Huntmaster
Huntmaster
Ottawa, Canada
41 registered members (Alan_nc), 249 guests, and 473 spiders.
10257 Registered Users
Lannis 60
TBolt72 46
609,192 mail-order LSR
Topics67,120
Posts651,371
Members10,257
BSF and BSC #374648
05/22/11 4:00 pm
05/22/11 4:00 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi guys. Just a random thought, but how do you guys distinguish between BSF 1/4-26tpi and BSC(or CEI)1/4-26tpi? For example, the rocker box nuts, the steering stem securing bolt and the brake arm stopper bolt for late rigid model are all 1/4-26tpi but I'm not sure which pattern is used. In addition to this, what is the difference between BSC and CEI? I know they are 60 degree but I don't know more details.
Machico
Re: BSF and BSC [Re: machico] #374656
05/22/11 4:54 pm
05/22/11 4:54 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I do not have my Machinery Handbook handy but I believe BSC has a 47.5 degree tooth form.
Re: BSF and BSC [Re: DMadigan] #374657
05/22/11 5:17 pm
05/22/11 5:17 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
I think the thread angle of BSC is 60 degree. The thread angle of BA is 47.5 degree.
Machico
Re: BSF and BSC [Re: machico] #374659
05/22/11 5:51 pm
05/22/11 5:51 pm
Stuart Offline
Stuart  Offline
Hi Machico,
BSF has a 55-degree included angle in the triangle formed by each thread peak or trough; otoh, as you've said, Cycle has a 60-degree included angle. Nevertheless, in general, it's almost impossible on decades-old parts.
However,:-
... when you know that, as a general rule, Triumph and BSA standards were BSF threads into aluminium alloy and Cycle threads into/on iron and steel (including nuts on bolts and screws), then you can make an educated guess depending on the component.
That said, the fun starts when you get a 1/4"-dia. stud that screws into an alloy component and takes a nut on the other end - both ends will be 26tpi but which end is BSF and which is Cycle? grin
Finally, bear in mind also there's BSB - British Standard Brass - thread. 26tpi at all the diameters Cycle is, but 55-degree included angle. smirk
Re: BSF and BSC [Re: Stuart] #374681
05/22/11 9:28 pm
05/22/11 9:28 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Stuart
This is very interesting. I didn't know that. So, the parts I listed as an example are all cycle thread right? Are there any source of this rule?
Is this because aluminum alloy is more fragiler than steel? I'm just guessing but it seems that the thread of BSF is deeper than cycle thread and the deeper thread may be better for fragile material? Am I correct?
In this case, I will ask you which is which. grin
But are there any studs like that for Triumph? The 1/4 studs for rocker box have a BSW 20tpi and a BSC(CEI?)26tpi on the other end. I thought the 1/4 studs for the oil pump are same pattern as rocker box studs.
If the length of the thread is different from each side, it is easy to distinguish though.
Oh no. I didn't know this either. It's so complicated!! Is BSB pattern used in Triumph model?
Thanks for your very informative post!
Machico
Re: BSF and BSC [Re: machico] #374688
05/22/11 9:54 pm
05/22/11 9:54 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
BA, BSC, BSF, BSP, BSTP, BSW, CEI, UNC, UNF, ME, BSB.
http://www.britishfasteners.com/threads/
Re: BSF and BSC [Re: L.A.B.] #374767
05/23/11 8:47 am
05/23/11 8:47 am
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Thanks for the website! laugh
Machico
Re: BSF and BSC [Re: machico] #374823
05/23/11 4:09 pm
05/23/11 4:09 pm
Stuart Offline
Stuart  Offline
Hi Machico,
A lot of the time; as I said, "you can make an educated guess".
There probably was at some time somewhere; I just know it by observation.
