BC/DC
BC/DC
Vancouver B.C. Canada
198 registered members (1xfatboy), 1,777 guests, and 604 spiders.
10032 Registered Users
Lannis 143
kommando 103
476,556 mail-order LSR
Topics65,719
Posts635,192
Members10,032
Replacing Clutch Cush Drive Rubbers ???? #380392
06/23/11 1:22 am
06/23/11 1:22 am
Jon W. Whitley Online content OP
Jon W. Whitley  Online Content OP
This is one job I have never done. I currently have the clutch on my 1970 BSA 650 disassembled and although the rubbers look decent, I am contemplating replacing them.
I believe I've seen or heard in the past that this can be a frustrating job. Maybe I heard wrong or think I did !
Anyhow, anybody want to share some insight-tips concerning this job or really even think I should if they look okay?
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380419
06/23/11 4:58 am
06/23/11 4:58 am
Santa Barbara, California
KC in S.B. Online content
KC in S.B.  Online Content
Insight ? DON'T. (do you really need to?)
To do it, you need a rig that will hold the hub, while you horse (rotate) the drum enough to make space to drop them in. The factory had a special table for that job. You could make something up if you had an old transmision shaft to put in a vise to hold the hub. I don't know if you could do it with the hub on bike, as horsing the drum would be tough in the limited space of the primary.
Thought about it myself once, that hub is still in pieces!
Down to 1 BSA, 2 Triumphs, 2 '56 Chevys
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380422
06/23/11 5:06 am
06/23/11 5:06 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Been a while since I did mine but a couple of screwdrivers and some Armorall for lubricant did the trick.
1969 TR6R
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380424
06/23/11 6:08 am
06/23/11 6:08 am
England
Tom_dup1 Offline
Tom_dup1  Offline
England
I put them in on one side, the easy bit, then compressed the rubbers in an oiled adjustable wrench. Lined them up with the slot they go into and pushed the rubbers out of the wrench with a screwdriver. Worked a treat.
Tom
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380427
06/23/11 6:39 am
06/23/11 6:39 am
Didn't I read where somebody squeezed em with visegrips and put them in the freezer for a while? Maybe that P80 lube John H. raves about would be good. So far, I've avoided this job also.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380431
06/23/11 7:18 am
06/23/11 7:18 am
Nanaimo, B.C. Canada
W
Wilfred Online content
Wilfred  Online Content
W
Used " tire mounting stuff " to get mine in and it did the job. Cheers, Wilf.
"It's about the ride..."
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Wilfred] #380443
06/23/11 10:19 am
06/23/11 10:19 am
Hmmmm,
Well, K.C. finds it a hard job to do and almost everybody else didn't find it too hard to do.
Wilfred, what is "tire changing stuff" ? I use WD-40 for tire changing stuff.
In my view, the rubbers aren't crumbling away so I am thinking I might not need to do it. On the other hand I understand that the rubber hardens over time. I just don't want to replace those if I don't really have to.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380456
06/23/11 12:26 pm
06/23/11 12:26 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Do it Jon, easy job and hopefully it will be years before you have to get back in there.
Match the rubbers up to location before removing the old ones, I may be slightly dislexic, remember scratching my head over that, if I recall correctly the old rubbers had taken a "set" and looked slightly different to the new.
1969 TR6R
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380464
06/23/11 1:26 pm
06/23/11 1:26 pm
Asheville, NC
Mike Baker Offline
Mike Baker  Offline
Asheville, NC
2 things make it easy:
Old clutch hub in a vice and old plain (driven) clutch plate with a 1' piece of steel welded onto it.
piece of cake....
Mike
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380476
06/23/11 3:11 pm
06/23/11 3:11 pm
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
Take an old driven plate and add (bolt/weld) a bar to it. After the first set are in use the plate to compress the rubbers and install the other set. Holding the hub takes a spare shaft in a soft vice or slip it on the shaft in the engine and use high gear/rear brake to hold it.
A good use for old clutch plates is to bolt a couple drive/driven plates together to lock the chainwheel to the clutch hub.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: leon bee] #380479
06/23/11 3:18 pm
06/23/11 3:18 pm
DINGDINGDINGDING!!! We have a winner! The freezer method makes a very difficult job a piece of cake. I believe it was RichB that posted that.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380509
06/23/11 6:57 pm
06/23/11 6:57 pm
John Healy Online content
John Healy  Online Content
Google P-80 they will send you a free sample. As the old joke goes, "you will need to strap a board across your buttocks to keep from falling in."
But if you have the older 6 screw iteration of the hub assembly may I strongly suggest that you invest in the later iteration which is held together by 3 bolts.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: John Healy] #380528
06/23/11 11:55 pm
06/23/11 11:55 pm
It is a 1970 and a 3 bolt set-up.
Thanks to all for the advice concerning this job. If I do it (If!) I will try to remember to post the process and end result of said job.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380576
06/24/11 7:14 am
06/24/11 7:14 am
W
W
Jon....tire mounting stuff is a tub of stuff that makes changing tires and even tyres a snap. And it doesn't promote rust on the rims. The local bike shop got me a bucket of it years ago. I gave some to a friend who was having trouble getting new rubbers into his shocks on his 49 MG and that worked too. Comes in an 8 pound bucket and is called tire mount "stuff" from Bridge Products, Inc, Aftermarket Components Division, Muskogee, OK 74402-0769 and is made in the USA. I've had this bucket for quite a while so I don't know if it's still available but I'll ask when I pick up some oil in the next couple of days. Used it last week to get the tubless tire off my wheelbarrow last week so I could put a tube in it so it would stay up. Cheers, Wilf.
Re: Replacing Clutch Cush Drive Rubbers ???? [Re: Jon W. Whitley] #380610
06/24/11 12:54 pm
06/24/11 12:54 pm
Oh yea, shock rubbers: Put a hose clamp around them then stick 'em in the freezer. bigt
