Phrog
Phrog
Sydney, Australia. I might be down under but I can still throw a leg over.
42 registered members (ArmyMutt), 216 guests, and 92 spiders.
Juan Cisneros, Willie, JohnS, Micke, Speedi594
10338 Registered Users
Stuart 119
DavidP 70
reverb 69
663,258 mail-order LSR
Topics67,727
Posts657,997
Members10,338
Stained carb... how to clean? #385064
07/18/11 6:07 pm
07/18/11 6:07 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
What do you guys use to clean the stubborn stains from the exterior carb body? You can see in the pic that I used rust remover (phosphoric acid/corrosive) to clean the parts that will not be effected by air and fuel flow. It does an excellent job. Leaves a nice, clean matte finish. But I didn't want to dip the entire body into this elixir because of the sensitive nature of the restrictive jet holes. Have any of you used rust remover on carbs? Or are there better solutions? Thx.
Re: Stained carb... how to clean? [Re: Bola] #385066
07/18/11 6:15 pm
07/18/11 6:15 pm
Brooklyn, NY, USA
jholmes Offline
jholmes  Offline
Brooklyn, NY, USA
There is carb cleaner that comes in a gallon can. Napa brand, I believe. Soak it for awhile.
Cheers!
-Jason
Re: Stained carb... how to clean? [Re: Bola] #385075
07/18/11 6:48 pm
07/18/11 6:48 pm
Tridentman Offline
Tridentman  Offline
Try using an ultrasonic cleaner.
Works wonders!
Re: Stained carb... how to clean? [Re: Bola] #385076
07/18/11 6:57 pm
07/18/11 6:57 pm
Ann Arbor
tsohg Offline
tsohg  Offline
Ann Arbor
Tape up the jet holes and soda blast! Guaranteed to work. Just be very careful to only hit the exterior and clean it up well afterwards.
When I bead blasted my A50's barrels... I thought I did a good job with taping everything. When I removed the tape, the whole insides (cam followers included) were covered glass beads. It looked like a sugar doughnut. Spent a long time with WD-40 and compressed air, but eventually got all the beads out!
Nothing works like media blasting smile
Re: Stained carb... how to clean? [Re: Bola] #385079
07/18/11 7:48 pm
07/18/11 7:48 pm
Arlington, Massachusetts, USA
kurt fischer Offline
#irideslow
#irideslow
Some recent discussion on ultrasonic cleaning here:
http://www.britbike.com/forums/ubbthread...2752#Post382628
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: Stained carb... how to clean? [Re: Bola] #385080
07/18/11 7:50 pm
07/18/11 7:50 pm
Texas
bandit Offline
bandit  Offline
Texas
"Berrymans carb cleaner" makes 'em sparkle like new.....one gallon can, dipping basket inside....don't get the stuff on your skin...real nasty. Read the can label.
69 Lightning
71 BMW R75/5
57 Cushman
74 MGB
So it's every hand to his rope or gun,
Quick's the word, Sharp's the Action.....
Re: Stained carb... how to clean? [Re: bandit] #385085
07/18/11 8:24 pm
07/18/11 8:24 pm
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
I've heard Berrymans mentioned in the past. Unfortunately not sold in Canada. Nor do we have Harbour Freight... Damn!
No old school tricks to clean em??
Re: Stained carb... how to clean? [Re: Bola] #385091
07/18/11 8:49 pm
07/18/11 8:49 pm
#irideslow
#irideslow
How 'bout Permatex products in Canada?
"82580 Carburetor & Parts Cleaner"
http://www.permatex.com/products/Automot...rts_Cleaner.htm
Kurt
Re: Stained carb... how to clean? [Re: Bola] #385095
07/18/11 9:28 pm
07/18/11 9:28 pm
Perth. Wild West Downunder.
M Shearer Offline
M Shearer  Offline
Methylated spirits will get rid of that as good as anything and will be cheaper than anything else you can get your hands on.
Mark F.
'52 ZB34 Gold Star.
'65 Lightning Rocket.
'74 Roadster Commando.
