its fitted with the 3" radius followers but what was not mentioned in his book was the tube connecting the inlet followers to the exh to feed oil to the inlet side.
As I understand it the thruxton cams were part #E4220. These were also listed as T-Bird cams in 1961 or 62 for a short time. Ive got a set here but they have worn the nose off them.
This engine came with the "spitfire" cams, as per the Boyer book, not the 4220's.
Cam timing was IO 51 IC 72. EO 83 EC 47. All @.020".
I dropped those cams into my T140 road bike, it transformed it.
I have a 4220 cam on the inlet of my dirtbike but I cant find the timing events. It uses 'R' followers.
If you are interested I will try and dig them up.
1950 Speed Twin outfit
1951 Thunderbird outfit (76 degree racebike, or is it 90 deg now?)
1955 BSA D3 minibike outfit
Triumph solo's
Re: Meriden Thruxton 650 engine spec [Re: 76degree-triumph] #381088
06/27/11 10:39 am
06/27/11 10:39 am
Cheshire UK
Cheshire UK
Thanks 6T and 76degree-triumph, this is exactly the sort of info I'm looking for.
6T, those look like mushroom headed tappets. Do you know if they were an original fitment or aftermarket? Also polished and shimmed rockers as I would have expected.
76DT, I once owned a set of thruxton tappet blocks in alloy bronze IIRC, they were bigger and slot machined for the 3" tappets was wider in the front to back dimension, it's hard to tell from the photo, but are the tappets longer than the 3059s? Also are they dome headed or cupped at the other end. I was told that if you used the shorter 3059s with 4220s the leading edge would dig in. Never actually got chance to try it. I've got a 4220 also, but assumed if the block needed machining to fit a bigger guide block, T140 inlets would have been simpler.
Thanks again all.
Phatt Bob
'95 Daytona 1200
Re: Meriden Thruxton 650 engine spec [Re: 76degree-triumph] #381089
06/27/11 10:42 am
06/27/11 10:42 am
6T Offline
6T  Offline
...I see Morgo do the Thruxton tappet blocks but the barrels have to be machined!
http://www.morgo.co.uk/tappet.html
T120R '67
6T 1965
T110 1958
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381090
06/27/11 10:46 am
06/27/11 10:46 am
6T Offline
6T  Offline
..I don't have special pushrods in mine but THINK the Thruston used triunph 250 ones moded?Have you got the Stan Shenton book?Cheers..
T120R '67
6T 1965
T110 1958
Re: Meriden Thruxton 650 engine spec [Re: 6T] #381103
06/27/11 12:20 pm
06/27/11 12:20 pm
Cheshire UK
Cheshire UK
Hi mate, yes, I have got it, but until you mentioned I'd forgotten...its me age.
It shows the flywheel and tappets etc quite nicely, but I reckon both the cams it shows are the same profile......
The reason I ask this is that I have an acquaintance who has a "Thruxton Spec" 69 Bonneville. I'm beginning to wonder if "Thruxton Spec" is a bit variable apart from all cosmetic bits!
Phatt Bob
'95 Daytona 1200
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381130
06/27/11 2:10 pm
06/27/11 2:10 pm
6T Offline
6T  Offline
..I remember the quip quite well.. Stan Shenton told his employees.. "The Thruxton Bonnevilles arrived!!" to which someone said "but its not a works Thruxton is it!".....
T120R '67
6T 1965
T110 1958
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381303
06/28/11 9:01 am
06/28/11 9:01 am
New Zealand
Trevor Stapp Offline
New Zealand
Bob,
Check out http://www.hoppybikes.co.uk/
Talk to George Hopwood, great guy and wealth of infor.
Spannered back in teh 60's on Thruxtons.
Trev
66T100SR Cafe racer
59 T20 Cub
1938 - 53 5T Bitsa project, now a roller
Duplex frame under the bench
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #381308
06/28/11 10:29 am
06/28/11 10:29 am
7
Bob, Ive used the 4220 on the inlet for many years with 'R' followers with no probs or abnormal wear whatsoever. They are in a unit engine with a T140 topend and norton crank and rods.
STD T140 guide blocks.
The thruxton followers in the front to back dimension are around 1/8th longer then std or 'R'. They are in my 650 race engine at the moment so I cant measure them.
They are dome headed and although I have not measured the length the pushrods appear to be STD 650 items.
I hope this helps,
Chris.
Triumph solo's
Re: Meriden Thruxton 650 engine spec [Re: 76degree-triumph] #381487
06/29/11 7:13 am
06/29/11 7:13 am
Cheshire UK
Cheshire UK
Thanks again folks,
Grumpy Trevor,
Funnily enough, this IS one of George Hopwoods motors, with the 3" followers and Spitfire (E6897 and 8 or his version) cams not E4220s, but sold to my mate as a Thruxton spec motor. Hence my question about what the spec was. Cam timings are similar for inlet but not exhaust, so they're obviously different beasts.
When is a Thruxton not a Thruxton? Does it need to have Thruxton cams to be a Thruxton, or just the word from an authoratative figure (e.g. Hoppy) that it can be considered a Thruxton.
I'm beginning to suspect the answer......
Phatt Bob
'95 Daytona 1200
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #404526
11/19/11 9:38 am
11/19/11 9:38 am
uk
Steve69 Offline
Steve69  Offline
uk
I tahe a copy of the alternative parts list for the 1964 thruxtons
if anyone is interested I could scan it. I have nothing for the
later thruxtons though I'am afraid.
-Steve
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #404595
11/19/11 7:54 pm
11/19/11 7:54 pm
HawaiianTiger Offline
When I was restoring my '62 6T I hunted the world wide for E4220/1 cams and came up short. No wonder. Only later did I discover that these cams were the same cams used in the Thruxton. They must be coveted by collectors and classic racers. I ended up installing T110 cams and was never satisfied.
E4220 cams are ramped cams and I'm sure by then folks were discovering that the ramps were easier on valve train components. I have saved my cams even though they were not usable in my engine having rusted too much. I would like to have them duplicated and use them in a street rod.
Re: Meriden Thruxton 650 engine spec [Re: Phatt Bob] #404673
11/20/11 10:33 am
11/20/11 10:33 am
6T Offline
6T  Offline
Hi Bill,look up "David Newman camshafts" of Orpington,Kent... He's refaced cam followers for me,very good service and reasonable price... It wouldn't be too expensive to ship your cams,would it? Cheers!
T120R '67
6T 1965
T110 1958
