Marty
Marty
Dorset, England
48 registered members (69BSATONY), 270 guests, and 62 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 97
reverb 83
Mori55 83
Triless 82
Stuart 82
DavidP 74
btour 66
690,301 mail-order LSR
Topics68,041
Posts662,035
Members10,387
Gearbox drain plug thread size? #398314
10/11/11 1:07 am
10/11/11 1:07 am
Effingham, IL
TonyK74 Offline OP
TonyK74  Offline OP
Effingham, IL
I'm in the process of tearing down my '70 TR6 motor for a complete rebuild. After pulling everything from the gearbox I unscrewed the level tube drain plug (T3668). Upon inspection, the plug only has about two threads left near the head of the plug and the threads in the case appear to be stripped. Now the plug won't screw back into the case. My thought is to have the drain hole welded closed and then retap for a new level tube plug. Can anyone tell me what size tap I need for this?
Re: Gearbox drain plug thread size? [Re: TonyK74] #398363
10/11/11 10:46 am
10/11/11 10:46 am
Stuart Offline
Stuart  Offline
Originally Posted By: tk74
'70 TR6
Nah - Helicoil or Timesert the existing hole, the original thread is 1/2"UNC. If possible, try and find an individual or company locally that does 'em, or you'll be shelling out for ten inserts and the tap ... whistle
When selecting the helicoil/Timesert, be aware that they come in various lengths, each being a mutliple of the diameter - i.e. in this case, '1/2d' is 1/4" long, '1d' is 1/2" long, '1.5d' is 3/4" long, etc., etc. Measure the thickness of the casting and select the correct one. Whatever you do, don't do what the muppet who put my 500 engine together did - put in a longer helicoil protruding into the gearbox; crazy I couldn't work out why only about 200cc of gearbox oil came out ... 'til the rest spilled all over the garage floor when I took the cover off ... mad
gearbox
I wouldn't replace with another 'level tube drain plug' - ime, the originals have a propensity for the level tube coming out of the drain plug; shocked if you're lucky, the tube just rolls around the bottom of the case; if you're unlucky, the loose tube was picked up between two gears, whereupon the engine seizes immediately, and breaks the gearbox case. sick Given the general standard of 'cheap bits' available today, I wouldn't trust a new one to be any better made. frown
Iirc, from '71, Triumph fitted an ordinary bolt and changed the gearbox inner case to incorporate a plastic dipstick.
On all my Triumphs, I've replaced each drain bolt with a socket cap (Allen) screw sized to protrude just into the case with, outside, a spring washer and plain washer compressing an 'O'-ring - Allen screw because the hex. key is shorter than a spanner so I'm less likely to strip the case thread, 'O'-ring 'cos it makes a better seal than a crappy fibre washer.
T160's have gearbox dipsticks as standard, the T100 I've changed the gearbox inner cover for one with a dipstick. I've a later gearbox cover for the T150 but, to be honest, I don't miss the level tube - I've long poured gearbox oil into a cheap enamel measuring jug (from a kitchen shop) before pouring it into a gearbox; the gearbox oil can't go anywhere unless there's a leak; if I want to know how much is in the 'box, it's hardly a chore to drain it into the aforementioned jug.
Re: Gearbox drain plug thread size? [Re: TonyK74] #398440
10/11/11 11:03 pm
10/11/11 11:03 pm
Effingham, IL
TonyK74 Offline OP
TonyK74  Offline OP
Effingham, IL
Stuart,
Thanks for the info. I think I'll take your advice and use an insert with an allen bolt. Like you, I think I would prefer to just measure the amount oil needed instead of waiting for it to dribble out of that level tube.
Re: Gearbox drain plug thread size? [Re: TonyK74] #398501
10/12/11 8:45 am
10/12/11 8:45 am
Diamond Springs, Kalifornia
Buckshot1 Offline
Buckshot1  Offline
Stuart,
My 72 has the metal tube arrangement. Perhaps the plastic tube came along later or? I do like the single bolt idea, and being a 4 decade machinist I have a thing for Allen bolts. A stainless bolt with an o-ring groove and drilled for safety wire might be a nice touch. The use of coarse threads in the castings to attempt the confinement of oil makes me cringe every time I change oil, adjust primary, etc.
Michael
currently owned by a 72 T120R
maker of plunger conversion jig
