mattstriumph
mattstriumph
Dillsburg, PA - USA
50 registered members (Alexp), 255 guests, and 397 spiders.
10476 Registered Users
NickL 92
franko 71
Triless 65
746,595 mail-order LSR
Topics68,801
Posts670,173
Members10,476
Wheel truing #393652
09/08/11 10:53 pm
09/08/11 10:53 pm
Triangle,Va.
Crookedhair Offline OP
Triangle,Va.
I am attempting to lace and true my first wheel.I'm actually making a bit of progress(I think).What would be an acceptable amount of lateral runout?I've got it to about 0.015".Also,what about out of round?
Re: Wheel truing [Re: Crookedhair] #393658
09/08/11 11:37 pm
09/08/11 11:37 pm
Very acceptable would be .020 overall on both the radial and axial.
Re: Wheel truing [Re: Crookedhair] #393676
09/09/11 1:36 am
09/09/11 1:36 am
For a steel rim, .015" would be really good. They're typically not even that round. For an alloy rim, you can usually get better, but it's not really that necessary.
Re: Wheel truing [Re: Crookedhair] #393879
09/10/11 1:31 pm
09/10/11 1:31 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
General question: I have laced and trued a bunch of bicycle wheels. Would a motorcycle wheel be much different other than everything is bigger and heavier?
Re: Wheel truing [Re: Crookedhair] #393880
09/10/11 1:41 pm
09/10/11 1:41 pm
John Healy Offline
John Healy  Offline
Same concepts apply to both.
Re: Wheel truing [Re: John Healy] #393976
09/11/11 10:41 am
09/11/11 10:41 am
Oslo Norway
Per B - R.I.P. Offline
Oslo Norway
In the BSA manuals I have at hand there is no tolerance of wheel run out. When building weels I was aiming for less than 0,5 mm both sideways and radially, but as a short time owner of a 79 TZ 350 racing Yamaha, i still have the workshop manual of this bike. The tolerance for both sidways and radially in this book is 2 mm. Keep in mind this is a racer!!
Well now adays I am much more relaxed regarding the tolerances and are building wheels to 1 mm in all directions.
Just my two cents worth of wisdom
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
Re: Wheel truing [Re: Crookedhair] #394662
09/16/11 12:03 pm
09/16/11 12:03 pm
NJ
NJThunderbolt Offline
NJ
You must have taken a lot of patience with your wheel, well done!
FYI, here's a conversion chart I use for tolerances.
http://mdmetric.com/tech/cvtcht.htm