Ime, not generally at the torques used on motorcycles. If the designers were that worried, imho they'd have used a coarser thread into aluminium. After 1968, when BSA and Triumph changed to Unified threadforms, they used UNC into alloy; if they'd been worried before, they'd have used Whitworth (BSW) which is the same tpi as UNC for each diameter (except 1/2"). Problem with a coarse thread on something that vibrates (not that British singles and twins vibrate much whistle ) is it takes less rotation to loosen than a fine thread. frown Subsequently, the Japanese used metric coarse threads, which aren't that dissimilar to BSF threads at similar diameters (e.g. M5 31.8tpi, 3/16"BSF 32tpi M6 25.4tpi, 1/4"BSF 26tpi, M8 20.3tpi, 5/16"BSF 22tpi).
which is which.
the fun starts
I can't remember where but I think I must have come across it/them, or I wouldn't have thought of the problem?
Not really. I didn't mean to confuse you; afaik, neither Triumph nor BSA, not any of their suppliers used it. However, sometimes it's difficult to get the correct Cycle-thread tap or die and, especially if you want to just clean up a thread, sometimes knowing about BSB can sort out the problem quickly. wink
Re: BSF and BSC [Re: machico] #374831
05/23/11 5:52 pm
05/23/11 5:52 pm
Peter R Offline
Peter R  Offline
Machico, 1/4BSF and 1/4 BSC both have 26 turns per inch. But the thread angle of BSF Has 55 deg, while BSC is 60 deg, the difference between te two is difficult to see with the naked eye. I advise to buy a thread gauge to determine what thread you are dealing with, but even with a thread gauge the difference between 1/4 bsf and 1/4 bsc will not be easy to spot.
Anyway, with the aid of thread gauges, a caliper and a screwthread tables it is usually fairly simple to determine what thread type you are dealing with.
Concerning BSC thread, it is not generally known that a type of BSC thread exists with 20tpi rather than 26tpi, this is used for the rocker spindles, and brake cams on the BSA Goldstar for example.
Confusing? maybe, but with the aid of the above mentioned tools it is certainly no rocket science to find out what thread you are dealing with on your British bikes.
Re: BSF and BSC [Re: machico] #374854
05/23/11 8:23 pm
05/23/11 8:23 pm
HawaiianTiger Offline
All the pre units used coarse thread into alloy. That fine thread was a unit thing....
I've never had a case screw back out. If anything, they get tighter. Oh, and I don't use cap screws either as they are way too easy to over-tighten.
There are five 22tpi oddball fasteners on a pre unit. Four handlebar bolts and the one case bolt just below the cylinder in the back. Must be Whitworth or something else instead of CEI.
Re: BSF and BSC [Re: Stuart] #374936
05/24/11 6:17 am
05/24/11 6:17 am
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Stuart,
I have been kinda confusing but I noticed that BSC isn't used into alloy for pre unit. As you said, they used coarser thread which is BSW into alloy. when I get confused regarding BSF 1/4 26tpi and BSC 1/4-26tpi, I will follow the line which is "BSF into iron or steel". It is kida easy rule but I still don't get used to the british thread.. frown
Machico
Re: BSF and BSC [Re: Peter R] #374938
05/24/11 6:51 am
05/24/11 6:51 am
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Peter,
I have a thread gauge and the thread table but as you said, it is difficult for me to determine which pattern for the 1/4-26tpi is used by thread gauge and naked eye. When I wanted to clean the 1/4-26tpi thread with tap, I just couldn't figure out which tap I should use into the thread. Only 1/4-26tpi makes me confused because they have same size and same tpi. frown
Surely BSC 9/16-20tpi is used to gearbox adjuster for rigid pre unit too.
Anyway, as you said, it is easy to determine the thread type by using the gauge and the table but I still have to be used to the british thread. frown
Machico
Re: BSF and BSC [Re: HawaiianTiger] #374944
05/24/11 7:24 am
05/24/11 7:24 am
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Yes, I noticed that BSW is used into alloy.
I don't use cap screws either. I have broke up the thread hole before. eek
Really? Four Handlebar bolts are BSF5/16-22tpi but the bolt just below the cylinder in the back is BSW5/16-18tpi. Mmmm.. wait. Not BSC but BSF is used for handlebar bolt?? confused
Anyway, it seems that small amount of BSF is used for pre unit.
