Kevin (NZ).
Kevin (NZ).
Christchurch, NZ
29 registered members (998John), 196 guests, and 443 spiders.
Mickeyrat, Gtommy, Stew Dempsey, JoeBrown, Bart223
10176 Registered Users
Lannis 105
reverb 90
Stuart 68
koan58 68
L.A.B. 54
555,042 mail-order LSR
Topics66,612
Posts645,585
Members10,175
A10 Belt Drive #402797
11/09/11 2:03 am
11/09/11 2:03 am
The land of pleasant living
Z
Zimm Offline OP
Zimm  Offline OP
Z
Anybody running a belt drive/modern clutch set up on their A10? I'm thinking of going that way, and would be interested in other's experiences.
Sources and pricing would be nice to hear about too.
Zimm
Re: A10 Belt Drive [Re: Zimm] #402811
11/09/11 3:31 am
11/09/11 3:31 am
Zimm,
I thought about it too, until I found you had to buy 4 spring parts, to buy the belt drive kit, at around $850, and maybe yet do some fiddling around to get it to work.
Over a grand to get a belt drive clutch?
Not for me. Got better things to spend my boik fund on.
EVERYTHING for the boiks is gettin overly expencive...
Re: A10 Belt Drive [Re: Zimm] #402813
11/09/11 3:48 am
11/09/11 3:48 am
Never have understood "belt drive primaries".
On my bikes that have primary chains, the oil-bath chain primary drive is the longest-lasting and most reliable part of the whole bike. Probably the last thing I'd think about upgrading .....
Re: A10 Belt Drive [Re: Zimm] #402884
11/09/11 5:06 pm
11/09/11 5:06 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Lannis,
Life is full of interesting stuff. I happen to agree with you on the primary and would much prefer to look at little inexpensive changes to the clutch that can vastly improve it's performance...like additional plates or modified pressure plates. OTOH, who are we to say...I love to look at custom bikes and cars. In most cases their owners will go to great lengths and exacting detail to make their bike or car look cool and neat but in the process ruin the ride or at best don't improve it. Choppers and street rods come to mind. If I had a grand or more to invest in bike stuff, I'd probably be looking to find something else to drag home...but to each his own.
Re: A10 Belt Drive [Re: Zimm] #402903
11/09/11 6:56 pm
11/09/11 6:56 pm
Z
Zimm Offline OP
Zimm  Offline OP
Z
One thing I am looking for is a lighter clutch pull. Arthrites in my hands causes things to get sore over the course of a days ride.
Zimm
Re: A10 Belt Drive [Re: Zimm] #402931
11/09/11 11:22 pm
11/09/11 11:22 pm
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
Bob Newby clutch and drive kit. Get it from Frank Dheil 843 520 0481. Best thing I ever did to my DBD! PRT
Re: A10 Belt Drive [Re: pushrod tom] #402938
11/10/11 1:20 am
11/10/11 1:20 am
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
I really dont like the idea of a belt drive primary on a streetbike but having had a carpal tunnel release in both hands I do like a light clutch pull.Quite honestly I think an A-10 with a 6 spring clutch can have a delightfully light pull. I do have a frankenstein project A-10 ,sort of a "what if" bike . On this one I fitted a slave hydraulic cylinder from a Ducati to the clutch release . this was surprisingly simple and a one finger pull .
FWiW-BONZO
Re: A10 Belt Drive [Re: Zimm] #402970
11/10/11 2:14 am
11/10/11 2:14 am
Z
Zimm Offline OP
Zimm  Offline OP
Z
Bonzo:
Got any pics? Sounds like an interesting idea. I've done the carpel release too which was only part of the problem. The meds seem to work OK, but a lighter pull would be nice.
I'm not sure what clutch is in there. Its a 54 and should have the 6 spring, but who knows. The bike has been running well and I have not wanted to pull it apart until winter.
The 6 spring on my M20 is easier to pull than the A10 and works well, once I used a dial indicator to set it up.
Zimm
Re: A10 Belt Drive [Re: Zimm] #403026
11/10/11 2:22 pm
11/10/11 2:22 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
My A65 three spring is not an easy pull. I set it up with a dial and back out the screws as far as possible (until it slips under hard load). I make sure the cable is lubed and as straight as possible but that is about all that can be done.
On my B50 I added a 6th plate. Some of the newer after market plates are thinner and it was possible to add an additional friction disc that greatly increase clutch capacity and permits much lighter lever pull. I haven't tried to nor do I know whether it is be possible on an A65 or A10 but it might be worth investigating. I can send you a writeup if you wish.
Re: A10 Belt Drive [Re: Zimm] #403037
11/10/11 2:21 pm
11/10/11 2:21 pm
I assume it's a swingarm model? A10 plunger clutches can be delightfully light but effective. A dry clutch, all else being the same will always require substantially less pressure to be effective. That's why the plunger clutches and belt drive clutches tend to be much lighter. A belt drive will give you what you want, but it will be expensive....but you already knew that. Careful setup of the stock clutch and extra plates can also improve things....but it will never be as light as a dry clutch.
Re: A10 Belt Drive [Re: Zimm] #403046
11/10/11 3:55 pm
11/10/11 3:55 pm
New York
ShearedCrank Offline
New York
Zimm-
A couple of items that may help:
Use a Nylon lined clutch cable. I very much like Flanders Cables offerings.
Insure your barrel end is free to rotate within the lever. Lube with light machine oil.
Also, I was surprised to find how much different the pull was after I cleaned the operating rod bore (in the transmission) with a rifle brush. I hooked it up to a dewalt drill and ran the brass up and down the bore. I got a LOT of junk out of there.
Afterwards, I polished the operating rod on a wheel (cleaned) and reassembled with grease.
Insuring you have the correct geometry (adjustment) for the operating arm is also key.
I have a BNR belt drive now, but I had the Original 5 spring working with one finger (no slip).
Lastly, if your clutch basket has been abused and has notches in it from the clutch plate, none of the above is going to matter. Its going to fight you.
Matt
Re: A10 Belt Drive [Re: Zimm] #403853
11/15/11 4:36 am
11/15/11 4:36 am
SEATTLE WA
SEATTLE GS Offline
SEATTLE GS  Offline
SEATTLE WA
I have run one on my goldstar and like the fact that there is no oil to leak now. The clutch action is good but it is a new clutch. NO OIL!!!
Page Time: 0.822s Queries: 15 (0.011s) Memory: 1.0728 MB (Peak: 1.2798 MB) Zlib disabled. Server Time: 2018-04-27 06:57:15 UTC
