Marvin E. Woody
Marvin E. Woody
Far Northwest Washington
194 registered members (79T140E), 2,212 guests, and 560 spiders.
GabrielSoren, JoshP, spikey45, trevor's, myshootingstar68
10077 Registered Users
koan58 84
Lannis 81
504,067 mail-order LSR
Topics66,031
Posts639,115
Members10,077
Spark plugs for A65'S?? #365028
03/26/11 9:33 pm
03/26/11 9:33 pm
Sacramento California
Rusty Goose Offline OP
I need plugs for my '66 A65L (twin carb 1970 head, using Sparx ignition). NGK's seem to be easily available to me. What # am I looking for. Or is there another brand I should consider?
I'm not trying to start anything as inflamitory as an oil thread here!
Rusty
1967 A65 Lightning
1967 Triumph T20 Mountain Cub
1967 Moto Guzzi V7
1969 B44 Victor Special
Re: Spark plugs for A65'S?? [Re: ] #365054
03/27/11 1:00 am
03/27/11 1:00 am
Generally,
I like B8ES NGK's for my A10's and A65's.
For me, Champion's always foul out.
More'n a dozen years ago, I ran accross a bargain on ND plugs, W20ES-U, and W22ES-U, and I got several boxes at the time. They've been working fine for me all this time. I still have a few boxes left. Looks like I have plug stock for a few years yet...
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365082
03/27/11 5:07 am
03/27/11 5:07 am
I hate NGKs, they always foul. Only Champion for me, N3C, maybe N4C.
Re: Spark plugs for A65'S?? [Re: leon bee] #365095
03/27/11 9:33 am
03/27/11 9:33 am
BSA_WM20 Online content
BSA_WM20  Online Content
As a general rule modern "fuels" require one grade hotter than specified for real petrol.
The more time you spend running slowly or at idle the hotter plug you will need.
This is simply to prevent the heavy oilly gunk in the fuel condensing out on your plug causing it to foul.
On a club run I go 2 grades hotter while n long trips I usually go only 1 grade hotter which in the M20 means a BP5HS or BP6HS.
The actual equivalent plug would be 1/2 way between a B7 & B8.
Check if you can run the projecting electrodes without fouling on your piston by putting a lump of plasticine around .040" to .050" on the end of the plug & kicking the motor over.
Platinimum or any other "exotic" metal plugs will foul less than standard plugs as standard plugs were designed to burn stuff called "petrol" which sadly is no longer available.
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365125
03/27/11 2:11 pm
03/27/11 2:11 pm
What spark plug caps should I use. I assume a resistor type with the EI. 3 ohm, 5 ohm??
1967 A65 Lightning
1967 Moto Guzzi V7
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365129
03/27/11 2:37 pm
03/27/11 2:37 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
my A65 with Pazon and HD dual outlet coil....Lucas bumblebee solid copper core wire..Champion 1960s style bakelite caps with resistor 'pill' removed...Champion N4C...but that's just me
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365254
03/27/11 10:51 pm
03/27/11 10:51 pm
I use N4c in my '71, though I have also used B7ES. Zelda seems to like the Champions just a little bit better.
I also have the Sparx EI. I have used 5K resistor caps, but it gets a fatter spark with non-resistor caps. I currently use NGK model LZFH non-resistor caps with copper-core wires.
As I understand it, resistor caps are only needed with a digital EI or digital regulator (or if you listen to the radio while riding. laugh )
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365279
03/28/11 1:52 am
03/28/11 1:52 am
Thanks DaveP, that's what I needed. I was wondering about interference with the ei. Good to know.
Is it bad taste to have Champion plugs with NGK caps?????
1967 A65 Lightning
1967 Moto Guzzi V7
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365384
03/28/11 6:11 pm
03/28/11 6:11 pm
I have some NGK caps on my dirty rat bike.
Re: Spark plugs for A65'S?? [Re: Rusty Goose] #365576
03/29/11 6:23 pm
03/29/11 6:23 pm
Maryland
Porrick Offline
Porrick  Offline
Maryland
NGK B8ES and resistor caps for my 66 A65L with sparks EI and HO alternator and dual output coil. Nice fat spark and no problems.
Porrick
'66 A65L
Page Time: 0.175s Queries: 15 (0.007s) Memory: 1.0584 MB (Peak: 1.2466 MB) Zlib disabled. Server Time: 2018-02-22 20:51:22 UTC
