Les P
Les P
22 registered members (Boomer), 154 guests, and 58 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
Stuart 77
DavidP 72
btour 66
690,412 mail-order LSR
Topics68,045
Posts662,075
Members10,387
69 Victor rear sprocket #400472
10/24/11 6:09 pm
10/24/11 6:09 pm
S.E. Ohio
H
HillbillyBarr Offline OP
H
S.E. Ohio
Hey guys this past weekend i decided to take my 69 Victor out fer a ride since I just got it runnin not to long ago. After a quick trip down the road it was too cold so I headed out to my field and took a lap around a trail I've got. But when I came to the hill I couldn't go up the trail cause my speed in first gear was too high to manuver around the trees.
I decided to see if one of my other Victor projects had a larger rear sprocket and the one on my 67 is a nice big'un. But to be sure i checked the parts books and the 67 and 69 both list the same rear sprocket and chain size which is a 5/8"x1/4". But lookin at the 69 I can see it's got a 530 like my T140V has and the 67 looks to be a 520 as it's definetely skinnier.
Is my parts book wrong or did someone change sprockets for a 530 chain? Thanks, Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400474
10/24/11 6:13 pm
10/24/11 6:13 pm
I believe all B44's came with 520 chain and sprockets.
A nice modification for trail riding a B44 is to put a B25 engine sprocket and primary chain on. That way you don't end up with a ginormous rear sprocket.
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400479
10/24/11 6:45 pm
10/24/11 6:45 pm
kommando Offline
kommando  Offline
All but the early B44's came with 520 chains, early B44 Victor Enduro's with the C15 6" rear brake came with a 428 chain.
Re: 69 Victor rear sprocket [Re: kommando] #400482
10/24/11 6:53 pm
10/24/11 6:53 pm
V
VicCyclone Offline
VicCyclone  Offline
V
So did the Victor GPs have 1/2" X.305 chain with the unfinned 1/2 width hub and the sprocket bolted on from the inside.
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400487
10/24/11 7:09 pm
10/24/11 7:09 pm
S.E. Ohio
H
H
S.E. Ohio
I've got a 66 project that I was gonna start on after this 69 but I wound up with a 73 B50MX so it'll be next. But the 66 has the C15 style rear wheel like Kommando says. The 67 has a huge rear sprocket on it I can swap out on the 69.
Alex I didn't know the B25 was geared lower this way. I'll keep that in mind when I rebuild the engine fe the 67.
Thanks to the both of ya'll as it seems you two answer most of my B44 questions!
I'll check and see why the 69 has the 530 and switch out the 69's rear fer the 67s so I can play in the woods. At 58 I don't care to fly through the woods like I did in my teens! I'd just as soon go slow and not hit stuff. Thanks guys, Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400490
10/24/11 7:29 pm
10/24/11 7:29 pm
S.E. Ohio
H
H
S.E. Ohio
I just went out to the shop and looked at the 69 real close and it's got the wrong chain. I got the 69 from a Harley guy so that could explain the 530. This is great as I can borrow the gear and chain from the 67 as it won't be needin it fer a while. Cheap fix! thanks guys, Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400491
10/24/11 7:38 pm
10/24/11 7:38 pm
kommando Offline
kommando  Offline
Hilbilly, Thats interesting that the 530 fitted, does it rub on the engine castings at all, if it doesn't then you can fit a 520 X ring as that is the same width as a 530 but fits the 520 sprockets. I have a 428 X ring on my 69 Victor as the 66 rear wheel was virtually free.
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400492
10/24/11 7:55 pm
10/24/11 7:55 pm
S.E. Ohio
H
H
S.E. Ohio
I've not got even 5 miles on the bike yet since i got it runnin. I don't hear a chain rub but with the 441's exhaust I don't know if'n I could if I tried.
I'll be puttin the 69 and the 67 on milk crates to change the rear sprockets and I'll check the 69 fer crankcase wear. I didn't notice anything shiny on the chain tho so my guess is it must fit altho it does move side to side a bit. When I pull the chain I'll rub my fingers on the cases and see how things look and tell ya.
I can see why the 66 wheel was darn near free as it's a bit on the heavy side and I was wonderin about how affective the brake is. I hope to git to my 66 soon and bring it back to life. I was gonna swap theat big ol rear hub out with a QD unit but decided to keep it as original as possible.
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400496
10/24/11 8:07 pm
10/24/11 8:07 pm
S.E. Ohio
H
H
S.E. Ohio
Well Komanndo you made me curious so I strolled on out to the shop and took another look at the 69 and since i don't have a chainguard i can see the chain real easy and it doesn't hit a thing. Looks to be all kinds of room there for a X ring chain. The 530 flops from side to side and is a good bit from the cases.
