glastrywhippet
glastrywhippet
co.down n.ireland
45 registered members (Alan_nc), 296 guests, and 461 spiders.
Kara Chaffee, Dan1818, Konaflyer, Begbie, Andrew Fallo
10420 Registered Users
btour 84
Rohan 78
Triless 70
reverb 68
713,931 mail-order LSR
Topics68,332
Posts665,254
Members10,420
Speedo Drive for 1952 BSA #365171
03/27/11 5:07 pm
03/27/11 5:07 pm
Solebury,Pennsylvania, USA
Cheyenne Offline OP
Cheyenne  Offline OP
Ok,,basically I need to know if one exists that will fit a 1952 A7 plunger axle ? I changed out all of the guts I had from and old 50's hub into a mid 60's hub. The 60's axle OD was much smaller that the 52's,,was a speedo made that will fit or can I modify one ?
Re: Speedo Drive for 1952 BSA [Re: Cheyenne] #365172
03/27/11 5:10 pm
03/27/11 5:10 pm
Isn't the speedo driven off the gearbox on the early twin?
Re: Speedo Drive for 1952 BSA [Re: Cheyenne] #365205
03/27/11 6:41 pm
03/27/11 6:41 pm
Cheyenne Offline OP
Cheyenne  Offline OP
It could be but need to know about a speedo that will fit the hub axle combo
Re: Speedo Drive for 1952 BSA [Re: Cheyenne] #365309
03/28/11 8:26 am
03/28/11 8:26 am
North East England
beezageezauk Offline
North East England
Hi Cheyenne,
Has your bike got a "Crinkle Hub"? If so, some A50/A65 models had Crinkle Hubs with the speedo gearbox attached but I don't know if one of these would fit your setup. Maybe this is the one you've already tried.
Beezageezauk.
Re: Speedo Drive for 1952 BSA [Re: ] #365316
03/28/11 11:20 am
03/28/11 11:20 am
Cheyenne Offline OP
Cheyenne  Offline OP
Originally Posted by overandout
Show us a picture of your setup and we might be able to help you.
Well don't see how that will help much as I kinda explained,,but here it is anyway.
Yes both QC hubs,,just that the 1952 has a much larger OD axle than the 60's bikes,,so that is the only real issue I was inquiring about. The axle is 7/8 OD
Re: Speedo Drive for 1952 BSA [Re: ] #365409
03/28/11 8:19 pm
03/28/11 8:19 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
If I am reading this correctly what you have is a 60's hub with early 50's internals and the only reason the drive will not fit is the smaller I.D. in the drive ?If so , I'd have to agree with overandout. The only issues I might expect would be the thickness of the spacers on the drive side , you would have to turn them down to acommodate the extra thickness and maintain alignment . Does this drive need to be functional or just covering the end of the hub . Some of the offroad models had a cover to replace the drive as I recall.
Now , if I have this straight , the drive you are after needs a 7/8" hole? I'll check my stash .
FWIW-BONZO
Re: Speedo Drive for 1952 BSA [Re: BONZO R.I.P.] #365538
03/29/11 12:49 pm
03/29/11 12:49 pm
Cheyenne Offline OP
Cheyenne  Offline OP
FWIW-BONZO
If there is a cover that would be perfect,,and yes you are correct. I just want to close it up so to speak, so if there is a cover that would be great. Thanks
