Prospect
Prospect
London UK
42 registered members (Adam M.), 262 guests, and 357 spiders.
Duckster, IDG1, pemdoc65, creativecroc, gregneal
10171 Registered Users
Lannis 96
Stuart 84
reverb 81
NickL 69
koan58 56
550,114 mail-order LSR
Topics66,555
Posts645,181
Members10,171
Pre unit Camshaft/Crankshaft Pinion Timing Marks ? #393569
09/08/11 3:08 pm
09/08/11 3:08 pm
East Sussex UK
db133 Offline OP
db133  Offline OP
East Sussex UK
Hi
I'm stripping down a T100 (72679)and found this:
Are these pinions in the correct position for re-assembly or have they been moved previously ?
I have a spare set of pinions :
Why are the marks different ? Is it because the top pictures are a T100 ?
Sorry if its a daft question but we all have to learn.
Pullers wanted.
Re: Pre unit Camshaft/Crankshaft Pinion Timing Marks ? [Re: db133] #393575
09/08/11 3:40 pm
09/08/11 3:40 pm
Nor. California
Deadstiffcatt Offline
Nor. California
RE the top pics- they are not in correct alignment. The idler gear needs to be lifted up and re-placed so that the marking with identical length dashes is lined up with the crankshaft gear dot. This will place the long dash/short dash at the inlet gear, and the dot to match the dot on the exhaust gear.
On 5T models, the inlet gear would align with the short dash, and on the TR5, it would align with the long dash.
There is a difference to permit the opening of the cam a bit earlier on the sportier model, should run with either dash aligned, but should run better with the right one aligned, and would run best if you can properly time the camshaft opening to it's best position following the valve timing instructions in some of the old pre unit manuals.
Sorry, can't answer the why part on the differences-too many years, models, and gears..........
Pullers- a nice set for pulling can be found at almost any good Brit bike dealer- also check E-bay, especially if you are going to do more Triumphs in the future.
P.S. I hope that's not the wife's coffee table that engine is on. Could prove to be fatal!!! laughing
Re: Pre unit Camshaft/Crankshaft Pinion Timing Marks ? [Re: db133] #393579
09/08/11 4:15 pm
09/08/11 4:15 pm
As I recall the idler gear is smaller than the cam gears and thus is only lined up correctly with all the 'timing' marks once every so many revolutions of the engine. If you were to keep turning the engine over and over until the double lines are on the mark on the crank gear the rest should all line up correctly.
Re: Pre unit Camshaft/Crankshaft Pinion Timing Marks ? [Re: Gordo in Comox] #393585
09/08/11 4:46 pm
09/08/11 4:46 pm
East Sussex UK
db133 Offline OP
db133  Offline OP
East Sussex UK
Top info much appreciated. db
Re: Pre unit Camshaft/Crankshaft Pinion Timing Marks ? [Re: Gordo in Comox] #393600
09/08/11 5:48 pm
09/08/11 5:48 pm
Nor. California
Nor. California
Gordo, agreed! Seems it's once every 97 or so that all marks line up to the original due to the idler gear size. You explained it well where I couldn't find the right words.
Re: Pre unit Camshaft/Crankshaft Pinion Timing Marks ? [Re: db133] #393664
09/09/11 12:06 am
09/09/11 12:06 am
Yes, the 'hunting tooth principle' will explain it nicely.
http://www.dliengineering.com/vibman/huntingtoothgearsets.htm
Page Time: 0.064s Queries: 15 (0.005s) Memory: 1.0246 MB (Peak: 1.1772 MB) Zlib disabled. Server Time: 2018-04-21 15:24:44 UTC
