The Bonneville Shop
PhilM
PhilM
UK London
47 registered members (Al Eckstadt), 315 guests, and 439 spiders.
JD8, John Rowley, Zoot, sal pisciotta, Shawn G
10529 Registered Users
franko 89
Lannis 82
NickL 73
786,017 mail-order LSR
Topics69,227
Posts674,404
Members10,529
Engine Numbers #375238
05/25/11 5:54 pm
05/25/11 5:54 pm
NYC
djg42 Offline OP
djg42  Offline OP
NYC
Hello,
On my engine it says 71-1033. I cant find a number on the frame, near the handlebars on the right side where I would expect to see a frame number its stamped "Laughing Madness" Whatever that is...
Any idea what this engine number means and why theres no frame number? I believe my bike is a 1970 Lightning.
Re: Engine Numbers [Re: djg42] #375243
05/25/11 6:22 pm
05/25/11 6:22 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
A few things that will tell you real quick if your bike is a '70 or not would be the swingarm, there should be a solid shaft with bronze and steel bushing rather than the earlier tube with rubber bush . Then there are the two tubes welded to the headstock for a fairing mount . If you have both of these it is a '70, the numbers should be stamped on a squared off lug on the drive side front motor mount .
FWIW-BONZO
Re: Engine Numbers [Re: djg42] #375294
05/25/11 9:19 pm
05/25/11 9:19 pm
Stuart Offline
Stuart  Offline
That looks more like a part number. What part of the engine is it on?
By 1970, I believe engine numbers are similar to Triumphs - stamped on a raised area ('pad') of the left-hand crankcase just below the block?
Re: Engine Numbers [Re: djg42] #375341
05/26/11 12:40 am
05/26/11 12:40 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Stuart's right, the serial number can be found here on a 1970 A65 engine:
Josh
