andyhosie
andyhosie
Melbourne, Australia
199 registered members (1xfatboy), 2,195 guests, and 539 spiders.
koan58 89
Lannis 82
505,080 mail-order LSR
Topics66,047
Posts639,299
clutch plates stuck together #391704
08/26/11 2:17 am
08/26/11 2:17 am
DKA Offline OP
DKA  Offline OP
I have a '79 T140. If I leave the clutch alone for more than 2 days the plates stick together so much that I can't break them loose unless I take them out of the clutch and pry them apart with a screw driver. The pads do not seem overly worn and the metal ones are really smooth. If I coat them heavily with oil then they work nicely until driven, then back to sticking together. Whats with that? I just replaced the basket due to lots of dents in the slots and I filed down the dogs while I was at it. They slid past each other the next day, but then after 3 days they are stuck again. Should I just get new plates?
David
Re: clutch plates stuck together [Re: DKA] #391705
08/26/11 2:22 am
08/26/11 2:22 am
My old '79 used to stick almost as soon as I buttoned up the primary.
Try Barnett friction plates and back off the spring pressure till it just starts to slip on hard accelleration from about 3500 RPM, then turn in the screws about 1/4 turn and you should be good to go.
Re: clutch plates stuck together [Re: GrandPaul] #391707
08/26/11 2:35 am
08/26/11 2:35 am
Ottawa Ontario, Canada
mike07 Offline
mike07  Offline
Somebody here,i forget who suggested using a zip tie to hold lever to bar if its gonna sit for a while & it works for me.
68 Bonneville
68 Daytona
68 CL450
68 CL350
Re: clutch plates stuck together [Re: DKA] #391708
08/26/11 2:46 am
08/26/11 2:46 am
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
Usually you pull in the lever and use the kickstart to break the plates free before starting.
Instead of using zip ties, cut an old mountain bike inner tube into inch wide strips and use one or two of those to relieve the pressure plate.
Re: clutch plates stuck together [Re: DMadigan] #391712
08/26/11 3:20 am
08/26/11 3:20 am
DKA Offline OP
DKA  Offline OP
I can pull in the clutch lever and kick it while the rear tire is on the ground with a person on the seat and the plates won't break loose. I'll try the holding in the lever trick after I pull it back apart and separate them. I was a little worried that that might weaken the springs, but if other people do it to good affect, then I guess its worth a try. I've heard good things about Barnett so I'll probably do those over the winter, or sooner.
Does tightening the three springs past snug actually increase spring pressure? or does it just decrease its length?
David
Re: clutch plates stuck together [Re: DKA] #391721
08/26/11 4:55 am
08/26/11 4:55 am
so.cal
Torch Offline
Torch  Offline
so.cal
Many times on the 1970 and later bikes it's the engine oil you are using that sticks them together, if you are not already you might try using a actual Motorcycle oil that is intended for use with clutch plates.
It isn't a big problem on the earlier bikes because most people with the non-primary breather models use ATF in the primary case because it's designed to be used with clutch plates.
"Statesman" is the term often used to describe a deceased politician, we need more Statesmen.
Re: clutch plates stuck together [Re: DKA] #391741
08/26/11 12:29 pm
08/26/11 12:29 pm
John Healy Online content
John Healy  Online Content
This is a problem typically seen with the older clutch material Barnett used on their plates. As David explained, they would seem to weld themselves together. With in the past year they changed friction material and we have not had a complaint of sticking Barnett plates since.
This is rarely seen with the NEW Barnett, Taiwan, or Surflex plates. The best releasing plates are the Surflex ones sold by Norman Hyde in his 7 plate conversion.
Re: clutch plates stuck together [Re: DKA] #391783
08/26/11 5:38 pm
08/26/11 5:38 pm
Jordan, NY
Al Eckstadt Online content
Al Eckstadt  Online Content
Jordan, NY
I had this problem a few years ago and tried all the suggestions from this board with no results. Maybe the issue is cleared up now with new materials but I solved my problem with MAP no-drag clutch plates. HTH. Al.
Al Eckstadt
Re: clutch plates stuck together [Re: DKA] #391793
08/26/11 6:39 pm
08/26/11 6:39 pm
A lot of people have good luck with the Alto plates sold by MAP and others.
Re: clutch plates stuck together [Re: Al Eckstadt] #391794
08/26/11 6:42 pm
08/26/11 6:42 pm
devon
kevin large Offline
kevin large  Offline
devon
after cleening everything in petrol refill primary with Atf oil
works every time
Re: clutch plates stuck together [Re: DKA] #391803
08/26/11 7:48 pm
08/26/11 7:48 pm
ATF won't do a thing to prevent the old Barnett plates from sticking! If you had some real hp they were brilliant, but you had to take precautions to make sure they didn't weld themselves together.
Because we always checked the clutch rod adjustment between races we would just run in the adjuster between races. This kept the pressure off the plates in the same manner as putting a bunji of the clutch lever but a lot less stress full on the clutch cable.
