Hector Catre
Hector Catre
Toronto/Ontario/Canada
206 registered members (68 royalstar tony), 1,714 guests, and 551 spiders.
10036 Registered Users
Lannis 147
kommando 113
Stuart 62
478,362 mail-order LSR
Topics65,740
Posts635,506
Members10,036
Yer NOT gonna believe this.... #390744
08/21/11 5:18 am
08/21/11 5:18 am
Rickman Offline OP
Rickman  Offline OP
Y'all remember everyone complaining about how hard it is to remove an A10 swing arm cleanly?
Hacksaws, presses, wedges, and whatever else people have had to use, to remove the old through bolt, either type, then the flame and efforts to get rusty old silent bloc bushing remnants out of the swing arms?
Well, I've had an amazing day, and I thought I'd pass the GOOD news along....
Of three A10 frames I've had to juggle parts and swing arms around on, because one of the arms was twisted a bit, all three swing arms came off the frames EASILY!!!!! WHOO-HOO!!!
I had thought that one in particular was gonna be nasty, but I found a bolt to hold the through bolt still, correctly, moved the swing arm up and down to try to exercize the through bolt and bushings, and it EASILY dislodged the surface joint!
Tapped the nut on the end of the through bolt, which again easily moved sideways, then a little further with a rubber mallet with the nut off, grasped the bolt with my hand, and see-sawed the bolt out of the swing arm!
You guys terrorized me with all your tails of hardship, and todays efforts were anti-climactic, to say the least!
Now, sooner or later, I'm gonna have to try to find someplace that can straighten this twisted swing arm....
Brett
Re: Yer NOT gonna believe this.... [Re: Rickman] #390746
08/21/11 5:42 am
08/21/11 5:42 am
Muriwai,New Zealand
Llewelyn Offline
Llewelyn  Offline
Muriwai,New Zealand
Pretty easy to straighten yourself, detailed how to do here on this recent post
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=388929#Post388929
Re: Yer NOT gonna believe this.... [Re: ] #390798
08/21/11 4:21 pm
08/21/11 4:21 pm
Rickman Offline OP
Rickman  Offline OP
Yeah Allan,
That's what I kept hearing.
So I was approaching this project with MUCH trepidation!
WHAT a relief!!!!!
Re: Yer NOT gonna believe this.... [Re: ] #390847
08/21/11 9:23 pm
08/21/11 9:23 pm
Rickman Offline OP
Rickman  Offline OP
THANKS!
For complimenting me on my good fortune! PURE luck!
