lincolntbird
lincolntbird
Caveside, Tasmania, Australia
192 registered members (68 royalstar tony), 1,662 guests, and 517 spiders.
10036 Registered Users
Lannis 148
kommando 113
478,672 mail-order LSR
Topics65,743
Posts635,554
Members10,036
Chaincase oil #360652
03/01/11 4:52 am
03/01/11 4:52 am
Texas USA
DaveOfTexas Offline OP
Texas USA
p30 of my Owners Handbook has a chart with some no-longer-available oils, I am sure, for the chaincase and the front forks.
Some are 10W30 and 10W40 engine oil.
Is that currently the accepted thinking?
1969 BSA B44VS PC8113
Engine PC8113B44VS
Recently acquired (Feb 2011) Aiming to get running and return all parts/configurations to original.
First BSA. Have 1970 Honda CB750 too.
Re: Chaincase oil [Re: DaveOfTexas] #360660
03/01/11 5:36 am
03/01/11 5:36 am
Regular old 10W30 will be fine.
Many folks also swear by using ATF in the chain case. I'm sure they'll chime in here soon.
Re: Chaincase oil [Re: DaveOfTexas] #360670
03/01/11 8:16 am
03/01/11 8:16 am
BSA_WM20 Offline
BSA_WM20  Offline
As you are putting am old bike which is new to you on the road I would suggen that you do as mentioned above.
Engine oil in the engine
ATF in the primary
Synthetic in the gearbox ( or if not a special gearbox oil that is a funny colour )
Logic behind this is that if they are all different colours it will make chasing down all of those oil leaks much easier.
I use Valvoline 20W40 in the engine ( Brown )
Dextron II in the primary ( Pink )
Penrite manual box oil in the box ( Blue or Purple )
In new bikes thus it is easy to work out where those annoying dribbles are coming from.
After I have been riding the bike for a while & am use to it incontenece then I go back to 20W40 every where, just to make my life easy.
The only really important thing is to change the engine oil regularly.
I knew a bloke who dropped his A65's oil every time he took it for a ride.
He kept the reasonably clean oil and used it when he did oil changes in his F 100 truck. "The truck has got better filters than the bike". He got over 80,000 miles from a wonky bottom end and it was just as good ( or bad ) when he sold it as it was when he bought it.
For your forks, get a couple of bottles of genuine fork oil as different weights of fork oil can be mixed together to get the forks just the way you like them.
Re: Chaincase oil [Re: DaveOfTexas] #360845
03/02/11 5:13 am
03/02/11 5:13 am
Mark Z Online content
Mark Z  Online Content
"The only really important thing is to change the engine oil regularly."
And it's important to change the primary chaincase oil regularly as well, in order to get maximum life out of your clutch discs.
I'm also a proponent of ATF in the primary. The benefit is greatest when starting with a fresh set of discs though.
Re: Chaincase oil [Re: DaveOfTexas] #360847
03/02/11 5:20 am
03/02/11 5:20 am
I should have also mentioned, the gear oil (80-90W) should be changed once or twice a year, depending on the environment in which the bike is operated and stored. The gearbox likes to collect condensation (and sometimes water if the filler plug gasket fails). You'll know this has happened if the drained oil is milky-looking.
Re: Chaincase oil [Re: DaveOfTexas] #360853
03/02/11 6:01 am
03/02/11 6:01 am
Texas USA
Texas USA
Thanks once again. I think I have settled on:
For the engine I will use 20W50
For the transmission (gearbox) I will use ATF or gear oil 80-90W
For the primary chaincase (has clutch), ATF or 10W30 eng oil.
For the front forks, 10W30 or a custom combo.
For the rear chain, graphite grease.
Gasoline; 98 octane min.
This is a beautiful machine, I can't wait to hear it run.
Engine PC8113B44VS
Re: Chaincase oil [Re: DaveOfTexas] #360864
03/02/11 12:09 pm
03/02/11 12:09 pm
Norway
Ola Offline
Ola  Offline
Norway
You are absolutely right Mark Z. The dip stick/breather design from late -67 accumulates rain water and drain it to the gear box.
Best regards
(Doug Hele, 1919 - 2001)
Re: Chaincase oil [Re: DaveOfTexas] #360882
03/02/11 4:12 pm
03/02/11 4:12 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Dave,
The owners manual specifies SAE 20 oil for the forks, not "10W30 or a custom combo".
Re: Chaincase oil [Re: DaveOfTexas] #360932
03/02/11 9:08 pm
03/02/11 9:08 pm
Texas USA
Texas USA
Thanks Gary I will try the SAE 20 in the forks.