Re: clutch plates stuck together [Re: DKA] #391834
08/27/11 12:13 am
08/27/11 12:13 am
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
DKA,Your post about kicking with the tire on the ground and someone on the seat makes me think you are trying to kick it in gear. Are you? Jack
Re: clutch plates stuck together [Re: DKA] #391885
08/27/11 11:39 am
08/27/11 11:39 am
DKA Offline OP
DKA  Offline OP
Thanks for all the ideas. I'm glad to see that it is a normal issue and not that the universe is picking on me! John, I'll do the clutch adjuster thing. Jack, I was hoping to break the plates free by using a locked rear wheel(can't use the brake pedal 'cause its in the way of kicking). Over the winter I'm going to get new plates and hopefully be done with this. Also, tomorrow I'm putting in ATF to give it a try. Thanks everyone!
Re: clutch plates stuck together [Re: DKA] #391886
08/27/11 11:48 am
08/27/11 11:48 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Originally Posted By: DKA
I have a '79 T140.
No! Do not use ATF in the primary case
It's a 1979 model therefore you must use the same oil in the primary case as you use for the engine.
Re: clutch plates stuck together [Re: DKA] #392021
08/28/11 5:26 pm
08/28/11 5:26 pm
DKA Offline OP
DKA  Offline OP
LAB, thanks for yelling at me and getting my attention. I need it sometimes. OK, I won't go for the ATF but yesterday I cleaned them and coated them with ATF and reassembled the clutch leaving the springs fully tightened. This morning I tried kicking it over and they would not release. I'm no physicist, but I'm wondering if as the plates get worn they become ultra smooth, almost polished. Two polished surfaces with a thin film of wetness between them almost always will stick together. Surface tension or something like that. I do think I'll go ahead and get some Surflex plates instead of waiting. When the new ones arrive, I'm going to rough up my old ones and see if that makes any difference. I love a good experiment!
David
Re: clutch plates stuck together [Re: DKA] #392036
08/28/11 8:46 pm
08/28/11 8:46 pm
Norfolk, UK
Norfolk, UK
I think it's just an "old" plate problem, and it's one that I've heard Triumph owners often mention before. Fitting a new set of friction plates (such as Surflex etc.) usually cures the "overnight" plate-sticking problem.
When you say the clutch springs were "fully tightened" I hope you mean "correctly adjusted"?
Re: clutch plates stuck together [Re: DKA] #392039
08/28/11 9:17 pm
08/28/11 9:17 pm
You aren't supposed to fully tighten the clutch springs; you are supposed to adjust them to the point that they provide full lock-up with no slipping under accelleration in higher gears, and no grabbing/creeping with clutch engaged at low RPM at a stop.
Typically, you can just see the first thread at the end of the bolt coming up through the slotted head section at that pooint. That's why the special tool has a notch to accommodate it.
Fully tightened is sure to lock the clutch up solid regardless of lever / cable / mechanicsm position.
Re: clutch plates stuck together [Re: DKA] #392096
08/29/11 11:30 am
08/29/11 11:30 am
DKA Offline OP
DKA  Offline OP
Yes, I should have used the correct words. I had one thread showing on the spring adjusters. I'm ordering new plates this week. Thanks for everyone's help on this.
David
Re: clutch plates stuck together [Re: DKA] #392106
08/29/11 12:41 pm
08/29/11 12:41 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
If MAP advertise them as such I hope they send God to fit them.
Some folks have endless problems with Triumph clutches but mine have been few, once the bolts fixing the cush drive togeather came loose and that was my fault for not checking them at rebuild.
A cable once broke also and the nipple is still beneath the outer gearbox cover.
People speak of steel plates becoming polished and thereby allowing a pure suction lock against friction plates and suggest bead blasting of steel plates.
My clutch is feather light and only ever slips momentarily when accelerating in higher gears when the bike has been parked for a month, when warm it behaves.
Plates are what were fitted when I bought the bike 8 yrs back, I measured them at rebuild and have done 35K miles since.
I do the basic behaviours like never hold the clutch in but rather select neutral etc but that is not a dark secret.
1969 TR6R
Re: clutch plates stuck together [Re: Tiger] #392120
08/29/11 2:10 pm
08/29/11 2:10 pm
I swirl the plain steel plates (both sides) on a smooth area of my concrete shop floor, to knock the glaze off and give them a reasonably consistent tacky surface. It's worked fine for me for 20 years and several dozen bikes (at least).
Re: clutch plates stuck together [Re: DKA] #392392
08/31/11 1:49 am
08/31/11 1:49 am
DKA Offline OP
DKA  Offline OP
So who do I go to to buy the Surflex or Barnett plates? Preferably one of the advertisers on this site. I've looked around on their sites but haven't found a listing.
Re: clutch plates stuck together [Re: DKA] #392621
09/01/11 5:13 pm
09/01/11 5:13 pm
Shingle Springs, California
Roadwarrior Online content
Roadwarrior  Online Content
The good suppliers will have a variety of plates to choose from. I like Walridge motors.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Page Time: 0.070s Queries: 15 (0.007s) Memory: 1.1664 MB (Peak: 1.4757 MB) Zlib disabled. Server Time: 2018-02-24 11:48:11 UTC