Machico
Re: BSF and BSC [Re: HawaiianTiger] #374964
05/24/11 11:18 am
05/24/11 11:18 am
triton thrasher Offline
All the pre units used coarse thread into alloy. l
Not quite all.
The short alternator Thunderbird primary case on my Triton has fine threaded screws holding the cover on.
Re: BSF and BSC [Re: Stuart] #374983
05/24/11 1:25 pm
05/24/11 1:25 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
I found the 1/4 stud 26tpi both side. E3956. I'm not sure where to use it though. Maybe studs for AMAL?
Machico
Re: BSF and BSC [Re: machico] #375026
05/24/11 5:02 pm
05/24/11 5:02 pm
Stuart Offline
Stuart  Offline
Hi Machico,
That reminds me. Not strictly relevant to you but, on pre'69 (when they changed to Unified threads) single-carb. unit twins, the manifold is mounted to the head with four 1/4" studs. The head's alloy, so BSF; the other end of each stud takes a nut, so Cycle. There are probably others grin
Originally Posted By: triton thrasher
Not quite all.
Not helped by even the correct tap or die will almost always remove a small amount of metal from the thread. frown
If you're unsure whether to use a Cycle or BSF tap/die on a 1/4"-26 thread, if you think about it, start with Cycle. Because, with a 60-degree included angle on each thread peak or trough, from the same nominal outside diameter, the Cycle thread is slightly shallower than the 55-degree i.a. BSF thread.
Then, only if the cleaned thread still doesn't work, cut it a little deeper with the BSF tap or die.
grin
Afaik:-
. 20tpi Cycle applies only to diameters 7/16" and larger;
. Triumph used them extensively.
1/4BSF and 1/4 BSC
BSF has a 55-degree included angle in the triangle formed by each thread peak or trough; otoh, as [Machico] said, Cycle has a 60-degree included angle. Nevertheless, in general, it's almost impossible on decades-old parts.
Always worth reading the whole thread before posting, so you don't post duplicate information. wink
Re: BSF and BSC [Re: Stuart] #375071
05/24/11 9:01 pm
05/24/11 9:01 pm
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
Hi Machico,
NOT SO with a tapped hole.Use a 26 tpi BSF or Brass tap first.Smaller nose radius and 55 degree angle takes out less metal.
A BSC die will take less metal off a bolt or stud.
Re: BSF and BSC [Re: Stuart] #375306
05/25/11 9:55 pm
05/25/11 9:55 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
grin
Oh shocked
Thanks for pointing out. I use BSF, BSC, BSW, Japanese and English. I got so mixed up crazy
Machico
Re: BSF and BSC [Re: Pete R - R.I.P.] #375314
05/25/11 10:21 pm
05/25/11 10:21 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Machico,
mmmmm, I have never seen the drawing of the both type of threads so I'm not sure exact dimension but I think the BSF thread is shallower than BSC thread to me if I think of it simply. They have same diameter and same tpi. So as Pete R said, it seems that the BSF have a smaller nose radius than BSC. BSF 26 tpi tap first for the holes and BSC die first for the bolts and studs sound better to me. smile
Machico
Re: BSF and BSC [Re: machico] #375324
05/25/11 10:47 pm
05/25/11 10:47 pm
Stuart Offline
Stuart  Offline
Hi Machico,
BSF, Cycle
As you can see from the table under each drawing, for the same nominal o.d., Cycle thread core diameters (i.e. measured from the bottoms of two opposite threads) are greater than BSF thread core diameters. So the Cycle thread must be shallower than the BSF thread.
But the included angle at the nominal peak or trough of each thread is different. Or, as I say, just compare the core diameters for each o.d. wink
Re: BSF and BSC [Re: Stuart] #375337
05/26/11 12:09 am
05/26/11 12:09 am
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Machico,
BSF, Cycle
First, I misunderstood the word "shallow". I thought it means narrow or something but it is different. Sorry.