Back to the gearbox, I checked with my supplier and he says the ATF and the gear oil 80-90W are vastly different in viscosity.
What to use?
Engine PC8113B44VS
Re: Chaincase oil [Re: DaveOfTexas] #360933
03/02/11 9:15 pm
03/02/11 9:15 pm
Texas USA
Texas USA
PS Gary we must have different manuals, mine says nothing about sae20 but does list 10W30 motor oil. Model differences?
Thanks.
Engine PC8113B44VS
Re: Chaincase oil [Re: DaveOfTexas] #360935
03/02/11 9:20 pm
03/02/11 9:20 pm
Texas
bandit Offline
bandit  Offline
Texas
Dave,
Use 80/90 wt "gear oil" in the gear box.
Try to get some synthetic as has been mentioned.....
I've found synthetic ATF for the primary works well.
Valvoline single wt racing 50wt, VR-1, is what I use in the engine, especially in the summers in TX.....! 40wt in the winter.
Believe it when these guys say to change often, cheap insurance...
Good luck.....;o)
69 Lightning
71 BMW R75/5
57 Cushman
74 MGB
So it's every hand to his rope or gun,
Quick's the word, Sharp's the Action.....
Re: Chaincase oil [Re: DaveOfTexas] #361001
03/03/11 3:34 am
03/03/11 3:34 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Dave,
manuals 00-4144 and 00-4171 both indicate 10W/30 and 10W/40 depending on what brand is used. manuals 00-4121, 00-4126, 00-4137, and 00-4142 all indicate 20w depending on what brand is used. All the forks have nearly the same parts. Go figure.
20W is getting harder to find unless you want to buy a gallon.
Re: Chaincase oil [Re: DaveOfTexas] #361133
03/03/11 10:51 pm
03/03/11 10:51 pm
El Dorado, California
Roadwarrior Offline
Private Sponsor
Roadwarrior  Offline
Private Sponsor
The weight of the oil in the forks should depend on the fork reaction or stiffness you want on the ride. In the motor, make sure you are using Motorcycle oil. You need the extra ZDDP in the oil that the modern automobile oils do not have. 20/50 works great. I'd also put on a return side oil filter. MAP has them and they work great. I have one on my B44, and it keeps the oil nice and clean, and will triple the life of the motor. ATF or 20/50 motorcycle oil in the primary chain works fine as long as you don't over fill it. The oil in there is to lube the primary chain.
73 Triumph T140 Main Ride
70 Bonnie
67 BSA West Coast Hornet
56 Chevy
Who are the brain police?
Re: Chaincase oil [Re: DaveOfTexas] #361179
03/04/11 4:22 am
03/04/11 4:22 am
Hmm, surprised no one has said this, but you should use fork oil in the forks. Fork oil has the attribute of not foaming when agitated. If the oil foams, it loses viscosity, reducing damping.
Later style forks like a lighter weight oil, and ATF is often specified (ATF also has non-foaming attribute), but ATF is too light for the earlier damper designs. Fork oil is available in any viscosity, all the way from 5W to 30W. As was pointed out above, it's a matter of how much damping feels right to you. I've settled on 15W for my '66.
No one suggested ATF in the gearbox, only the primary chaincase. ATF is way too light for the gearbox, you want 80-90W.
Re: Chaincase oil [Re: Mark Z] #361702
03/07/11 3:31 am
03/07/11 3:31 am
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
My vote:
20W50 in the motor summer 10W40 winter (unless you don't have or ride in "Winter") I have been using Spectro Golden but it is really pricy and getting hard to come by. Soooo I'm switching to the Valvolene 20W50 VR-1 Race oil in the summer and the Valvolene 10W40 motorcycle oil in the winter because they have the most zinc and I can get them at any Autozone for a reasonable price.
Gearbox - 85W140 gear summer 80W90 in the winter (I'll probably get some hell for that). Again Valvolene in the dark blue bottle. I've be using this for years in my BMW just because it "felt" better than anything else. So my choice was a subjective one. Don't use ATF in the gearbox.
Primary - 10W30 or 20W50 conventional car cheep stuff with not much zinc. Anti friction additives are bad for the clutch. ATF leaks out too fast in my bikes and I usually have a long way to go. If your Primary doesn't leak then you can use ATF. Lots of people do...I know the racebike people like it but perhaps for different reasons?
+1 on changing often plus all my BSA's have remote Harley/Norton spinon oil filters (WIX).
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
