The Bonneville Shop
Shadrach
Shadrach
Maryland
39 registered members (Adam M.), 251 guests, and 466 spiders.
10528 Registered Users
franko 90
NickL 66
785,221 mail-order LSR
Topics69,221
Posts674,282
Members10,528
what size oil lines? #221630
11/01/08 6:04 pm
11/01/08 6:04 pm
milton iowa
ozzman Offline OP
ozzman  Offline OP
milton iowa
whats size is the oil lines on a 650cc triumph? 5/16 or 3/8?
Re: what size oil lines? [Re: ozzman] #221632
11/01/08 6:19 pm
11/01/08 6:19 pm
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
Assuming unit construction, I know the OIF is 5/16 for the feed and 3/8 for the return......I would expect the dry frames to be the same....those are for the main supply and return lines, the breather hoses and rocker box feed may be slightly different....
HTH,
Re: what size oil lines? [Re: JubeePrince] #221657
11/01/08 9:00 pm
11/01/08 9:00 pm
milton iowa
ozzman Offline OP
ozzman  Offline OP
milton iowa
maybe thats why i was confused, i was thinking one or the other, 5/16 or 3/8, not needing both sizes. i just remember on my first triumph years ago i had put one that was just a little to big on first and it did not seal tight with the hose clamp and leaked. to much rubber bunched up. i want to avoid buying the wrong size this time around. and im planning on braided line this time so the cost will be higher...lol there is not much difference between the two sizes, they should of made them the same...lol
Re: what size oil lines? [Re: ozzman] #221664
11/01/08 9:53 pm
11/01/08 9:53 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
It depends on the year... which you forgot to tell us.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: what size oil lines? [Re: RF Whatley] #221689
11/02/08 12:57 am
11/02/08 12:57 am
milton iowa
ozzman Offline OP
ozzman  Offline OP
milton iowa
1966 T120R
Re: what size oil lines? [Re: ozzman] #379904
06/20/11 5:27 pm
06/20/11 5:27 pm
Canada
dracko Offline
dracko  Offline
Canada
4 year thread bump!
Found this thread after doing a little searching Google.
I'm building a 1971 T120. Haven't fired it yet. Currently have 5/16 ID hose for Feed and Return lines to tank. is this alright? or do I really need to get some 3/8" ID for return line?
1/8" ID okay for rocker feed line?
thanks.
Re: what size oil lines? [Re: dracko] #380033
06/21/11 4:46 am
06/21/11 4:46 am
Nebraska, USA
E
ed_h Offline
ed_h  Offline
E
Nebraska, USA
On my 71 T1100R it was 5/16 and 3/16. the 3/16 isn't easy to find in a hose rated for hot oil.
For just a little more, you can do it yourself!
Re: what size oil lines? [Re: dracko] #380195
06/22/11 12:22 am
06/22/11 12:22 am
San Rafael, Ca.
BikeVice Offline
BikeVice  Offline
San Rafael, Ca.
My 1971 T120 uses 5/16" hose for both feed and return. I don't think the 3/8" hose appeared until the 750's when Triumph moved the oil feed to the absolute bottom of the frame and incorporated the pickup into the sump cover. For the rocker feed on an OIF 650, I last used VW diesel injector return hose from the local auto parts store. I think it's 3.5mm.
Eric
1971 T120RV (R.I.P.)
1973 T140V/TR7
1993 Ducati 900 SS
Re: what size oil lines? [Re: ozzman] #380227
06/22/11 2:50 am
06/22/11 2:50 am
Canada
dracko Offline
dracko  Offline
Canada
Hey thanks for the info Eric. 3.5mm is basically 1/8 I think so my 1/8 copper line should work.
cheers
Dan
