Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
t140 running without a battery is it possible #390600
08/20/11 11:07 am
08/20/11 11:07 am
united kingdom
brian begg Offline OP
united kingdom
hi is it poss to run my t140 bonnie without a battery. have herd you can but not sure what to do.its fitted with a Boyer electronic ignition .reason i am wanting to do this is i am building a bobber and have no room for a battery .also anyone got any ideas for a wireing loom only going to have front and back light and horn and ignition switch hope you can help me cheers brian
Re: t140 running without a battery is it possible [Re: brian begg] #390630
08/20/11 4:31 pm
08/20/11 4:31 pm
so.cal
Torch Offline
Torch  Offline
so.cal
There are still many people that will say it can't be done but we wire custom bikes that way all the time and it works fine, the secret is a good strong alternator, (that translates into a "new" one) and don't go over board on the stator output, you can't use a 200 watt high output stator with this charge unit so stick with standard output stator and a new rotor. and we use the "Boyer light delay battery eliminator" charge unit. that unit will allow the minimum voltage necessary needed to keep your Boyer ignition running properly before it powers up your lighting system.
It also helps to wire the bike as a negative ground and use an LED taillight and don't use a high wattage halogen headlight (halogen bulbs burn faster when they are run at a lower voltage)this will also minimize you lighting power requirements and prevent pulsing lights at idle.
here is a simple wiring diagram from Rask, you will need to substitute the Boyer charge unit for the Tympanium and battery.
http://raskcycle.com/techtip/webdoc16a.html
"Statesman" is the term often used to describe a deceased politician, we need more Statesmen.
Re: t140 running without a battery is it possible [Re: Torch] #390636
08/20/11 5:02 pm
08/20/11 5:02 pm
united kingdom
united kingdom
thank you very much for that information very helpfull
Re: t140 running without a battery is it possible [Re: brian begg] #390637
08/20/11 5:11 pm
08/20/11 5:11 pm
united kingdom
united kingdom
sorry had look at wireing diagram it shows it useing a battery .do you just wire it the same way without useing the battery thanks again brian
Re: t140 running without a battery is it possible [Re: brian begg] #390670
08/20/11 7:59 pm
08/20/11 7:59 pm
so.cal
Torch Offline
Torch  Offline
so.cal
yes just eliminate the battery, and because those Boyer charge units cost about $140 make sure you put a fuse in line on the (red) power wire.
Re: t140 running without a battery is it possible [Re: Torch] #390673
08/20/11 8:03 pm
08/20/11 8:03 pm
united kingdom
united kingdom
spot on mate thanks again
Re: t140 running without a battery is it possible [Re: brian begg] #391003
08/22/11 4:53 pm
08/22/11 4:53 pm
Charlotte NC
RHall-HCV Offline
RHall-HCV  Offline
Charlotte NC
Ive got a hi output alt kit with a sparx battery elim kit, running a Boyer with a led tail light bulb (necessity like torch said) and 2 55w bulbs for a head light. Works just fine and starts first kick most of the time.
ROB HALL
HCV MOTORSPORTS
Re: t140 running without a battery is it possible [Re: brian begg] #391012
08/22/11 6:00 pm
08/22/11 6:00 pm
KY, USA
RyanF Offline
RyanF  Offline
KY, USA
I run most of my bikes battery-less. You have several options... in order of preference with electronic ignition:
1. Capacitor with Tympanium/Spark Solid state rectifier/regulator
2. Boyer or Sparx Power box/Battery Eliminator
3. I also use small Sealed Lead Acid batteries of the 4.5 - 5 Amp Hour range. Small enough to conceal easily (2 packs of smokes small), but reliability of a battery.
AS others have stated. I properly working charging system is a must. 10amp std. Alternator/Rotor combo is just fine for me my lights hardly flicker at idle.
I wire my Headlight to a 3 way toggle (ON-OFF-ON) in the light housing so I can start or run without lights on. Tail Light is also wired only to "ACC" position on 3 Position ignition switch. Brake Light runs off coil jumper, so if the bike is running, I have a brake light, lights on or not.
A quick word on LED lights, they are Polarity Sensitive!!! Unless designed to do so, they will not light on a POSITIVE ground system without an inline relay of some type.
That's all I got!
Farducci
1950 BSA A10 Chopper 1951 BSA Golden Flash
1960 Triumph 5T
1962 BSA A65 Royal Star
1968 BSA A65 Bobber - In Progress
1969 Triumph T120 Bobber "The Rabbit"
1972 Triumph T120RV
Re: t140 running without a battery is it possible [Re: brian begg] #391019
08/22/11 6:21 pm
08/22/11 6:21 pm
I also have been doing this for some time, on several bikes. My favorite setup is Podtronics box and an old time looking, (but new) Mallory capacitor. I've used Mity Max, Sparx box and Boyer Power Box, but like the capacitor best. Boyer Mark 3 and a Pazon, haven't tried with Boyer Mark 4
I mention Boyer Mark 4 because the esteemed Torch has earlier posted he doesn't like the Mark 4 without battery.
As others have said, alternator rotor is the biggest factor- stronger the magnets, less kicking you will do. I always use some kind of little battery at first to get the bike up and running good.
Re: t140 running without a battery is it possible [Re: RyanF] #391561
08/25/11 3:05 am
08/25/11 3:05 am
so.cal
Torch Offline
Torch  Offline
so.cal
"A quick word on LED lights, they are Polarity Sensitive!!! Unless designed to do so, they will not light on a POSITIVE ground system without an inline relay of some type."
as for the LED tail lights all you need to do is switch the black and red wire going to ground from your Tympanuim and you now have a negative ground bike that can just plug in the store bought LEDs
Esteemed? ...hmmm... but I still prefer the Pazon over the Mark IV, the mark III's were fine but the new Boyer's are way to sensitive to minor A/C leakage.
Re: t140 running without a battery is it possible [Re: Torch] #391604
08/25/11 12:10 pm
08/25/11 12:10 pm
JubeePrince Online content
JubeePrince  Online Content
If you are going to do this, you would probably want to reverse the polarity on the coils too....
Re: t140 running without a battery is it possible [Re: JubeePrince] #391618
08/25/11 2:45 pm
08/25/11 2:45 pm
so.cal
Torch Offline
Torch  Offline
so.cal
there is a whole different wiring diagram for the E/I brain box for a negative ground, but the coil wiring is the same
Re: t140 running without a battery is it possible [Re: Torch] #391630
08/25/11 4:19 pm
08/25/11 4:19 pm
London, England
Triumph5ta Offline
Triumph5ta  Offline
London, England
Paul Goff will have all your Positive Earth LED bulbs:
Paul Goff classic bike electrics
Re: t140 running without a battery is it possible [Re: leon bee] #391797
08/26/11 7:13 pm
08/26/11 7:13 pm
dave jones Offline
dave jones  Offline
What is the value of the capacitor you use? I fancied trying running with one but wasn't sure if the ancient Lucas capacitors would still work.
Re: t140 running without a battery is it possible [Re: brian begg] #391806
08/26/11 8:16 pm
08/26/11 8:16 pm
I bought several new, fresh capacitors. Mallory, made in USA, (allegedly). They say 4500uF, 30 volts. Mallory number is CGS452U030R2C.