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400505
10/24/11 9:00 pm
10/24/11 9:00 pm
kommando Offline
kommando  Offline
Thanks for the info, the smaller brake is surprisingly good, I can lock the rear wheel with a heavy boot. Alex's C15 MX has the same brake but modified to take the QD hub which should loose a lot of the excess weight.
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400583
10/25/11 2:09 pm
10/25/11 2:09 pm
S.E. Ohio
H
H
S.E. Ohio
Komanndo I've got the BB calander from a couple years back hangin in the shop and it's opened to the page with your bike, GoldstarFreddie's Goldie and GranPauls 441. I had to look real close to see the rear wheel was different. Also noticed your breather mod like the B50s.
I'm gonna swap the gear and rear wheels from the 67 to the 69 as the 67 has a knobby tire. And right after i git back from a ride on the T140V I'm hittin the woods on the Victor! I'll ride it on my property first then hit the big woods behind the house. It's bright and sunny with a high around 67 today. I'm ridin Brit bikes all day!(least ways till my clutch hand gives out!) Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400632
10/25/11 7:27 pm
10/25/11 7:27 pm
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
So, Hillbilly...Where are you in S.E. Ohio? Don't believe I have had the pleasure. Feel free to pm me if you want. If we have met and I forgot, I apologize...
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #400981
10/27/11 5:29 pm
10/27/11 5:29 pm
S.E. Ohio
H
H
S.E. Ohio
No Nome Man (Mr. Bill) I'm around the Lancaster area. Were you the guy at the Lancaster Old Car show with the 69 VS? If so I stopped and jawed with you fer a bit and give you my card. If not then we need to correct this as I've got a couple Victors plus a 77 T140V and always lookin fer someone to ride with.
Now back the the rear sprocket swap. I replaced the 49T with a 64T I had on the 67 and while I was at it I put the 67s 4.00 Metzler knobby on it and Whooooooooooweeeeeee!!!!!!!!!!!! Is this puppy fine! Course I only got a top speed around 45 or so but is it ever fun to race across my field and up through the woods.
Now I gotta do somethin about the 3.25x19 K70 on some unknown rim as it just slids tryin to turn in the wet or even damp dirt. I might leave this gear on through the winter if I git a knobby on the front and maybe take the Victor deer huntin. I always wanted to do that
But in the long run I'd like more highway speed. I found a new lookin 52T layin around here and might slip it on as I'd like to be able to cruise the backroads fer some fishin and maybe wander on up over to the BSA rally in Toronto next spring. Anyone run a 52T? Thanks, Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #401050
10/28/11 3:00 am
10/28/11 3:00 am
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
No Hillbilly...wasn't me. But now that I'm thinkin clearer I believe I have run into you at the Toronto rallies. You gotta be one of the New Lex Comp Riders, right?
Saw your pm...pm-ed back.
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #401097
10/28/11 2:26 pm
10/28/11 2:26 pm
S.E. Ohio
H
H
S.E. Ohio
nope but they've invited me down fer parties and stuff. Have been to Toronto in the past. Just never thought me showin up on a 69 441 Shootin Star would command a pressence around the hogs. I'm sure they wouldn't have minded as Joe asked me to drop on by.
You ride yer 69VS much? Mine had a major oil leak comin from the banjo bolt on the tank after my ride the other day. Still findin loose stuff. Thinkin about takin it out fer a bit to play in the wet. That 19" K70 in the front sucks big time tho. PM'd back Hillbilly
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #401105
10/28/11 3:06 pm
10/28/11 3:06 pm
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
Don't really know any of those NLCRs. Or if any are on this site. But they seem real friendly to me. I had the use of a 441 Shooter in college. Kinda small for the street but a lot of fun. If somebody doesn't appreciate it, let em try to start it!
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: 69 Victor rear sprocket [Re: No Name Man] #401129
10/28/11 5:51 pm
10/28/11 5:51 pm
S.E. Ohio
H
H
S.E. Ohio
Once you know the drill those Shootin Stars and later Victors are easy to start. It's all in that there 12V battery. Course the first time they'd try givin it gas while kickin it would give'em a free trip over the handlebars! Big difference from my T140v!
Re: 69 Victor rear sprocket [Re: HillbillyBarr] #401178
10/28/11 10:04 pm
10/28/11 10:04 pm
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
Yep that's what I'm talkin about...
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