Re: Stained carb... how to clean? [Re: Bola] #385175
07/19/11 12:15 pm
07/19/11 12:15 pm
BSA_WM20 Offline
BSA_WM20  Offline
Boiling is my favourite method.
Big pot of boiling water on the BBQ outside ( unless you enjoy eating cold baked beans & sleeping on the couch ) .
Pop several of those dishwasher tablets ( the ones with the ball in the middle ) in the water & toss the carb in.
About 20 minutes of a nice rolling boil with have it quite clean with a grey coating of zinc hydroxide which will rub off to a nice polished finish.
Pull the carb out of the boiling solution then pop it into a pot of clean boiling water and allow it to cool down before a final rinse in cold water
Re: Stained carb... how to clean? [Re: Bola] #385210
07/19/11 4:34 pm
07/19/11 4:34 pm
S.E. Ohio
H
HillbillyBarr Offline
H
S.E. Ohio
Just shoot carb cleaner on it or soak it in laquer thinner, just don't git any on plastic parts. Carb cleaner in a spray can does wonders on aluminum and WD40 does a nice job on the oxidized aluminum.
Gene
Re: Stained carb... how to clean? [Re: HillbillyBarr] #385251
07/19/11 7:32 pm
07/19/11 7:32 pm
Steve S Offline
Steve S  Offline
stick them in the dish washer dont let the wife catch you though mad
Re: Stained carb... how to clean? [Re: Bola] #385254
07/19/11 7:35 pm
07/19/11 7:35 pm
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
I like the dish washer too, even put some cases in there 1/2 at a time.
A little bleach run after and the wiffee is no wiser.
Richard
Re: Stained carb... how to clean? [Re: Richard Phillips] #385348
07/20/11 8:23 am
07/20/11 8:23 am
BSA_WM20 Offline
BSA_WM20  Offline
Richard
Braver man than I laughing
Re: Stained carb... how to clean? [Re: Bola] #385374
07/20/11 12:41 pm
07/20/11 12:41 pm
the dungeon, in N.W. Ohio
Mitch C. Offline
Mitch C.  Offline
Once I needed to heat up a right half of a case to get the right main bush out and stuffed it in the oven while momma was gone. I got the bush out, but the house stunk with the oil that had burned during the heating process that was in the case that I couldn't srub out ahead of time... wifey came home to a house full of smoke... there was no hiding that!
Re: Stained carb... how to clean? [Re: Mitch C.] #385376
07/20/11 1:27 pm
07/20/11 1:27 pm
S.E. Ohio
H
H
S.E. Ohio
I painted a gas tank fer a guy once then to do a quick cure i baked it in the oven. You couldn't git the smell of paint fumes out of that oven or the house. Luckily I wasn't married and was renting at the time.
Re: Stained carb... how to clean? [Re: Bola] #385384
07/20/11 2:28 pm
07/20/11 2:28 pm
Tridentman Offline
Tridentman  Offline
Dont forget that very often you are judging the effectiveness of the cleaning process by looking at it on the outside.
Using solvents alone can often give a clean exterior but leave crud in the internals. May look good but still leave you a problem in the internal passages of the carb (more likely with the crap starvation fuel we get nowadays).
Whereas by the nature of the process the ultrasonic cleaners clean inside and outside.
So IMHO and IME I prefer to clean carbs ultrasonically.
But---hey---they tell me its a free country ---so up to you.
Re: Stained carb... how to clean? [Re: Tridentman] #385392
07/20/11 2:49 pm
07/20/11 2:49 pm
Peter R Offline
Peter R  Offline
Works wonders!
I use ultrasonic cleaning too for my carbs, although, if the idle jet is clogged, ultrasonic cleaning will not always remove the blockage.
Re: Stained carb... how to clean? [Re: Bola] #385474
07/21/11 12:20 am
07/21/11 12:20 am
Toronto, Canada
Bola Offline OP
Bola  Offline OP
Toronto, Canada
Thanks for your excellent advise. As it turns out I did use a diluted (1:1) solution of rust remover/water. Worked a treat.