Thanks. I saw the both drawings. Now I understand what you are saying. Surely BSC thread is shallower than BSF thread when I compare the core diameters. That's why the bigger size of tapping drill is used for BSC. According to the table and the drawing, when I'm unsure whether to use BSF 1/4-26 tap or BSC 1/4-26 tap, it's better to use the BSF tap first instead of BSC not to make the core diameter of the hole bigger. When I clean the studs and bolts, it's better to use BSC die first. smile
Machico
Re: BSF and BSC [Re: machico] #375393
05/26/11 11:20 am
05/26/11 11:20 am
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
I just refreshed my memory with a quick peek at my copy of "Machinery's Screw Thread Book; 20th Edition 1969"!
BSW and BSF conform to the Whitworth threadform which has a 55 degree thread angle. British Standard Cycle thread has a 60 degree thread angle. BSF and BSCy only coincide at 26 tpi 1/4" major diameter. You would be very pressed to notice the difference if using a tap to chase out a thread.
Regarding the usage of BSF; my '60 T120 only has one BSF thread holding the handlebar clamps (Steel bolts into the forged triple-T). This is 5/8" 22 tpi. (presumably this thread pitch was chosen as a compromise between strength and vibration performance) All other threads were BSW (almost always into castings), BSCy 26 for fasteners (although there seems to be an unofficial optional 20 tpi for 1/2" and above) and BA for electrical and instruments. After 1962, (I am not sure of my ground which models and when), there was a progressive adoption of unified threads but with the retention for quite a long time of BSW in castings (a mish-mash if you want).
It's almost like a history lesson which started in the Industrial Revolution!
FWIW
mike
Member #: 147
1960 T120 Bonneville
1999 H*%^a VFR 800 FI
V4 Triton Project (still keeping me sane (Ha-Ha!))
Re: BSF and BSC [Re: t120mike] #375419
05/26/11 2:15 pm
05/26/11 2:15 pm
Stuart Offline
Stuart  Offline
Hi Mike,
Ime, you don't see BSA itself (the parent company rather than the marque) adopting Unified threadforms 'til 1968. In 1965, the British government announced the Britain was going metric and the changeover would take ten years. The British automotive industry's (when we had one) answer was to adopt Unified threadforms, which is mainly why BSA did.
BSA's policy seems to have been that threads were only changed if a component was redesigned. Obviously, that wasn't always possible - if the changed component affected those around it, the threads on those might have to be changed to match, even if the components themselves weren't otherwise changed. Otoh, for example, in the 500 and 650 cylinder blocks, the threads for the head bolts and studs remained Cycle - I believe the bigger block changed to Unified when the capacity was increased to 750(?) - but the 500 block never did.
In fact, 7/16" and larger-diameter Cycle threads can be 26tpi or 20tpi; Triumph used 20tpi where it was available, I'm only not sure what the standard was for 7/16" specifically.
Re: BSF and BSC [Re: machico] #375423
05/26/11 2:45 pm
05/26/11 2:45 pm
Tridentman Offline
Tridentman  Offline
Confirm that the 650 head bolts and studs remained as Cycle thread right to the end of the 650 Bonneville (certainly on my 1974 T120RV---one of the last 650 Bonnies).
You are right IME that they changed to Unified threads on the 750 Head bolts and studs.
In terms of the 1/4" BSF vs. BSCY situation IME after 40/50 years it doesnt much matter which you use--- the threads are pretty much buggered about by now.
I have just finished stripping a 1965 T100SR and on the fringe parts (the parts that DPO could get to easily) I found BSF, BSCy, UNC, UNF and metric threads and fasteners!
Re: BSF and BSC [Re: Tridentman] #375447
05/26/11 4:54 pm
05/26/11 4:54 pm
JAPAN
machico Offline OP
machico  Offline OP
JAPAN
Hi Tridentman,
This is interesting. I have 1968 TR6C and am interested in Unit triumph too. Thanks for the informative info.
I think so too. I may not have to be so nervous about it because the taps or dies may be made with worn out equipment and the reproduction bolts and nuts may be made with worn out tap, dies or lathe after all. As you said, the threads may be buggered about by now. But what if the parts I want to clean is NOS? confused
However, I'm new to Triumph and want to use right tool as much as I can to learn the British threads and tools. smile
shocked shocked shocked!! Crazy! too many kind of threads! crazy
Machico
