Spitfire Ken
Spitfire Ken
Illinois
29 registered members (BikeVice), 202 guests, and 453 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 62
633,845 mail-order LSR
Topics67,352
Posts653,894
Members10,285
A65 gearbox driven speedo ratio #369202
04/20/11 7:19 pm
04/20/11 7:19 pm
London,Great Britain
KevRasen Offline OP
KevRasen  Offline OP
Hello All,
Ref: 1966 A65L - Anybody know what the speedo drive ratio is when driven from the gearbox ? 1000-1 or 1600-1 or different ?
Cheers in advance for any info.
Kev
Re: A65 gearbox driven speedo ratio [Re: KevRasen] #369327
04/21/11 4:02 pm
04/21/11 4:02 pm
Canada
LarryLebel Online content
LarryLebel  Online Content
Canada
The 1000 and 1600 numbers you quote are turns/mile (of the speedo cable) for 15/12 and 2/1 ratio, respectfully, rear wheel speedo drive gears. I don't know for sure but I'm going to guess that transmission driven speedos are mechanical (chronometric) and that the 'modern' magnetic speedos, that you refer to, might not be compatible. You can measure the 'ratio' of your transmission drive mechanism yourself by counting the turns of the speedo cable for, say, 10 turns of the rear wheel (tranny in a gear). The ratio of this number to 10 is the ratio of the drive. To work with a 1000 speedo it would have to be 15/12 or 1.25/1, to work with a 1600 it would have to be 2:1, assuming a standard size BSA rear wheel. You can determine the exact turns/mile you require by calculating how many turns your particular wheel makes in a mile, then multiply this number by the drive ratio.
Re: A65 gearbox driven speedo ratio [Re: KevRasen] #369338
04/21/11 4:54 pm
04/21/11 4:54 pm
Rich B Offline
Rich B  Offline
I would have thought a 66 BSA would be rear wheel drive speedo. But it may be a 65 titled as a 66 or some other strange situation..... eek
The 65 service manual has a nice page listing all of the available ratios based upon wheel size, sprockets, etc. But be careful, a lot of the combinations are difficult to find the correct gears for. There are also gears that are misidentified in people's stock.
If I remember right, the 65 parts book identifies the correct Smiths magnetic speedo to use as well.
Re: A65 gearbox driven speedo ratio [Re: LarryLebel] #369350
04/21/11 6:38 pm
04/21/11 6:38 pm
Originally Posted By: LarryLebel
(tranny in a gear)
Doesn't matter if it's in gear or not. Speedo drive comes off the layshaft which is always directly linked to the rear wheel via the sleeve gear.
Re: A65 gearbox driven speedo ratio [Re: KevRasen] #369365
04/21/11 8:23 pm
04/21/11 8:23 pm
My 1965 A65T/R came with a 'SSM 5001/03A 1600'. Of course the accuracy will depend on the gearbox and rear wheel sprockets in use.
Re: A65 gearbox driven speedo ratio [Re: Gordo in Comox] #369369
04/21/11 8:46 pm
04/21/11 8:46 pm
KevRasen Offline OP
KevRasen  Offline OP
Cheers everybody for the info,
I hadn't thought about the drive sprocket affecting the ratio !
I might give the back wheel revolutions/speedo drive revolutions a try just out of curiosity - I had planned to fit a 19/47 set up.
The bike is a matching numbers 66 - but who knows when the cases were made !
It did come with a rear wheel speedo drive as well so I've got the option to stick with that instead - it's not a detailed show bike so whatever works is good for me. I fancied the gearbox drive purely to have a shorter cable and less "mess" along the swinging arm.
But I've just come out of the garage and looking at the bare frame on a table and the scattering of engine parts on my bench I think it'll be a while before the speedo comes into play !!!
Again - cheers for the feedback,
Kev
