Kenacu
Kenacu
RED BANK NJ
202 registered members (1xfatboy), 2,157 guests, and 545 spiders.
koan58 89
Lannis 82
505,158 mail-order LSR
Topics66,049
Posts639,308
JRC PWK30 Carburettor on a BSA A65 #378344
06/11/11 5:48 pm
06/11/11 5:48 pm
Germany
MarkusHorst Offline OP
Germany
i bought a special PWK30 Carburetor for my BSA A65. But the engine will not run with this Carburetor, not even start, not even one "puff", kicking 10 minutes. The engine runs with an AMAL Concentric or an Monobloc, but not with this PWK30-Carburetor.
What is wrong with it ?
Please help me !
Thanx
Markus
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #378349
06/11/11 6:33 pm
06/11/11 6:33 pm
Don M. Offline
Don M.  Offline
With any plunger type enrichment device, as the PWK, set the lever down & keep the throttle firmly closed or it won't work. If it doesn't start after a few kicks, set plunger off & kick with full throttle a couple of times to clear excess fuel. With the old carbs we get in the habit of opening the throttle some for starting, which defeats the plunger type. Cheers, Don.
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #378804
06/14/11 10:08 am
06/14/11 10:08 am
I remember when I installed my PWK, there was dirt (aluminium particles from machining) in the needle valve which closes fuel when the float goes up. This caused my PWK to leak fuel to the outside. Maybe the same kind of dirt causes Markus PWK to be dry.
It's a trail and error twist and push movement to remove and replace the float bowl. Do not use force or you'll damage the brass overflow pipe that sticks between the two halves of the floater.
My BSA went out of service before I could determine the correct jetting. That will be a job for later this year.
I'm very curious what other PWK-users use.
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379072
06/15/11 4:28 pm
06/15/11 4:28 pm
Carmel, CA
Doc_dup1 Offline
Doc_dup1  Offline
Carmel, CA
I have a set of the JRC carbs on an A65 and I love them. I had JRC set up the jets before they sent them out and they started on the first kick and I have had no problems. It does seem that you have a blockage, I assume that you have a single carb, and I can only add that you need to be careful when removing the float bowl. It requires a little manipulation if you don't have the option of turning it upside down. Once you get the thing working, you will love it.
Doc
Doc
Mostly Triumphs with a few BSA's a Norton, and two BMW's
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379087
06/15/11 5:35 pm
06/15/11 5:35 pm
Colorado
rstar45 Offline
rstar45  Offline
Colorado
Yep be careful of the overflow tube in the float bowl. If still on the bike, I found it really helps to use a pick or pocket knife to hold the floats up while you gently move the bowl around. When you hit the right spot it will simply fall off.
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379105
06/15/11 6:39 pm
06/15/11 6:39 pm
This thread is turning into one of the best advertisements for AMAL Concentric Carburettors that I've seen. Makes me appreciate mine!
Re: JRC PWK30 Carburettor on a BSA A65 [Re: Lannis] #379112
06/15/11 6:54 pm
06/15/11 6:54 pm
Brooklyn, NY, USA
jholmes Offline
jholmes  Offline
Brooklyn, NY, USA
^^^ bigt beerchug
Cheers!
-Jason
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379114
06/15/11 7:10 pm
06/15/11 7:10 pm
British Columbia
hh Offline
hh  Offline
British Columbia
As we all know, Amals never suffer from clogging, or bad machining, or wear, or leaky float valves, or improper jet sizing, or ...
Re: JRC PWK30 Carburettor on a BSA A65 [Re: ] #379903
06/20/11 5:18 pm
06/20/11 5:18 pm
Germany
Germany
theres no difference between the enrichener is pulled up or not. The floating chamber is filled with fuel without overflowing. I controlled the Main Jet and the pilot jet.
The carburettor is new, no dirt inside, i was decomposing it.
But the engine is running with an AMAL 389carburettor or a AMAL 928carburettor which a friend brought to me.
Why not with the PWK ?
Thanx
Markus
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379905
06/20/11 5:30 pm
06/20/11 5:30 pm
Das kann doch nicht wahr sein?
Where in Germany are you, Markus?
A friend of mine in Den Haag, owner of a motorcycle workshop, built several PWK's on several Nortons and Meriden Triumphs. He has several spares on stock also.
If it's not to far from you, you might come over with the PWK in your pocket and let him have a look at it.
What is the size of the main jet as you have it now?
When I received mine the main jet was #140. pilot #38, needle 3rd groove of five (middle).
I ran the bike with several jets, richer and leaner, but it allways ran and started first kick.
Since my bike still has to have some things fixed we might swap (tauschen). You send yours over to my mate in Den Haag, we can send my carb to you with the jetting as you have it now, if you agree to pay the mailman.
Let me know what you want.
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #379967
06/20/11 9:38 pm
06/20/11 9:38 pm
Duesseldorf/Germany
Phil in Germany Offline
Duesseldorf/Germany
Dear Markus,
I think I know you and the wonderful carb trouble... eek
If I was in your shoes I'd send the carbie to Ger and ask him to hand it to his mate in order to check the thingie.
Keep my 928 until you have a working PWK or get your Monobloc going/sleeved.
I can surely subscribe to Lannis' point of view. The Concentrics are by far better as their reputation. At least the A 65 starts with it....
Take care and good luck in finding a fix
Best regards
Ph.
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: JRC PWK30 Carburettor on a BSA A65 [Re: Ger B] #380249
06/22/11 9:05 am
06/22/11 9:05 am
Germany
Germany
Hi Ger, leider ist es wahr !
i live near Frankfurt/M., its to far to Den Haag (ca. 600km).
Thank you very, very much for the possibility of swapping the PWK, shall i send it to you or to your mate ? Of course i will pay all the neccessary fees, mailman, etc.
So lets exchange our adress for snailmail via PM, or not?
Thanx for your help !!!!
Greetings
Markus
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #380250
06/22/11 9:54 am
06/22/11 9:54 am
Frankfurt is indeed a bit far, Markus.
Let me consult my mate. My bike and the PWK are in his workshop in Den Haag. I live 25 km away so it's easier he receives your carburettor and sends mine directly.
I'll PM the adresses after I talked to him.
Re: JRC PWK30 Carburettor on a BSA A65 [Re: MarkusHorst] #380756
06/25/11 8:59 am
06/25/11 8:59 am
Markus you have a PM.
Page Time: 0.155s Queries: 15 (0.006s) Memory: 1.0949 MB (Peak: 1.3284 MB) Zlib disabled. Server Time: 2018-02-24 14:21:36 UTC
