Barb
Barb
Western Washington State (USA)
30 registered members (Andy Higham), 212 guests, and 399 spiders.
10256 Registered Users
Stuart 75
Lannis 66
608,497 mail-order LSR
Topics67,110
Posts651,229
Members10,256
B31 Service Manual #393847
09/10/11 5:17 am
09/10/11 5:17 am
Australia
GJS Offline OP
GJS  Offline OP
Australia
I am looking for a service manual to give me some guidance re servicing/ maintaining my 1945 B31. The Haynes manual range don't appear to cover the early B31.Is this correct, or am I missing something ?
Re: B31 Service Manual [Re: GJS] #393848
09/10/11 5:29 am
09/10/11 5:29 am
I've maybe seen something on eBay. But, if you might keep the bike or any other BSA, best investment you could make is the BSA CD set offered for sale through this site. Probably the best motorcycle tool I have bought.
Re: B31 Service Manual [Re: GJS] #393863
09/10/11 11:35 am
09/10/11 11:35 am
Australia
GJS Offline OP
GJS  Offline OP
Australia
Cheers. This is my first Brit bike.I need all the help I can get!
Re: B31 Service Manual [Re: GJS] #393899
09/10/11 6:52 pm
09/10/11 6:52 pm
From what I can see the 1954 to 1961 Haynes manual has almost all you need to know given how little the machines changed. For example all three frame types are covered and both the alloy and iron engines are shown.
For sure your gearbox is not covered but the M type shown is quite similar with the exception I think being the gear changing bits.
The basic B31 engine will be as per the iron top end engine shown with only small detail differences that will be obvious.
There are service sheets that were published in those days but they are not always easy to come by. For them folks on this site will normally have that info if you are in need.
Re: B31 Service Manual [Re: Gordo in Comox] #393971
09/11/11 9:04 am
09/11/11 9:04 am
Australia
GJS Offline OP
GJS  Offline OP
Australia
Thanks Gordo
At the moment I am looking for some guidance re timing.The bike was running well,starting fine until the points cover rattled loose.I'm not sure what has happened, but suspect the points may have slipped.I am looking for some instruction (with diagram/picture if possible) re checking / setting the timing.
I am sure this will be the start of many things I will need to get to the bottom of, so thanks for the headsup.
Graham
Re: B31 Service Manual [Re: GJS] #393978
09/11/11 11:48 am
09/11/11 11:48 am
kommando Offline
kommando  Offline
You can get the BSA service sheets in PDF here
http://www.britishonly.com/tech/manuals/bsaservicesheets.asp
