DamienE
DamienE
Palm Bay, Fl.
36 registered members (AML), 215 guests, and 61 spiders.
10383 Registered Users
NickL 98
Mori55 89
Stuart 77
reverb 76
DavidP 71
Triless 71
Rohan 69
btour 65
689,335 mail-order LSR
Topics68,024
Posts661,788
Members10,383
Page 2 of 2 1 2
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366801
04/05/11 7:26 pm
04/05/11 7:26 pm
Tridentman Online content
Tridentman  Online Content
Bob---I think you are confusing me with Triton Thrasher (TT)---he thrashes Tritons----I just restore and ride Triumphs ---which is a lot lower down the pecking order!
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366803
04/05/11 7:31 pm
04/05/11 7:31 pm
Massachusetts, U.S.A.
btour Online content
btour  Online Content
Oh yes, I did. My sincerest apologies. No wonder it was such good advice, since coming from lower down in the pecking order. laughing Power to the Plebeians. smile
Re: T100R Not Charging & Turn Signal Trouble [Re: Tridentman] #366820
04/05/11 8:46 pm
04/05/11 8:46 pm
JubeePrince Offline
JubeePrince  Offline
Originally Posted By: Tridentman
You really need a dedicated earth line from the turn signal housing to the red earth line on the bike (whether it is the standard red earth line or a SPG is of second order importance).
I have always found that it is possible (although sometimes difficult) to get an earth wire through the center of the stem. Then fit a small ring terminal and put that under one of the screws holding the reflector bowl into the turn signal housing and the other end as mentioned to the red earth line or SPG system.
What T-man said. It IS a tight fit, but it can be threaded thru the stem/stalk....standard automotive wire (16 guage, 18 strands). Tied into the ground for the headlight in the bucket.
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366821
04/05/11 9:14 pm
04/05/11 9:14 pm
Nice photo of how to do it Steve!
BTW I have had stems where it would have been impossible to get wire through of the size shown in Steves photo.
I normally use wire of about half that diameter.
However the important thing is not the size of the wire but getting a wire there.
As stated previously the duty on the wire is low--less than 2 amps and intermittent even when in use and then not in use for most of the time.
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366822
04/05/11 9:16 pm
04/05/11 9:16 pm
BTW Steve---what is that second red wire in the photo of the flasher light unit?
Re: T100R Not Charging & Turn Signal Trouble [Re: Tridentman] #366827
04/05/11 10:06 pm
04/05/11 10:06 pm
JubeePrince Offline
JubeePrince  Offline
T-man - I think what you're seeing is just a reflection of the one red wire....
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366834
04/05/11 10:43 pm
04/05/11 10:43 pm
Steve---OK---yes thanks---I see it now.
Problem with getting old (no not old just less young!) I guess---seeing double!
Seriously---thanks for posting the photo----I was trying to explain it in words but as usual---one picture is worth a thousand words.
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366860
04/06/11 5:36 am
04/06/11 5:36 am
Arizona
desertrat Offline OP
Private sponsor
Private sponsor
Arizona
Some good results after taking the tank off.
A couple of crossed and bad connecions found and now have good connections front to rear. If I manually ground the front signals, I actually have the right side working! I have some new connectors coming to replace the shakey units.
My guess is the left side will come around once the grounds are set completely. The indicator lamp flashed as well. The stalks are definately limited clearance as noted in the comments. I'll figure a way to get something connected through there.
I have a white/red wire under the tank coming from the left switch that is not connected anywhere. I can't find that color on the wiring diagram, it's under the lower button on the switch.
If memory serves, that is the engine kill switch, which was working previously, I must have disconnected it under the tank when working on the signal wires. I don't see a matching wire running fore or aft to connect it to.
Other than that, looks like I'm on my way to happy signaling land.
Thanks A.gain for all the suggestions.
1975 Norton MkIII
1974 Ducati 750GT
1974 Ducati 750GT Sport Style
1971 Moto Guzzi Ambassador
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366871
04/06/11 8:54 am
04/06/11 8:54 am
Stuart Online content
Stuart  Online Content
Nope.
The engine kill switch is - in the handlebar switch cluster - White in, White/Yellow out. That you "don't see a matching wire to connect [White/Yellow] to" is because, as standard, it connects to the -ve terminal of each coil (assuming +ve earth/ground). Otoh, if the bike has electronic ignition, White/Yellow from the handlebar kill switch is then the input to the e.i. box and not the coils directly.
White/Red connects to an electric start relay. It wasn't used until the T160 (which uses different handlebar clusters) but was included in the '71-on clusters for the Bandit and Fury, some variants of which would've had electric starters. Fwiw, 'cos it's supplied by the White wire into the relevant handlebar cluster, rather than have it as a potential short-circuit generator some time down the line, I connect it into the Blue/White (headlamp main beam) connector in the headlamp shell as an extra headlamp flash button.
As I said before, I've never had a problem with indicators grounding just through the thin layer of chrome over the plastic body so I just attach any ground wire to the 'bike end' of the stem. As others have said, an indicator bulb draws less than 2 Amps and it's intermittent. Just connecting an Ohm- or multi-meter between the grounded side of the bulb holder and the 'bike end' of the stem will tell you if you have a good ground path.
Pleased to have been of some help.
Re: T100R Not Charging & Turn Signal Trouble [Re: desertrat] #366911
04/06/11 3:43 pm
04/06/11 3:43 pm
Arizona
Private sponsor
Private sponsor
Arizona
Interesting,
I should have mentioned since it's been referenced a few times, this engine still has points ignition. Given the low mileage it will likely see, I'll probably leave it that way. I am a fan of the Tri-Spark though. It made a major difference on my Norton when swapped for an old Boyer.
Since my kill switch works, obviously it was the other button on the switch, the white-white/yellow combination and that is fine.
I just mis-rememberd which button it was.
I'm happy to hear the white/red isn't supposed to have a mate on my bike. I like your idea for the added headlight flasher, more gentlemanly than an additional horn I think.
Funny about the turn signal grounding. The rears ground fine through the housings/stalks, but I plan to ground them seperately as well. The right front will ground through the housing/stalk to the headlamp bucket when checked with a VOM.
The left front will not! Must be some terrific insulation available on that side. Looks like my ground wire for that will have to connect to the harness ground. Looks like I have some skinny wire fishing to do at the front.
When it's complete and flashing, maybe I'll post a video so everybody can join in the celebration.
1975 Norton MkIII
1974 Ducati 750GT
Page 2 of 2 1 2
