Chris
Chris
Newburyport, MA, USA
194 registered members (1xfatboy), 1,759 guests, and 593 spiders.
Lannis 144
kommando 105
Stuart 64
476,837 mail-order LSR
Topics65,721
Posts635,229
A65 CDI affordable Ignition kit #366430
04/03/11 5:42 pm
04/03/11 5:42 pm
Ipswich England
wbabojo Offline OP
wbabojo  Offline OP
Ipswich England
Hi all, been a while since I last wrote, but I stumbled across this. I've currently got a Boyer Micropower on my A50DC, but have never really been satisfied with the advance curve,it just doesn't 'feel' right. Could I run this and power lights etc? Anybody got one? Anyone any experience of this set up?
http://www.tmf-racing.de/images/electrex/Installation%20Race%20Stator.pdf
"Life is like a toilet roll, the nearer the end, the quicker it runs out"
Gavin
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366441
04/03/11 7:00 pm
04/03/11 7:00 pm
Ipswich England
wbabojo Offline OP
wbabojo  Offline OP
Ipswich England
Hi all, not an advert I promise, but they will be at Stafford show 24th Apr. They are currently developing a system that will run lights as well. Answered my own question really, any thoughts?
Gavin
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366527
04/04/11 4:18 am
04/04/11 4:18 am
Man, I'm eager to hear more about those things.
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366534
04/04/11 5:02 am
04/04/11 5:02 am
DavidP Online content
DavidP  Online Content
"Hits a sweet spot at 5000rpm."
Because that's where it's supposed to be fully advanced, NOT before.
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366564
04/04/11 12:57 pm
04/04/11 12:57 pm
This is the main UK site, currently fitted to trials and scamblers that need no lights, not seen much feedback on them at all so can offer no advice on if they are any good.
http://www.electrexworld.co.uk/
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366569
04/04/11 1:30 pm
04/04/11 1:30 pm
Looks like a PVL system. I use them on my race bikes. They work great.
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366768
04/05/11 4:41 pm
04/05/11 4:41 pm
BSA_WM20 Online content
BSA_WM20  Online Content
It is a variation to what is standard on a lot of single & twin rice burners.
I used to run SR 500's for work as a metrop courier ( despatch rider for some ).
After about 2 years ( 300,000 km ) the wires in the spark power coil burn out and the stator needed to be rewound.
Basically the kit is a fly wheel magneto.
The big coil on the stator generates the power for the plug coil.
It dose a lot of work on a twin.
The unit probably runs an ac high voltage coil which has a lot finer wire than the standard 12V lump so never test it by flashing it across you battery or you will cook the wires
OTOH timing from the crank is a lot more accurate than from the cam.
Apart from the coil burning out they never gave me a seconds worth of problems and these bikes took a pounding.
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366780
04/05/11 5:43 pm
04/05/11 5:43 pm
Trevor, it does exactly the same work on a single as on a twin...the only difference is the twinspark coil. Unless you ran without lights, it is not this unit. This appears to be either a re-badged PVL or possibly a copy. No burning coils, these are designed for 15000 rpm.
Re: A65 CDI affordable Ignition kit [Re: ] #366802
04/05/11 7:29 pm
04/05/11 7:29 pm
Originally Posted By: 1968BSA
15,000 on a A65, im not saying it ain't possible, but i'd like to see it!
I suspect that Alex is pretty sure that a BSA A65 engine wasn't what he had in mind for 15,000 RPM (or anything over 8,000 as a matter of fact).
But some twins do see RPMs like that, like a Kawasaki 250 Ninja.
If you read Larry Niven's "The Magic Goes Away" and read how the Warlock's Wheel operates, that would pretty much describe an A65 trying to cross 10,000 RPM!
We're approaching the tipping point ... where those who vote for a living will outnumber those who work for a living .....
Re: A65 CDI affordable Ignition kit [Re: wbabojo] #366816
04/05/11 8:34 pm
04/05/11 8:34 pm
Yes, these ignitions were originally intended for 2-strokes but they can, obviously also work on four strokes with waste spark. PVL makes them available in different combinations of stators and coils for different RPM ranges, the trials versions do not go quite as high in rpm.
And no...I wasn't suggesting a BSA would turn that fast...even though I've pushed the envelope, I know.
