Hortons Norton
Hortons Norton
California U.S.
34 registered members (998John), 150 guests, and 127 spiders.
10389 Registered Users
NickL 96
Triless 87
Mori55 85
reverb 79
DavidP 72
btour 67
691,474 mail-order LSR
Topics68,055
Posts662,181
Members10,389
Where to mount electronic ignition? #365486
03/29/11 3:47 am
03/29/11 3:47 am
Texas USA
DaveOfTexas Offline OP
Texas USA
Same for that box, no indication where it goes. Any suggestions on some good places to mount it?
1969 BSA B44VS PC8113
Engine PC8113B44VS
Recently acquired (Feb 2011) Aiming to get running and return all parts/configurations to original.
First BSA. Have 1970 Honda CB750 too.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365509
03/29/11 9:41 am
03/29/11 9:41 am
kommando Offline
kommando  Offline
I have mine in the space between the 2 gusset plates behind the headstock, its stuck to one of the plates and does not overheat in UK.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365526
03/29/11 11:59 am
03/29/11 11:59 am
Ponoka ,Alberta,Canada
A.k.a Homer Offline
A.k.a Homer  Offline
on my a65 i put it in the center of the bracket holding the ignition coils.
Aka Homer
A day with out learning something new is a bad day indeed.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365531
03/29/11 12:23 pm
03/29/11 12:23 pm
Under the battery box. Greg Fauth (Norbsa)makes a nice bracket for this.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365547
03/29/11 2:32 pm
03/29/11 2:32 pm
Cable-tied to the underside of the frame top tube between the fuel tank and seat.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365588
03/29/11 7:14 pm
03/29/11 7:14 pm
Homer and Alex got both my spots, ignition between the coils, regulator under the battery.
However, that's an OIF A65. Don't know where to put them on a B44.
72 T150V yet to be named
Re: Where to mount electronic ignition? [Re: DavidP] #365613
03/29/11 8:57 pm
03/29/11 8:57 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
i agree with homer and alex...reg under the batt and box between the coils on my 72 T120 OIF
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #365672
03/30/11 3:12 am
03/30/11 3:12 am
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
in a cardboard box, on a shelf in the shed.
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366008
04/01/11 12:59 pm
04/01/11 12:59 pm
Texas USA
Texas USA
OK I think I need to be spoonfed a little on this guys,
lets look at the VR first. I have the battery mount and the VR bracket.
Included in pic is the electronic ignition, lets set that aside for now.
Engine PC8113B44VS
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366021
04/01/11 1:52 pm
04/01/11 1:52 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
Dave,If you are calling that box on the right a regulator,you should be aware that it looks Exactly like a Pacifico battery eliminator. Jack
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366033
04/01/11 3:17 pm
04/01/11 3:17 pm
kommando Offline
kommando  Offline
A lot of the answers refer to an A65 which you do not have, as you can see from the pics below the battery tray on a B44 3 bolts drop down to a couple of support brackets which stop you mounting boxes below the battery tray unless they fit between the 2 brackets plus it does get mucky there. I mount the regulator where the orginal rectifier went which is behind the toolbox where the red wires are exiting your harness (which I use for the earth for the regulastor), I also fit the capacitor in the same area. Unless you are fitting an oversize capacitor like I do there should also be enough room to fit the electronic ignition, downside is to get to the boxes the seat has to come off by loosening the 2 top shock bolts. I prefer the electronic box to be near the coil (or coils if twin sparked) so go for the gussets behind the headstock but it can go further back as the wires from the timing chamber normally run back to the orginal postion for the now redundant points condensor just up from the rear engine mounting bolt.
Re: Where to mount electronic ignition? [Re: Jack Adams] #366059
04/01/11 6:01 pm
04/01/11 6:01 pm
Texas USA
Texas USA
Battery Eliminator? WTH is that? I was told it was a VR. That is why I am on bb.com I guess! Thanks Jack.
Do I need it? What does it do?
Engine PC8113B44VS
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366155
04/02/11 2:27 am
04/02/11 2:27 am
Texas USA
Texas USA
I am reading elsewhere to discard the battery eliminator. I already have a battery anyway and plan to keep it in that configuration. Some say the B.E. may cause damage to other electrical components like the rectifier.
Engine PC8113B44VS
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366288
04/02/11 9:48 pm
04/02/11 9:48 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
Dave, If you don't want it, I believe Leon Bee might take it off your hands. Jack
Re: Where to mount electronic ignition? [Re: DaveOfTexas] #366344
04/03/11 4:26 am
04/03/11 4:26 am
Texas USA
Texas USA
Jack, it is not mine to give but I will ask the owner. Might sit on it til the project is complete. Nothing will be thrown away regardless.
Engine PC8113B44VS
